Question about Icom M302 VHF Radio
How to program the emergency rd button on IC-F43TR
Could anyone please help me to program the emergency red button on ICOM IC-F43TR.? Even a link to some programming help/documentation is highly appreciated.
thanks
    Problem Solver:
  • 12 Answers
First do you have the correct software? Second do you have the correct programming cable? If the first two are OK you are half way there. Open the program and download the radios info to the program, it's that little computer icon. Click on "common settings", you will then see "key & display" click on that. You should have a small window with all the buttons including the red one. I hope this helps.
Posted on Sep 13, 2009
My icom v8000 says off when I transmit how do I fix this
Hi
This sounds very much to me like a power supply problem.
If I understand your question correctly, the radio will turn on but when transmitting it shuts itself shuts off. This is usually caused by a poor connection to your battery. Although it is possible to show 12v using a voltmeter, there may not be enough connection when putting the circuit under load. (25 watts is a considerable load)
I would inspect both positive and negative connections (pay particular attention to the crimped lugs) , clean and lubricate them and give it another shot.
Here is a link to Trojan battery explaining in detail the importance of clean battery terminals.
Hope this helps you out.
-Steve
http://www.trojanbattery.com/pdf/WP_BatteryCableGuide_0512.pdf
Mar 09, 2015 | Icom IC-V8000
Why my icom 2200h is getting hot even if i did not used it and when the power is off?
Check your wiring , you may have reversed the power suply with the stan by wires. They are both same polarity, hoever the power goes to fuse and control panel and the standby gos to baterie.
Sep 17, 2014 | Icom Ic 2200h Vhf Mobile Two Way Radio...
I need amounting brack for my icom ic m302 vhf marine transceive where can i get it
Try Ebay as a source. I have had good luck finding such accessories for reasonable.
Aug 20, 2014 | Icom IC-M302 VHF Marine Radio
How to fix icom ic v8000 reversed polarity
you need to change the protection diode
Jun 15, 2014 | Icom IC-V8000
Icom IC-M34 transmit correct but do not receive if sql is above 0
Sound like a speaker problem, dosconnect the speaker and check it with a meter, it should read 8 ohm. Good luck.
Mar 13, 2011 | ICOM Informatique Floating Hand Held Vhf...
Can you provide a SCHEMATIC DIAGRAM OF ICOM IC-2200H?
Lookk here for a scizmo
http://www.cbtricks.com/
Feb 17, 2011 | Icom IC-2200H
Hello, Can you tell me what make of GPS will work with the Icom m-504. I tried using the Garmin 76csx with the NEMA in/Nema out function set, but it will not communicate to the Icom. I would appreciate...
Hi!
We had the same problem with our Uniden Oceanus failing to communicate with our GPS. What the problem was, was that our VHF didn't recognize the NMEA sentences transmitted from our "ancient" GPS. We ended up buying a Standard Horizon cp180 chartplotter. PRESTO! Our DSC capability materialized.
Your 76CSx is newer than our Magellan was, so before you take on the task of a $400 chartplotter purchase, just make sure your BAUD rate is set to 4800. This adjustment alone could make your GPS work with your ICOM.
Hope this is helpful.
Jan 23, 2011 | Icom IC M504 Black Submersible PLUS Marine...
I have an ICOM-504 . I can transmit but I can not receive any chanels even the WX is not receiving
I had the same problem and traced it to a bad connection between flex cables and boards.It seems the SQL signal from the Rx board is not reaching the processor on the front panel. Check all connections (reseat all cables) and try again.
servstan
Aug 09, 2010 | Icom IC M504 Black Submersible PLUS Marine...
Can the Microphone be replaced on a ICOM M302 Radio
The MIC is available with the cord from Icom or me (847-746-0100) It is not easy for the novice, it must be routed through the front panel and plugged in to the circuit board inside. Not impossible to do, just tedious. Also, my wild guess is about $50 to buy the mic, so, not worth it if you pay labor!
Jan 09, 2010 | Icom IC-M302 VHF Marine Radio
Handheld Marine Radio
This applies to all battery powered radios. Take out the battery and measure the voltage to see if it is indeed charged. If it's not, then the fault is the charger or the battery or both. If the battery voltage shows that it is fully charged, then clean the terminals on the battery and on the radio with a pencil eraser to remove any corrosion. If still no joy, then look up in your user's manual on how to do a reset. If you don't have a manual, get on the ICOM website and download one.
Good luck.
Mar 19, 2008 | Icom M302 VHF Radio
Icom M302 VHF Radio Logo
227 people viewed this question
Top Icom Boating Experts
Steve
Steve
Tony
Robert McClure
Are you an Icom Boating Expert? Answer questions, earn points and help others
