Question about Whirlpool AWM5125/1 Front Load Washer
Machine does not wash just fill and drain
Awm 807 machine fills with water does not cut off .clicks to drain almost immediately. no washing done.
    Scholar:
  • 99 Answers
HI my name is joyce , you need to get a service tech to fix problem the machine has got a piece of trash in valve that controls the cut off of the water and its stuck. check the filter in the water line to make sure it is in good shape and has no trash in it, this usually happens when you are on well system with no filter on line.
Posted on Feb 06, 2009
Water drain out immediately while filling the washing machine
you should check 2 things the drain pipe should be higher than the drum or there is some dirt in the thin pipe of the pressure switch try to blow air in it in order to clean it
Feb 10, 2014 | Simpson Esprit 750 Top Load 7.5kg
Washer fills then drains immediately
Motor plug faulty. Remove and check for burnt wires.
Dec 08, 2013 | Zanussi ZWF1430W Front Load Washer
Kitchen sink hole fills up with water when using the washing machein
After washing cycle all the water flows immediately from tub to drain pipe. If the flow capacity of sink is slow sink hole fill up with water .
Connect washing machine drain to proper place for drainage.
Oct 05, 2013 | Washing Machines
My whirlpool washing machine AWM 6085 is unable to **** in the water from the pipe during washing. What can I do?
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Mar 09, 2011 | Whirlpool Washing Machines
I have a Whirlpool 1200 Spin AWM 1201 Washing Machine. There is a funny smell coming from it like suage. Also sometimes there is water on the floor after its use. We have checked the pipe going outside and...
The smell is a build up of bacteria which can be flushed out to help/ The leakage could be a few things a hose , pump or door boot seal ,a small rip in this you need to check further....
Feb 22, 2011 | Whirlpool Washing Machines
Zanussi jet stream iz16s tripping ouy rcd once filled up with
It would seem to me that the heating element needs replacing from the information you have supplied especially as it performs most of the other functions like filling and spin and drain.
Good luck
Mar 17, 2010 | Washing Machines
My kenmore 80 series will not fill to wash - it starts to fill with water and then starts draining immediately??
If the washer drains immediately as it attempts to fill,or if it has problems with maintaining the water level after it does fill, this can commonly be caused by what is known as "siphoning". The following link explains:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
Read through the link provided and let me know if you have any questions. This could be a simple matter of drain hose placement. If this does not correct your problem, please let me know. I hope this helps you.
Oct 12, 2009 | Washing Machines
Washing machine tripping RCD
electrical short in m/c.could be heating element. regards
Jul 30, 2009 | Washing Machines
Soon as i set cycle and swich on door light flashes open
hi,
The cycle doesn't advance
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Thanks for your question.
Jan 03, 2009 | Ariston Technologies AW129NA 16 Lbs Front...
Whirlpool AWM5125/1 Front Load Washer Logo
153 people viewed this question
Dan Webster
Dan Webster
Sal De
