Question about Intel CeleronD 2.933 256K 533FSB Skt-478 Retail RE2933C (IN36C293D5R)
Uninstal how wud i uninstall recovery disk. and set it bak to original windows xp. i havnt the disk
  • 167 Answers
Hi, this is hard with out the disc for xp, or the one that goes with the system. if you have the key code, and you can get a xp disc,you would be able to clean install of xp, but you would lose the extras and other software that came with the computer,most of those you can download. do not use a dell,hp,or any other brands install disc! unless yours is a direct match. you may try and find an oem xp disc(this is what i would do) and clean install.hope this helps,glen
Posted on Feb 15, 2009
Registery cannot load hive file/systemroot/system 32/config/software or its log of alternatice is corrupt, absent or unwritable on compaq presario2227US
Solution 1
Requires some tech skills:
To complete part one, follow these steps:
  1. Insert the Windows XP startup disk into the floppy disk drive, or insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer.
    Click to select any options that are required to start the computer from the CD-ROM drive if you are prompted to do so.
  2. When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
  3. If you have a dual-boot or multiple-boot computer, select the installation that you want to access from the Recovery Console.
  4. When you are prompted to do so, type the Administrator password. If the administrator password is blank, just press ENTER.
  5. At the Recovery Console command prompt, type the following lines, pressing ENTER after you type each line: md tmp
    copy c:\windows\system32\config\system c:\windows\tmp\system.bak
    copy c:\windows\system32\config\software c:\windows\tmp\software.bak
    copy c:\windows\system32\config\sam c:\windows\tmp\sam.bak
    copy c:\windows\system32\config\security c:\windows\tmp\security.bak
    copy c:\windows\system32\config\default c:\windows\tmp\default.bak
    delete c:\windows\system32\config\system
    delete c:\windows\system32\config\software
    delete c:\windows\system32\config\sam
    delete c:\windows\system32\config\security
    delete c:\windows\system32\config\default
    copy c:\windows\repair\system c:\windows\system32\config\system
    copy c:\windows\repair\software c:\windows\system32\config\software
    copy c:\windows\repair\sam c:\windows\system32\config\sam
    copy c:\windows\repair\security c:\windows\system32\config\security
    copy c:\windows\repair\default c:\windows\system32\config\default
  6. Type exit to quit Recovery Console. Your computer will restart.
Solution 2 Reinstall Windows Xp
Jan 29, 2014 | HP Compaq Presario CQ60-249US Notebook
Saying:/windows/system32/config/system is missing or corrupted n i dnt now how to fix it wut link exactly do i have to download to my usb to fix it n wut r the steps?
Assuming it is windows XP here are the steps to fix that error:
  5. At the Recovery Console command prompt, type the following lines, pressing ENTER after you type each line:md tmp
My YouTube Channel
Click Here Live Tech Support
May 03, 2013 | ASUS Eee PC 2G Surf Notebook
Toshiba A60 equiam will not boot from original recovery disk
Try reseating the RAM modules and then try the recovery CD.
If it still fails, take the RAM modules out and take them to your friendly computer repair shop and get them to test the RAM.
Mar 04, 2012 | Toshiba Computers & Internet
Problem with OS. How can I fix? Net book states - Windows XP could not start because the following file is missing or corrupt: \WINDOWS\SYSTEM32\CONFIG\SYSTEM Can you help? Thanks Philip
Note This procedure assumes that Windows XP is installed to the C:\Windows folder. Make sure to change C:\Windows to the appropriate windows_folder if it is a different location.
If you need more help come back.Post / thumbs / testimonial are welcome!
Dec 03, 2010 | ASUS Eee PC 1005HAB Netbook - Intel Atom...
What are the steps of formatting toshiba tecra M9 using window XP Recovery Disk?
If you are using the original XP Recovery Disk for Toshiba, you have to set your first boot to CD/DVD Rom from our Bios setting or use the 1st boot Function Utility when booting up.
If your 1st boot is your CD/DVD Rom, the Recovery Disk will boot up, and your just follow the wizard to finish the OS installation back go the default setting.
Hope it helps.
Oct 16, 2010 | Computers & Internet
My desktop shut down and is asking me to re install a 32 windows file. What is this and how do I fix it?
Hi, This normally means that a windows file from the system32 folder is missing or corrupt. You will have repair that by using your operating system cd and go to repair when prompted. If this does not work you may have to install a clean copy of your operating system.
Apr 10, 2010 | HP Pavilion a1220n (A1220NED904AA) PC...
I have toshiba L300 pc laptop, i tried to formati
kindly follow these steps:
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Feb 20, 2010 | Toshiba Satellite Pro L300 Notebook
Acer travelmate 225x
Hi!
You may buy a recovery cd for your laptop on this site:
http://www.user-guides.co.uk/cddownload/Acer/AcerTravelMate/Acer-TravelMate-225X-Data-Recovery-Boot-Disk-CD-98-XP-57411.html
Have fun!
*Your vote is highly appreciated. Thanks in advance!
Dec 31, 2008 | Acer TravelMate 225X Notebook
Windows xp corrupted
This is supposed to be caused by some missing registry entries in your windows installation. Not exactly sure why this is happening. May be you have some important files that cannot be copied due to a damaged CD. Microsoft replaces the media for you so that you can try installing using the replacement. Click here for more details
http://support.microsoft.com/default.aspx?scid=kb;en-us;326246
You can also try to recover the PC using recovery console. To do it follow the steps below
    copy c:windowssystem32configsystem c:windows mpsystem.bak
    copy c:windowssystem32configsoftware c:windows mpsoftware.bak
    copy c:windowssystem32configsam c:windows mpsam.bak
    copy c:windowssystem32configsecurity c:windows mpsecurity.bak
    copy c:windowssystem32configdefault c:windows mpdefault.bak
    delete c:windowssystem32configsystem
    delete c:windowssystem32configsoftware
    delete c:windowssystem32configsam
    delete c:windowssystem32configsecurity
    delete c:windowssystem32configdefault
    copy c:windows epairsystem c:windowssystem32configsystem
    copy c:windows epairsoftware c:windowssystem32configsoftware
    copy c:windows epairsam c:windowssystem32configsam
    copy c:windows epairsecurity c:windowssystem32configsecurity
    copy c:windows epairdefault c:windowssystem32configdefault
Source:http://support.microsoft.com/kb/307545
Dec 29, 2008 | Samsung 250GB HD250HJ SATA II 300 7200rpm...
Computers & Internet Logo
44 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
