Question about Tomtom GO 910 GPS Receiver
The power turns on but the screen is blank
The green light is on and we have it plugged in but nothing shows up on the screen
  • Anonymous Feb 14, 2009
    The green light is on and we have it plugged in but nothing shows up on the screen..
I had a similar problem after I fixed the top power button on my Nuvi 350. I had dislodged one of the tiny ribbon cables connecting the screen (in my case it was partially dislodged so the problem was intermittent).
Your problem could be different -- the screen itself could be damaged or something else could be wrong. Try the obvious first -- like the reset button on the back. ;-)
If your problem is like mine, here's how to deal with it......
First of all, the best instructions I've found for opening the unit are here:
http://www.fixya.com/support/t1366185-garmin_nuvi_660_dead_battery
I added to that thread some tips at the end, because though the instructions worked, I had a couple of minor tribulations following them - hopefully what I added will save some time.
Once the unit is open, note that there are three orange colored ribbon cables in the unit. DO NOT CREASE THEM. These are quite fragile.
One is for the antenna, two are for the touch screen. I think one is the "touch" part and the other is the "screen display" part, but I'm not sure.
These connect in a tricky way. There's a very narrow flip-up latch that runs the width of the cable right where it connects to the board. This is hinged like a piano hinge and can be flipped "up" carefully. The hinged side is away from the ribbon cable. You can carefully wedge up that latch and then the ribbon will slide in and out under it. Make sure the ribbon cables are slid in carefully but fully and evenly. They go in further than you might think. Then, keeping the ribbon cables well seated, close the hinge.
If you force things and it breaks, you're going to destroy the unit (unless you're MUCH better than I am at soldering on a new connector to the board). You might want to try using a pencil eraser to push that hinge closed as it has some give to it.
If you've never done anything like this before, consider the following general tips:
1. At every (and I mean every) stage, take a digital photograph of what you're doing. If you forget how it goes back together, you can look at your photos. Take way more photos than you think you need. You will not remember what you think you remember.
2. As Robert Persig once advised -- the most important thing is a comfortable place to sit and good light. In other words, take your time and enjoy the process of learning and doing it. If you try to rush or get frustrated, you'll do poor work.
3. Don't force things. They break.
4. If you fail, you're no worse off than when you started -- since the device is useless right now. If you succeed, you'll feel really great about it.
Best of luck.
Posted on Feb 08, 2009
Sanyo dp42848 turns on but blank screen
Replace the Main board if your not hearing any audio from the set.
Oct 27, 2012 | Sanyo DP42848 LCD TV
Unable to solve Blank screen
hmm confusing but try turning your ps3 off at the wall give it 5mins and try again if nothing happens try it on another tv
Sep 25, 2009 | Sony PlayStation® 3 (80GB) Console
Ps3 turns on with green light an doesn't show users screen blank
Your tv screen has problems with the video mode
that has setted up on your ps3, hold the power button till hear two beeps, this will reset the video mode of the ps3, and leavse you at a screen to set up the video mode of the ps3.
Succes.
Sep 03, 2009 | Sony Playstation 3 (PS3) Console
Samsung s730 nothing comes up when turned on
when you press the power button does it show a green light?
try using batteries with 2500mAh/ 1.5 volts or higher
Jul 02, 2009 | Samsung Digimax S730 Digital Camera
Completely blank screen when power is on.
do a hard reset....remove charger>remove peripherals>remove battery> press and hold the power button for about 30secs, while batt and charger is removed> then plug in the charger only and turn ON!
Please vote, thanks!
Jun 27, 2009 | Acer Aspire One Netbook 8.9" Notebook
I have a dell inspiron 5000e that won't power up. the battery is dead but the adapter works. after pressing the power button the left light beneath the screen turns a solid green and the center light...
As per the symptoms given by you it seems like a motherboard problem. Follow the steps on the link below and it would suggest what part needs to be replaced.
http://tinyurl.com/6xxv4h
thanks
proton
Aug 02, 2008 | Computers & Internet
Boot up problem
It is possibly the RAM it may have ceased. Look at it underneath held in by two screws. Take it out and examine it then put it back. The motherboard seems ok because you said the lights are lighting up. Sometimes the ram can stop even the bios and nothing can boot up.
Oct 03, 2007 | Compaq Evo Notebook N115
Bank Monitor problems
Unplug the cable from your PC, if the monitor shows a test image, the monitor is fine and the problem is with your graphic card. If you dont see nothing on-screen after unpluging the cable from the PC, then the monitor in damaged. Send it to repair.
Jul 09, 2007 | Dell E193FP 19" LCD Monitor
Tomtom GO 910 GPS Receiver Logo
141 people viewed this question
Top Tomtom GPS Experts
Martin Murray
Will Halftowaite
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
