Question about Frigidaire 24 in. FDB1050RE Built-in Dishwasher
No water When I start the dishwasher, the display shows 96 and starts to go down but there is never any water entering the machine and "HO" starts blinking. The dishwasher has been running fine up until today.
    Scholar:
  • 93 Answers
First swith the machine and the water supply off and then where the inlet hose is on the back of the machine remove the hose from the machine and look in the plastic part that the hose screws onto there should be a small sieve there this can be pulled out with a pair of long nose pliers clean if dirty and replace ,replace the water inlet pipe make sure it is tight ,switch water and machine on and test.this is the most coman reason for no water try it if you do not come right then drop a comment on this I will pick it up and we can go further.
Posted on Feb 06, 2009
HO 1 code dishwasher will not start
Jenny, I believe the HO 1 (or H: 01) means that the machine is set to delay starting for 1 hour. Continue pressing the "DELAY" button until the readout shows H: 00.
Mar 06, 2016 | Westinghouse SB915
I have a Fisher Paykel 605 double DD. I have an F2 error message. There was a frozen rotor, likely from disuse over the winter. I replaced the rotor and it still stops and shows the F2 display. There
Not sure if you have fixed the F2 problem yet. The rotor cavity may look clean but sometimes there is a piece of bone or seed stuck inside the channel connecting rotor cavity with pump sump. Take the rotor out and the drain filter out. Take a rigid thin wire and run it inside the channel connecting the two.
Also get some white vinegar and with a tooth brush rub it inside the rotor cavity to ensure all dirt is removed. The rotor speed sensing is done by the hall sensor sitting underneath the cavity. It is not visible from top. The sensor could be reading incorrectly. IF still no luck then Run in diagnostic mode - (but make sure you do not try any other function than what is mentioned here otherwise you could damage dishwasher).
DishDrawer Diagnostics can
only be entered in Power Off mode, ie. When there is no display on the LCD or the
badge LED's are off. Diagnostics is entered by holding the
Keylock and Start/Pause buttons simultaneously for 5
seconds. Ensure that
Keylock is pushed first.
All LED's and LCD segments (except keylock) are illuminated. Press Power button and display shows HO in red background. Press Start/ Pause. You are now in hardware diagnostic mode. Open drawer so that you can see inside. Press Start/ Pause a few times until FU shows on display. At this point press Keylock and water should flow in. Press Keylock to turn inlet valve off after water is collected under the wash arm (don't cover wash arm). Press Start/ Pause again and P1 will display. Press Keylock to turn rotor motor on and water will swish around. Press Keylock to turn motor off within a few seconds otherwise flooding could occur. Next press Start/ Pause once so P2 displays. Press Keylock to run rotor again but this time it will pump out. Let it run until the water is pumped out. Press Keylock to stop pump. This should test the rotor in both forward and reverse direction.
PRESS POWER BUTTON ANYTIME TO EXIT DIAGNOSTIC
If the hardware test worked ok then turn mains power to dishwasher off and on and start normal wash cycle. If there is still an F2 problem then hall sensor is faulty and needs replacement. Not easy to do and best left to technicians. By the way each dishdrawer has separate controller - so one drawer could be working fine and the other not.
May 10, 2014 | Fisher and Paykel Dishwashers
Ex500isc displays error 20
Have you tried making sure the water entering the machine is very hot by running the attached faucet Mr. Burns?
We had this happen when we turned our water heater down to it's minimum setting and forgot to run the kitchen faucet (supply was also plumbed to the dishwasher) until fully heated up, then switching on the dishwasher.
Mar 27, 2014 | Electrolux Dishwashers
The display is flashing HO, what does this mean?
I was wondering the same thing. This is what I found:
The display shows "HO" or "Hd." What does this mean?
HO" or "Hd" means the dishwasher's cycle time is being extended while it is heating water. At certain points in the wash cycle, the dishwasher uses hotter water to ensure a clean load of dishes. If it detects that the water is not hot enough, it will heat it.
If you're seeing "HO" or "Hd" frequently, check the temperature of the water available to your dishwasher. It's best to do this at the sink closest to it, allowing the hot water to run until it reaches its maximum temperature before you test it with a thermometer. For best results, water should be not less than 120°F.
Nov 08, 2010 | Amana ADB1600AW Builtin Dishwasher
Leaking water from bottom draw
To put machine into test mode: Press and hold keylock, then press and hold start button. Hold both in until machine beeps (if you have display, it will show all symbols). Press power button- display should now show HO. Press start button until LD shows in display- this tests lid motors. Activate lid motors by pressing keylock button- if you open drawer about 3 inches, you should see lid come down. Pressing keylock again will raise lid. Raise and lower lid several times by pressing keylock button to ensure lid is working properly- if not, lid motors need replacing. Good luck!!
Mar 18, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
AWM8000 AF flashing and machine cut out, very
WHEN I PRESS START - HAS ALARM ON DISPLAY F AND H FLASHING AND TAP OPEN POSTER HAS THE FLASHING LED TOO. HO TO REPAIR IT.
MY NAME XUAN
Sep 29, 2009 | Whirlpool AWM8000 Front Load Washer
"HO" flashes on display during washing.
HO, indicates that the dishwasher is using Hot Water. It is completely normal.
Mar 08, 2009 | Frigidaire Professional Series 24 in....
Motor starts but no water entering dishwasher
TRy priming by putting a jug of water in bottom of inside of dishwasher
Mar 04, 2009 | Westinghouse Dishwashers
I want to know what HO means on a frigidaire dishwasher?
it means the water is trying to heat up and it is taking longer than normal. Check your hot water heater to make sure it is heating properly. Do not use hot water in other areas at same time ..ie: washer, shower, etc. The HO will disappear once the water is heated to the proper level by the dishwasher.
Dec 31, 2008 | Frigidaire Dishwashers
Error "HO"
If your hot water isn’t hot enough it will display “HO” while heating the water to operating temperature.
Thank You Huum
Please remember to leave a solved rating before you sign off!
Dec 20, 2008 | Dishwashers
Frigidaire 24 in. FDB1050RE Built-in Dishwasher Logo
79 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
