Our tec b-472 qp only blinks the online green led when a job is sent to the printer but does not print. we have set up printer with proper driver from Toshiba and are using serial cable 25 to 9 pin. Serial is set to port 1 and have checked all settings on Label View 8.1 correctly and also on printer properties. Please help.
  • leni1024 Feb 06, 2009
    Dip switches are set according to manual. Straight or crossover cable give the same result. Printer is still not printing.
    Test page from printer itself is OK.
The serial cable for the Tec printer must be wired straight through (not a crossover cable). Are you using the original cable that came with the printer? Do you still have the manual? there are some dip switches in the top right hand corner of the inside of the printer that control the serial port settings. If you have the manual and look in there check that they are set to default settings.
Posted on Feb 06, 2009
  • 19 Answers
Check in the parameter set the option code
http://www.fixya.com/support/t606190-tec_472_qq_no_print solution 2 by belgis
Posted on Dec 01, 2009
2 Suggested Answers
  • 300 Answers
SOURCE: tec 472 qq no print
First of all can you print just from the printer ie
Turn on the power while
holding down the [FEED]
key and [PAUSE] key?
Posted on May 18, 2008
Dear Sir, We cannot print out although we install driver again. Would you Pls. help us to repair it. We waiting for your reply.
first install the Driver from www.seagullscientific.com
Then check tha your are sending data (The online led will blink when receiving data) If this is the case check if your are using serial connection the spped (9600,N,8,1)
Check in the driver that you are using ESc LF Null (default) instead of {'} or change the setting n the parameters of the printer
Sep 14, 2011 | Toshiba TEC B-472 Thermal Label Printer
I am not able to print to a local printer TEC 472 on LPT1. I get no error.
The B472 has a contronics SPP mode parallel
Check that you have the correct settings on your computer.
Besides take care the DB25 is a serial connection with
9600,n,8,1 setting by default
Jan 03, 2011 | Toshiba TEC B-472 Thermal Label Printer
Ribbon Error
According to the user's manual this message indicates a problem with the ribbon sensor. As a test, set the unit for thermal direct printing and attempt to print a barcode. You will not see the code if yoiu are expecting thermal transfer, but the paper/label should feed like it is printing. That will indicate that the printer is functioning. At this point, the sensor needs to be replaced.
Hope this helps,
Dan
Apr 22, 2010 | Toshiba TEC B-472 Thermal Label Printer
Will not print
Change the chip on the main board. sometime this chips goes out. It's the only one mounted on a chip support
Mar 29, 2010 | Toshiba TEC B-472 Thermal Label Printer
All ok but not print
2 possibilities.
- The communication parameters are not correct
Try 9600 bds
8 data bits
1 stop bit (defaults)
Or the control character is not correct
See parameters
Jul 21, 2009 | Toshiba TEC B-472 Thermal Label Printer
Tec 472 qq no print
May 18, 2008 | Toshiba TEC B-472 Thermal Label Printer
TEC 472 QP PRINTER
Try with CUPS --- oh, sorry, it's for Linux only, my bad
Jan 08, 2008 | Toshiba TEC B-472 Thermal Label Printer
846 people viewed this question
k24674
jasbo
jasbo
