Back to:
Tags:
LandWare Pocket Quicken 2.0
Synchro between Quicken 2002 deluxe and Pocket...
By man1 - usenet poster
To anyone using this combo:
When I add a transaction in Pocket Quicken, it does not get transferred into
Quicken 2002. All HotSync parameters seem in order. All transactions from
Quicken 2002 are downloaded into PQ on HotSync.
When I was using Quicken 99 and PQ v 1.0, it worked fine...
Any ideas?
Thanks
Fran??ois
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 01, 2007
Not Rated (0)
jessie25
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Peter J. Ricciardiello <
I too have a an issue when I sync. In my case no transaction ever get
listed.
Has this issue been resolved.
Other issue i have -
1. In can no longer backup my qif file. Message "File not backed up".
This work fine until 14 Jun 02
2. I no longer send online bill payment via checkfree through the
internet. Yes my account is enabled at checkfree. This was work
until just resently.
I keep getting asked to setup my modem, but I doing this via the
internet and a cable modem. CheckFree provide more support then
Inuit/Quicken. I also get a message stating that I have outstanding
transaction that must be accepted. Wrong there are no tranactions
listed, I say accept all then continue, this function is
looping!!!!!!!!!!!!
I've validated, I've super validated without error whats up!!!!!!!!
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Synchro between Quicken 2002 deluxe and Pocket Quicken v 2.0:
I don't want to Accept this solution
Solution #2
Not Rated (0)
Riddle
Rating: 0%, 0 votes
Did you try to contact Landware support? This seems to be a PQ problem,
not a Quicken problem.
Other than that, I am out of ideas. :-(
(omit 'x' to reply)
Thank You!
Solution #3
Not Rated (0)
Rogers
Rating: 0%, 0 votes
Thank you for your insights. My answers follow your lead. BTW, Intuit
suggest, after three messages, a clean install of both Q2002 and PQ... I
guess that's all I'm left with, at this point...
"Peter J. Ricciardiello" < ...
Right.
Palm Log:
OK Pocket Quicken 2.0
PC Log:
Beginning Pocket Quicken 2.0 Sync
-- Backing up db PQKN-Accounts to file
E:\Palm\Franco\Backup\PQKN-Accounts.PDB
-- Backing up db PQKN-Transactions to file
E:\Palm\Franco\Backup\PQKN-Transactions.PDB
-- Backing up db PQKN-Lists to file E:\Palm\Franco\Backup\PQKN-Lists.PDB
-- Backing up db PQKN-Memorized to file
E:\Palm\Franco\Backup\PQKN-Memorized.PDB
-- Backing up db Saved Preferences to file
Both
I do recall an option in the PocketQuicken Hotsync
Palm: HS Options: Receive-All checked; Send-Checked
All accounts set on Send and Receive
"Match window" not showing up; it does when I download transactions from the
bank
Negative
Thank You!
Solution #4
Not Rated (0)
2Pansy
Rating: 0%, 0 votes
Since you indicated that it appears that you are receiving new Quicken
transaction into PQ, then issues like an incorrect password or an
incorrect Quicken data file name in HotSync's PQ options would not be
relevant.
Have you checked the HotSync log (found either on the Palm in the HotSync
utility or off the LOG menu option of the PC's HotSync menu)? What does
it report for the PocketQuicken Hotsync?
You stated you checked the HotSync options. Did you do this in
PocketQuicken on the Palm, or did you do this in the HotSync utility
itself on the PC? I do recall an option in the PocketQuicken Hotsync
menu that allows you to specify what to sync up with the PC's Quicken.
Perhaps the option to upload new transactions became disabled?
With Q2001 and Q2002, the transactions coming from PocketQuicken do not
go directly to the register. Instead they go to a "match window" that
allows you to accept them as NEW transactions, match them to existing
transactions already in your register, or delete them outright. This is
different than how Q99 processed incoming transactions. Thus, a few
ideas relating to this Quicken change come to mind:
After you HotSync, open Quicken. When you open the account register to
which you are uploading transactions, Quicken should be sensing the new
transactions and opening the match window automatically at the bottom of
the register. Do you see this window appear when you open the register?
Quicken does offer a "Accept All" button when new transactions appear in
the match window. If pushed, this button will accept whatever status was
deduced by the matching algorithm. If this algorithm mistakenly matched
these incoming transactions to existing transactions already in the
register, it will look as if the incoming transactions disappeared when,
in reality, they were matched to these existing transactions. That would
make it look as if the PQ transactions are not importing correctly.
(omit 'x' to reply)
Thank You!
Can you Help with these PDAs problems?
PDAs
m1621 fitting external buzer for guard alarm
PDAs
What does IPK stand for?
PDAs
where can i find an manual or instructions to download on...
PDAs
I can play the video file (Skateboarder Video) that came...
PDAs
My Name : Shakil Ahmed My mobile : Asus PDA P750 My...
Loading problems.
Repair Service
Prescreened Contractors
Get Matched to Prescreened Computer Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
