Question about SmartDisk (FDUSB-TM) External Floppy Drive
1 want to install floppy drive to i mac
I bought smart disk floppy for my i mac but when I  connect it to USB port it does not register
  • 101 Answers
When u connect it leave it connected restart computer when it gets into windows it should find it auto
Posted on Aug 29, 2009
Can I use a Bytecc BT-144 usb external floppy disk drive with an iMac running OS 10.10.1?
I'm not a Mac tech, but I wouldn't see why not. Floppy drives are kinda old school now. You may need a driver for the floppy. Check online and see what you can find. Download and install it.
Or you may have to plug the floppy in, then reboot, to get the Mac to recognize it, especially with a USB port. Some old Windozz machines were like that...maybe your Mac too????
Mac OS is very close to Linux/Unix systems, which have awful support for floppy drives. That's another possibility.
If your windows machine can't read the disk, makes me think the floppy drive is bad or you have corrupted files on the disk. Try a couple known good floppy disks on the Windoz box and see what happens. Or another removable floppy drive. They cost $5 to $10 now.
Jan 22, 2015 | BYTECC (BT144) External Floppy Drive
Tip
NO BOOTABLE DEVICE
When the computer/laptop cannot see a boot file/disk on either the hard disk or floppy drive it gives an error message - "No bootable device. Insert boot disk and press any key"
First thing, check to see if the is a floppy disk inthe floppy drive, if so removes this disk.
If there was no disk in the floppy drive then it maybe a hard disk problem.
Check the BIOS to see if the hard disk is detected, if not open the case and re-seat the data cable on the hard drive and also where it connects to the motherboard disk controller.
If it still gives this error message and the BIOS does not detect this hard drive, then the hard drive is probably faulty.
A further check on the hard drive, remove the hard drive and connect it to an USB hard drive adapter and connect it to a working computer's USB port, if this computer does not detect it as an external storage device then the hard drive is faulty.
To get the computer operating again, install a new hard drive in your computer and then install Windows on this hard drive plus the computer's device drivers and your programs.
on Oct 02, 2010 | Computers & Internet
Is there a power light on the BT144?
light only appears when accessing data from disk. Check that you have right drivers... that is it.
Mar 28, 2014 | BYTECC (BT144) External Floppy Drive
Just bought a teac fd-05pub usb portable diskette drive. i have a dell computer with windows vista. when i pluged it in the device was installed, however the power light comes on for a few seconds then...
The below is on the basis that the drive is visible in "Computer"...
This can be tow thing, one the drive is not receiving enough power from your USB port, try unplugging any addtional USB devices connected to the PC, if this doesn't work try a powered USB hub. Second the floppy disk is faulty or the drive itself is faulty.
Hope this helps, let me know how it goes.
Thanks
Jul 11, 2011 | Teac FD-05PUB External Floppy Drive
I need to install a floppy disk drive what's the
Instead of opening the computer case, and installing a floppy drive, I would suggest buying a floppy drive with a usb adapter.
No technicals are required and are just plug and play. All you need is an available usb port. However please note that this type is slightly more expensive.
Feb 02, 2010 | Gigabyte MA785GM-US2H Motherboard w/ AMD...
Need a USB converter for some serial thing
dynex puts out a usb to serial adapter can be bought at best buy for somewhere around 15.00 you will need the drivers from the cd to make it work and then will probably have to set the port it is looking for that should be all you need
Dec 05, 2008 | Toshiba - Floppy disk drive - external -...
Bought a usb floppy drive reader to convert my floppies to my laptop. have plugged in the usb cord. what do I do now?
Its easy to use:
Step 1). Just on your lap.
After complete boot
Step2). Insert your floppy connector one end to your USB port of Lap.
Step 3). Double Click on My Computer Icon.
The my Computer will be open.
and if every thing is ok, a floppy disk drive icon [A: or B:] will be shown in the window.
Step 4). Insert your floppy disk into the Drive.
wait till the floppy disk drive light goes off.
Step 5). Double click on floppy disk drive icon [A: or B:].
and the content of the floppy will be open.
have any question... ask me
Thanks
Iqbal
Mar 22, 2008 | Computers & Internet
Main advantages
* Super high capacity storage/ floppy disk compatible The Panasonic PV-SD4090 and PV-SD5000 digital cameras offer super high capacity storage on a 120MB SuperDisk™ Diskette for up to 1500 shots on the PV-SD4090 (Up to 1000 on PV-SD5000). Also, both cameras are floppy disk compatible. * USB Port/External SuperDisk™ Drive Both cameras come equipped with a USB port so you can quickly and easily transfer images from either a SuperDisk™ Diskette or floppy disk (using the included USB cable) to your computer, even if your computer does not come equipped with either a SuperDisk™ Drive or floppy disk drive. In addition, images and data can be transferred from your computer to the camera using the included USB cable*. This lets both the PV-SD4090 and the PV-SD5000 digital cameras function as an external SuperDisk™ Drive so you can easily archive your images or backup all your data (i.e. Excel, PowerPoint files). * Inexpensive media Panasonic SuperDisk™ digital cameras use SuperDisk™ Diskettes or 1.44MB floppy disks. SuperDisk™ Diskettes cost approximately $10.00 each (suggested retail price), which is far less expensive than comparable CompactFlash or SmartMedia cards. * Motion image recording with audio The PV-SD5000 can record up to 12 seconds of motion images with audio (the PV-SD4090 stores up to 10 seconds) using the popular QuickTime™** format, so you can easily send motion image files to friends and family. * TIFF recording (PV-SD5000 only) TIFF format recording allows you to take uncompressed images with greater clarity and detail. * Comes with a complete package of accessories, including: 1. 120MB Panasonic SuperDisk™ Diskette 2. Rechargeable lithium ion battery pack 3. AC adapter charger 4. DC cable 5. A/V cable 6. USB cable 7. Camera strap 8. Software CD-ROM including Adobe® PhotoDeluxe® editing software *Requires Microsoft™ Windows® 98 preinstalled PC with USB port, Windows® 2000 PC with USB port, iMac® or Power Macintosh® G3 or G4 with USB port and Mac OS version 8.1 or later. Windows® 2000 driver for the PV-SD4090 is currently available on this website. Software for the PV-SD5000 will be available in the near future. **QuickTime and the QuickTime logo are trademarks used under license. QuickTime is registered in the U.S. and other countries.
Sep 04, 2005 | Panasonic Palmcam PV-SD5000 Digital Camera
Main advantages
Sep 04, 2005 | Panasonic Palmcam PV-SD4090 Digital Camera
SmartDisk (FDUSB-TM) External Floppy Drive Logo
123 people viewed this question
Top SmartDisk Computers & Internet Experts
Sunday Ojelabi
Sunday Ojelabi
 Ian Kayhan
Ian Kayhan
Are you a SmartDisk Computer and Internet Expert? Answer questions, earn points and help others
