Question about Carrier XHB123D X/Y Series Heat/Cool Air Conditioner
Carrier package HVAC unit with electric heat (10KW)
I have a heating problem one bank of my heat strips 5KW is not working. I have found the problem, the thermal fuse is open. It is a Microtemp 404204A there is also a number 98C. Where can I find a replacement for this part? Any info would be appreciated.
  • 306 Answers
If you don't mind shopping over the internet here is a company I deal with on a daily bases Call Washer Specialties they have everything. 99% of the time.
http://www.wsconet.com/
Now if you have a appliance parts house in your area I would go there as this part you are talking about is a common part.
Posted on Feb 07, 2009
Wiring schatic to wire a 10 kw heat strip inside of a trane gas furnace
If you are using strip heat as seperate mode you must install a fan isolation relay which would be energized by emergency ht mode of stat.
Nov 25, 2012 | Carrier 38CKC042 Air Conditioner
OD model#, CKL36- 1F and the indoor model#, AR36-1. The indoor does not have the electric heat strip in it but has the place for it. I want to convert it to a heat pump. Is it a 3 ton system? How many KW...
You can use the existing air handler for a heat pump condenser unit up to 3 tons. The line set, evap coil are fine for a heat pump.
The electric heat strip issue can be another problem, you can put several different size strips in depending on what may be needed where you live, the power requirements will differ with each heat strip, for example a 5KW (5000 watt) heat strip requires a 2 pole 30 amp circuit for heat strip and air handler combination.
Aug 22, 2011 | Goodman CKL36AR36 Air Conditioner
HOW DO I WIRE A HEAT STRIP IN MY HEIL CENTRAL AIR CONDITIONER ?
Do you have power to the unit for the new heat strips? what size strips do you have? 10kw-15kw.. ect.
If you had heat strips previously, then i will just need to know the size and application.
Dec 15, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
I have an Intertherm electric furnace an sometimes it won't start but if I shut off the Tstat then turn it back on the furnace runs fine for awhile thought that it was T stat then thought that it was...
Electric strips have what's called a Sequencer also called a stack relay it's a relay that brings on the fan and strips at the same time on a call for heat. If you have more than 5kw you will have more than one Sequencer in fact you will have one for every 5kw.(only the first one will bring on the fan) It could be your high limit making your unit stop heating before it reaches the temp set on the T-stat. Check and see if your getting proper air flow across the electric strips your filter could be dirty. If not remove the cover from your T-stat and take the red and white wires off and twist them together this will bring on the heat then just watch the unit for about an hour if no problems then you have a bad T-stat. If the unit does cut off and the fan seems to be blowing fine you might have a bad high limit switch.
hope this helps........
Nov 18, 2010 | Heating & Cooling
We need wiring for heat strip install on Coleman Package Unit Model PHP036H1321A --- HELP!
Doesn`t this unit already come prewired for electric
heat? It shows 5kw,1okw and 20kw.
Jan 09, 2010 | Heating & Cooling
I have a HVAC unit made by Inter-City Products. I
In general, when more than one heat strip is present, one is used as primary heat, and the second one comes on if the primary does not prevent the temp from falling.
Another set up is, yes there can be a time delay in the system. it usually takes a few minutes for the second set to energize.
Since you did not state if this is a heat pump, i'm limited in my response at this time.
Hope this helps.
Dec 31, 2009 | Heating & Cooling
Compatability of a R22 air handler and a R410a heat pump
1. The units should match up without a problem.
2. You will need a 40 or 50 amp breaker for the A/H and 5 KW heat strip. You will probably need a 20 or 25 Amp for the condensing unit. I would check the FLA (full load amps) rating on both units, total them and install a breaker with no more than 20% more rating than the total. You can install a small box at the A/H with a breaker for the A/H and one for the condensing unit.
Nov 15, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Will conditioner run same amps cold weather
Usually connected to a 30 amp & 40 amp double breaker, if it is a heat pump. 30 for cool, 40 for heat, to turn on 1 or 2 heat strips. heat strips are rated 2 5kw each.
Nov 12, 2009 | Carrier Heating & Cooling
Rheem Heat pump 5 ton heat strip 10KW what
I would say this is around 75 amps of draw at max for both the compressor and heat units. . Therefore--at least 90 amp breaker, and probably 100 amps for good measure, and at least #4 or #2 wire to the unit.
Oct 09, 2009 | Heating & Cooling
Diagram for 10kw heat pack for carrier furnace
I hope this helps
http://www.xpedio.carrier.com/idc/groups/public/documents/techlit/wd-fa4c-01.pdf
Jan 23, 2009 | Carrier 38CKC042 Air Conditioner
Carrier XHB123D X/Y Series Heat/Cool Air Conditioner Logo
342 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
