Question about Garmin GPS
I geocache with a friend. I am 40 ft. off east to west. Hers is always right on. Garmin Venture Etrex CX Help !
  • lorinbarwell Feb 08, 2009
    we held them together one on top of the other. Different coordinates.
  • snamelloh Feb 16, 2009
    I have the Same problem. My Lengend CX is consitently 6-10 meters off to the East. My Cache is usually 6-Meter or so to the west of where I am standing even with accuracy of 2m. My Nuvi 250W is more accurate. Must be newer technologies. I have just started putting in mental offsets.
  • 74 Answers
Depends on the number of satellites each GPS is viewing at the time so if you are holding the device your body will be shielding a number of satellites from the device and this may be different depending which direction you are looking in. The other thing is that 10m/40ft is about the best accuracy you can get from a standard GPS. If you want better accuracy you need a surveying GPS with a Differential GPS receiver
Peter
Posted on Feb 08, 2009
  • ontherails Feb 08, 2009
    Both of them are displaying the location within the expected accuracy of the GPS system when using non-survey quality instruments (10m/40ft).
    If you were actually holding one GPS above the other then the lower GPS will not be seeing as many satellites as the upper one due to shielding of the antenna. If they were side by side it would avoid that and make a fairer comparison.
    Is exactly the same data loaded into both GPS units?
    If after eliminating any differences between the units and one unit still shows a poorer performance then it suggests that there is a possible fault with that unit. However, the retailer / manufacturer is unlikely to admit to the unit being faulty if it's showing an error of less than 10m.
    Let me know if you find there is a consistent difference between the units. I have aquired a GPS12, GPS38, Etrex and an eMap over the years but I have never had two units the same to be able to directly compare what the same units will display given the same location and data.
    I' be interested to know what conclusion you come to.
    Peter
Garmin etrex 20 refuses to cooperate.
I am not too smart on the Garmin but I know they have a Tec. phone number that can help. Give it a try.
May 17, 2014 | Garmin eTrex GPS Receiver
Won't acquire satellites
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} make sure you are in view of clear sky, large buildings, trees and even clouds will make it harder to track satellites.
May 19, 2009 | Garmin eTrex Venture Cx GPS Receiver
Problems with Garmin set up
Firstly, have you downloaded the locations of caches to your Vista HCx, either from the garmin website or from Geocaching.com? which are the sites that I would recommend.
If you haven't done so, then you have to do that before you can be guided to the caches. On those websites it asks for the location from where you want to look for caches, then lists suitable caches which you can download to your unit, by connecting the USB cable that was provided with it.
Once you have done this, using the find geocache function will bring up a list of the caches that you have downloaded, listed by their geocaching ID. You can, by pressing the menu buttom on the left hand side, select the option to have the caches listed in order of how close to your location they are. To find a little more detail, select the cache with the rocker switch, and press the switch down, which brings up a screen with a bit more detail of the cache.
Hope this helps.
Mar 29, 2009 | Garmin eTrex Vista HCx Handheld GPS...
Geocaching with Garmin Etrex Legend CX
The preloaded maps are VERY generic, mostly major highways. They are not useful for geocaching.
The good news is that you can download free topo maps created by a very generous Canadian soul, Dale Atkin. The maps are free but donations are accepted. He is also working on US topo maps. I've used Ibycus and Garmin topo maps and prefer the Ibycus version.
If this solves your situation, please come back and rate our answer. Thankyou.
Dec 27, 2008 | Garmin eTrex Legend Cx GPS Receiver
Bab
Maybe you've adjusted the contrast too far?
Sep 22, 2008 | Garmin eTrex Legend GPS Receiver
Black and blue
Setup > Map Setup > Marine (far right icon) > Marine Colours.
If this fixes your problem, please come back and tell us.
Unlocking a Garmin etrex venture cx
The unit comes with a base map. You will need to purchase City Navigator software if you want more detailed maps which will show all roads. If the box contained a copy of the City Navigator and you threw away the code, you'll have to purchase another unlock code from Garmin.
May 22, 2008 | Garmin eTrex Venture Cx GPS Receiver
Not connected
Have you installed the USB drivers for your GPS to your PC? You can download the drivers from the Garmin website.
Mar 16, 2008 | Garmin eTrex Venture Cx GPS Receiver
Won't give me the correct location
you should search for mapdate (kaartdatum in dutch) and select WGS84, it's a preference all geocachers use
Nov 27, 2007 | Garmin eTrex Legend GPS Receiver
GPS Logo
91 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
