Question about Metz mecablitz 45 CL-4 TTL Flash
Trying to re-activate a Metz45CL-4 flash gun . Only activity is t
That the TTL light comes on but no sound . what do you suggest.
  • 1 more comment
  • ginorullo Feb 07, 2009
    all 6 batteries are fully charged AA 1.5 v . As stated when switch on post is activated the TTL light comes on but no sound is heard . There does not seem to be anything else happening in the unit.
    Can you give me some more info on these electrolytic capacitators ? Is this unit repairable and is the unit worth the repair charges . Who is capable of repairing this unit if all the answers are positive.
    Can some one answer the second half of my question ?
    President:
  • 2,110 Answers
Possibly.
It's usually a small, seperate transformer, that has a capacitor discharged
through it, and produces a several KV pulse, on a seperate
electrode (usually on the outside of the tube, at one end) to cause the tube
to strike.
If it were me, I'd take apart the lighter I've got next to me, connect two
leads to the pezio device, and after removing the connection to the trigger
transformer, connect it, and see if triggering the lighter would light
the tube.
If so, there is a problem with the trigger transformer.
Posted on Feb 07, 2009
  • Sibananda Jena
    Sibananda Jena Feb 07, 2009
    Possibly.
    to strike.
    the tube.
  • Sibananda Jena
    Possibly.
    to strike.
    the tube.
    President:
  • 2,559 Answers
Don't know if this will help.
  • 129 Answers
The sound comes when the capacitors are discharged with a bang. You may need to look into the capacitors on the unit and check if they are all right..
    Master:
  • 848 Answers
Hi
you have problem with electrolytic capacitors
  • gopinath pasupathy Feb 08, 2009
    the unit is repairable.....but it cant be worth repairing it.... the electrolytic capacitor for your specification is difficult to get ...... this job has to be done by technican ..........
  • 679 Answers
Check battery of Flash Gun.
  • 3 more comments
  • rockfixya
    rockfixya Feb 07, 2009
    follow the below link for more info.>>
    http://www.fixya.com/support/t1226337-me...
    Thanks
  • rockfixya
    Might be the Speaker gone dam. check that first.
  • rockfixya
    is the information is on the link>>
    (copy the link and past ityour browser tab)
  • rockfixya
    Repairs? Unless you are a qualified and well equipped electronics technician, it is best to stay out of the innards of electronic flash equipment. Although the battery voltage is low, it is stepped up to very high voltages (at least 300 to 400 VDC) within the unit. Theses voltages can cause sever burns, nerve damage and even death if you should come in contact with them- and in some units, even after the power is turned off.
    At this point in time,repair of you unit may not be cost effective but if you can't get ti going with the aforementioned test procedures you should check with you local repair facility of the unit's distributor- they MAY have a reasonable repair plan.
  • rockfixya
    yes here is a full def. of Electrolytic capacitor>>
    http://en.wikipedia.org/wiki/Electrolyti...
    Brigadier General:
  • 3,614 Answers
Can you please more specific on this.
  • micromaster
    micromaster Feb 07, 2009
    • Try this- Start off with fresh batteries and install them in the unit.
      Make sure the battery terminals are clean and free of dirt, dust,
      corrosion are residue from leaking old batteries.
    • If they are dirty,
      clean them with denatured alcohol, an ink eraser or an emery board, depending on the amount of dirt or residue.
    • Switch the unit on and listen for the sound- if you don't hear anything, move the batteries around and listen again for the sound- it it is intermittent, clean the battery compartment again and make sure the springs are tensioned up.
Zoom flashing
This will come on if you manually activated it on the back of the flash. It's for the times when you want to manually provide wide or tele coverage.
Jan 17, 2014 | Canon SPEEDLITE 580EX TTL Flash
Canon 420ex makes brief buzz noise but no lights
The buzz noise may be the zoom motor in the flash activating as it starts up. If it encounters resistance it will shut down to protect the motor and flash. It's impossible to tell if something has jammed the zoom motor or path without opening the flash (I suggest you don't). If mounting the flash on your camera, turning both on and resetting your camera to factory default settings through your camera menu settings doesn't reset it you'll probably need to send it in for repair.
Dec 23, 2012 | Canon Speedlite 420EX TTL Flash
Synchronizing two sb-800s with a nikon d300
You knoq the SB-800 has a slave mode called SU-4 in the menu. It activates remote flash. When your on camera flash fires so will the slave flash. The slave flash will need to be able to "see" the light from the on-camrea flash to work.
To access the SU-4 remote mode hold the "SEL" button in for a few seconds until the menu appears. Scroll down to the SU-4 setting and turn it on.
When using this method set the flash to manual and set the power as needed.
Regards.
Apr 13, 2010 | Nikon Speedlight SB-800 TTL Flash
How do I use two sb800 one on the camera and one behind a groups of people to eliminate the shadows on the wall
The SB-800 has a slave mode called SU-4 in the menu. It activates remote flash. When your on camera flash fires so will the slave flash. The slave flash will need to be able to "see" the light from the on-camrea flash to work.
Mar 08, 2010 | Nikon Speedlight SB-800 TTL Flash
My Metz mecablitz 60CT4 has two direct cables connecting the battery to the flash gun. One works fine. But the other one "activates" the flash when I turn onthe battery (the f-stop, ft, and ISO numbers...
I repair these baby.
Only one High Voltage Cable can be use not two. Is your HV Cable or your PC Sync Cord that is defective? Do you have a DVM?
atdlee@netzero.com
Feb 14, 2010 | Metz Mecablitz 60CT4 TTL Flash
Vivitar 3200 Flashgun and Canon EOS 400D
Using Vivitar 3200A flash gun on a DSLR is risky for the following reason. The trigger voltage of a DSLR at flash hot shoe that takes it to its TTL (through the lens) circuit is less than 10 volts, it is about 6 to 8 volts in the recent DSLRs. The trigger voltage generated by Vivitar 3200A at full charge flashing is around 180 volts (max). That is a fatal dose for a sensitive DSLR TTL circuit. This high voltage flash gun will work endlessly, the only damage is to the TTL flash circuit. When you attach a TTL flash to the DSLR after using Vivitar 3200A for sometime, your TTL flash will not communicate with your camera. It will be just another ordinary flash without any auto functions. There is a Wein adapter that you can fix b/w your cameral hot shoe and the vivitar flash gun that is said to reduce the trigger voltage that passes into the camera. Try it if you get it. Without this gadget it is better not to use non recommended and non TTL flashes on latest DSLRs.
Apr 13, 2008 | Cameras
Ttl dedicated flash gun operating instructions
What equipment are you talking about?
Please give as much as possible.
Alexander
atdlee@netzero.com
Dec 17, 2007 | Metz mecablitz 45 CL-4 TTL Flash
What are the flash metering modes?
The DiMAGE A1 employs three metering modes; ADI (Advanced Distance Integration) flash metering, Preflash-TTL metering and Manual. The ADI flash metering mode combines distance information from the autofocusing system with information from a pre-flash exposure. On the other hand, in Preflash -TTL metering mode, the exposure is calculated with a pre-flash only. Flash emission control is manually selectable in three levels from 1/1, 1/4, 1/8, 1/16. Pre-flash TTL metering must be used when a diffuser is attached to an external flash or a filter to the lens. Attachment of those accessories may cause error in distance information necessary for ADI (Advanced Distance Integration) metering due to reduced entering light. While manual output control is active, pre-flash will not burst.
Sep 15, 2005 | Konica Minolta DiMAGE A1 Digital Camera
The ADI flash metering mode combines distance information from the auto focusing system with information from a pre-flash exposure. On the other hand, in Preflash -TTL metering mode, the exposure is calculated with a pre-flash only. Flash emission control is manually selectable in three levels from 1/1, 1/4, and 1/16. Pre-flash TTL metering must be used when a diffuser is attached to an external flash or a filter to the lens. Attachment of those accessories may cause error in distance information necessary for ADI (Advanced Distance Integration) metering due to reduced entering light. While manual output control is active, pre-flash
Sep 15, 2005 | Konica Minolta DiMAGE 7i Digital Camera
Metz mecablitz 45 CL-4 TTL Flash Logo
46 people viewed this question
Top Metz Cameras Experts
bhargav
TimHu
Level 1 Expert
Tony
Are you a Metz Camera Expert? Answer questions, earn points and help others
