Question about Gateway MX3228 Notebook
Opening Gateway MX3228
The power jack on my laptop has broken, I assume soldering point broke. I am comfortable buying a replacement and soldering it but I cannot for the life of me get the laptop opened all the way to do so. I have taken all the screws off underneath that appear to hold it together but still cannot open it. Does anyone have a link to a guide to open this laptop up properly? Any help is greatly appreciated. I can also be emailed at synapses11@gmail.com
  • synapses11 Feb 06, 2009
    TY very much, my problem was that I wasnt taking the keyboard off. I was able to get the dc jack out which isnt connected to the mb but rather a small board connected with wires which makes it vastly easier to get out. Unfortunately saw no broken connections. Will have to wait for replacement piece to come in the mail.
    President:
  • 1,902 Answers
Ok here is instructions on removing to get to the motherboard. It is for a different laptop but removal is exactly the same.
http://www.irisvista.com/tech/laptops/ToshibaA75/satA75_1.htm
Posted on Feb 06, 2009
  • Jeremy Reddick
    Jeremy Reddick Feb 06, 2009
    Ok understand. Well best of luck to you and have a good weekend
My DC jack broke what should i do.
I am assuming you mean the DC jack on the motherboard in your laptop?
You can repair it yourself, or take it to a repair shop and pay to have someone do it.
To repair it yourself, you'll need:
1) A new DC jack (though sometimes you can fix the broken one)
2) The disassembly guide to your specific model of laptop. Google the phrase "laptop make/model disassembly" and one should come up pretty quickly. Guides are generally step-by-step with pictures included, and putting it back together is just the reverse of disassembly.
3) A soldering iron and solder. 15-30 watts for delicated boards like a motherboard. Once you've pulled your motherboard out, You can de-solder the broken DC jack from the motherboard (if necessary) and solder the new one on. DC jacks are generally 2-4 solder points and fairly simple to press back on.
May 26, 2011 | Computers & Internet
Hello my laptop t41 power is not even flash but the adapter is working,am technician and i have troubleshoot allot.
I concur with what Diegotech stated.
To iterate further;
1) The DC Power Jack (DC IN), may have cracked solder joint/s on the motherboard connector, (Female), where the DC Power Jack plugs in.
Resolder
2) The DC Power Jack may be broken.
Center Pin mount, and/or body of DC Power Jack, and/or Outer Shell mount.
Replace DC Power Jack.
3) Wires from the DC Power jack plug to the female connector on the motherboard, may be bad.
Two examples, of a place to buy an IBM ThinkPad T41 DC Power Jack,
1) http://www.buy.com/prod/dc-power-jack-connector-socket-for-ibm-thinkpad-t40-t41-t42-r50-r51-r52/q/sellerid/23962916/loc/101/215782035.html
2) http://www.machinaelectronics.com/store/buypart/IBM_Thinkpad_T41/DC-P001
Past this point it's a bad DC sensor on the motherboard.
Replace motherboard.
IBM ThinkPad T41 Service Manual, (Free),
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-ibmlenovo
On this page go down to the 8th line.
The one that starts with > ThinkPad T20.
Go across, and click on > T41
Takes approximately 2 seconds to see the first page, and additional time to fully download.
Page 142 for 14.1 inch LCD screen
Page 151 for 15 inch LCD screen
(PDF file page number box at top)
Dec 01, 2010 | IBM ThinkPad T41 Notebook
Powerjack is loose when plugging in charger.no power,no lights battery can not be charged.
In order to fix this problem, you will have to fully disassemble your laptop to get access to the motherboard & the power jack. If the power jack is not broken but only loose, you can re-solder it to the motherboard. Otherwise, you will need to buy a replacement power jack (usually less than US$ 10), de-solder the broken power jack, & then solder in the new one.
When this is done, re-assemble back your laptop.
Nov 27, 2010 | Acer Aspire One PC Notebook
My acer aspire 3680 could not power on by bat and adaptor
DC Jack diagnosis:
1. Test power adapter for output voltage. Bend the power cable in various directions while doing this to be sure that there is no broken conductors in the cable.
2. If power adapter is Ok, connect it & see if the power LED on the laptop will glow when you jiggle the power connector in various directions. If yes, then the DC jack might be loose or damaged, & need to be either re-soldered or replaced.
3. If not, then disassemble the laptop. Remove any components that attach to the laptop's motherboard first (e.g. battery, hard drive, RAM, wireless card, optical drive, ... etc.)
4. Next, remove the keyboard & the LCD screen.
5. Finally, unscrew all screws that hold the upper cover & lower cover together so that you could gain access to the motherboard.
6. Inspect the solder points connecting the DC jack to the motherboard. Make sure that none of them is loose. If any, re-solder them.
7. Inspect the center pin in the DC jack. Make sure that it is not broken or loose. If it is, then you might need to replace the DC jack.
8. When you are done, re-assemble back the laptop.
Oct 08, 2010 | Acer Aspire 3680 Laptop
Loose power connection on sony vaio PCG 7V1M
I'm assuming the laptop is out of warrantee.
It sounds like the power adapter jack is broken. To replace this you have to take the laptop apart down to the motherboard, unsolder the jack, solder on the replacement and reassemble the laptop. This is not something a novice should attempt.
Check with your laptop repair shops. The replacement/repair should be under $100.
Mar 02, 2010 | Sony VAIO Notebook
Plastic piece on inside of where power plugs into back of computer broke how can i fix it myself
  1. Be highly skilled in electronics soldering.
  2. Buy a replacement power jack, Jacks for most models are available on EBay
  3. Using soldering iron, and other required tools, remove old jack, then clean the connections, and solder new jack in place.
For what it is worth, I opted to buy a replacement motherboard, (also available on EBay) and replaced it (About an hour job for anyone familiar with working on a portable system.) Generally, if you don't do electronics soldering it is not recommended for novices (I'm great fixing computers, but I **** at soldering)
Oct 14, 2009 | Sony Computers & Internet
DC power inside computer will not charge battery.
About 99% of the time the DC female adapter is soldered to the motherboard making it near impossible to fix. Getting solder on anything would ruin the motherboard.
It is possible that it is your Power Cord and not the jack on the motherboard. Same problem I had a few weeks go with a clients laptop. You may want to buy a new Power Cord, and try that before you go out and have to get a new motherboard (which can be VERY costly, or even buying a new laptop).
Post the model number of your laptop and I can direct you somewhere to get a good deal on a new power cord.
Mar 16, 2009 | Gateway Computers & Internet
Broken Power Pin
Your model has a power jack that is soldered to the mainboard.
Yes, this is a common problem with a lot of notebooks. It usually happens when someone walks by and trips on the power wire and pulls the notebook off the desk / table and onto the floor.
Unless you're comfortable with taking it apart, and good with a soldering iron, you should take it to a repair shop.
If you ARE comfortable with doing so, the power jack can be purchased from several suppliers on Ebay, for about $12 including shipping. Just do a search for "aspire 3680 jack" and you will see them.
PS: Most shops charge $100-$150 to replace the jack.
Apr 06, 2008 | Acer Aspire 3680 Laptop
Plug in is broke
you cant buy a new one..........
Oct 07, 2007 | Averatec 3200 Notebook
Replace dc power jack
Hi, by dc power jack, if you mean the one at the back of your toshiba laptop, to replace, you may have to completely disassemble the unit and expose the back of the printed circuit board. This would involve removal of several small screws, panels, brackets, devices (hd. kb, cd, etc), connectors, cables. The screws would normally be small philips + but others might require a torx driver. Once the back of the main pcb is exposed, you can proceed to desolder the jack. normally there are 2 or 3 solder points. Simply insert the new jack and solder in place, reassemble and that should do the trick. However, if you are not comfortable with disaasmebly and soldering, it might be to your advantage to let somebody technically trained to perform the replacement for you. Hope this helps. Please let me know how it turns up. Regards.
Apr 11, 2007 | Toshiba Satellite P25-S507 Notebook
Computers & Internet Logo
273 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
