My oil light came on and when i accelerated it would start making this knocking sound then when i got home i checked my oil i had no oil and today i just got oil in my car and its still making the knocking sound
SOURCE: Check engine and VSC lights on
I talked to you on the live chat, and I think that you may have missed the end of my typing...
What I went on to say is that more often than not, on the 02 4Runners, the Check and VSC lights in tandem look mainly after the emission system, and, since you stated no issues during the road test, I would guess that it is a fuel issue (too full/loose gas cap). But, if you can get the vehicle scanned, I will be very glad to provide you with more and better info if you provide me with the DTC codes. That would require your guy or an autozone hookup to a scan tool. I hope my clarification helps; and the graciouness of a FIxYa rating for this question would be greatly appreciated
SOURCE: Oil light comes on and the engine begins to make a knocking sound
how much oil is left in the engine ?
the smoke was probaly oil burning,the knocking could be from low oil pressure,this could be very bad.check the oil and coolant levels and repost and let me know how they are.if any oil shows on the dipstick smell it and see if it smells burnt.
SOURCE: 99 Toyota Corolla multiple misfire problem
This is what you need to do, change the plug wires, because if there is a bad wire you would definitely experiences sputter or a stutter, so do the plug wires and at the same time do the spark plugs, this should take care of your problem. if not let me know and i will give you the next step
Testimonial: "So far the car is working fine after I replaced the spark plugs and wires! Thanks so much!"
SOURCE: CHeck engine AND VSA light came on in my car 2003 Highlander
Try Toyota Ed's fix; this was exactly what had happened on my Highlander
