Question about Mercury P4VM800M7 Motherboard
System restart i have problem in my motherboard , system is continoulsy restarting when i switch on the system. and i could not format the system, when i using xp id to format setup is not showing to format the system. could u help me out in this case.
    Problem Solver:
  • 7 Answers
This problem can be due 2 overheating...now u hav to do is cleaning the fan of the processor & place it correctly..try using that....r u hearing any type of beep when the system is starting...
Posted on Feb 06, 2009
Hallo, expert. i had a big problem. my pc is restart automatically every time. also i tried a format my hard disc but i m not done bcoz again my pc is restart. so..i tried another way,,, i formated...
ok.your pc is heating that is your processor is heating.......for which it is restarting......ok : you first remove fan attached on the motherboard...then apply the paste you can use your toothpaste and then again install that fan the problam of restarting will definately solve........
Nov 23, 2010 | Intel D101GGC Motherboard
How to restart nokia E63
Hi.
Well, there are codes to soft format your phone and hard format as well.
Many Nokias E63 have been complained to be always restarting by itself and I have come to a conclusion that these phones are defected..
I suggest you to have a backup of your phone book and data so that you can format it.
By formatting your phone, all data will be lost and it will be as freshly new phone from zero.
In order to format you need to do the following:
1 - switch of the phone
2 - when you switch it back on, quickly press the Green(call) button + 3def + *+ at the same time untill it shows formatting on your screen.
After that, you will have your phone reset and clean.
If the above steps fail - dial *#7370#
Good luck
Nov 17, 2010 | Computers & Internet
WHILE FORMATING SYTEM DOES NOT RESTART
prety simple
when it pc starts get in bios and enter into cmos
there set the primary boot divice as your dvd play it should work !
Jan 28, 2010 | Intel D102GGC2 Motherboard
P5PE-VM Restart when software is Run
Does it only happen when you are installing software or running software on the CD drive? If so, then it sounds like your power supply will have to be replaced...as the cd drive is accessed, it drains power from the system and the computer restarts due to the drain on the power supply.
Jun 14, 2009 | ASUS P5PE-VM Motherboard
Computer restarts every time
you better check your restart switch... that might be pressed on....if so unscrew your computer and the cable that passes thorugh the reset button take that out...( you can unplugged) ... for that, you can follow the diagram inside. of the computer...
perhaps it may help your problem....
and to format c drive. you have to install operating system cd and can follow the instructions if your computer's reset button works first...
Apr 23, 2009 | Zoom Wireless-G 4410 (44100000) 802.11g/b
Bios
what were you trying to do
did you recently add new hardware or did you recently format
Jan 16, 2009 | ASUS P5GC-MX/1333 - Motherboard - micro...
Sound problem
Reset ur sound settings in os or reinstall ur audio driver and restart computer when it asking to do it. If even if problem persists format ur os and reinstall ur operating system and install ur audio driver and restart ur problem would be solved
Apr 11, 2008 | Mach Speed P4MBMS Motherboard
Windows booting problem
hi sunnyh, when you start up the PC start pressing the F8 key every 2 seconds. A dos like window will load. At the bottom of the list choose, last known good configuration. (win might load the last good configuration) it's worth the try.
If your PC still does not load windows than repeat the above, this time choose, Disable automatic restart on system failure.
This also might allow windows to load (hopefully).
A system that starts going into this restart loop happens for many different reasons. Most common reason was a program that was last installed just before PC was restarted. Second most common reason for restart loop. Added new hardware, bios changes & windows boot files corrupted. If you did install a program, uninstall it. If you were in your bios & made changes, reset the bios. If you flashed the bios, go back to the old bios version. If you added new hardware replace with older hardware.
To fix Windows you may have to reinstall it. Do not run format or you will loose all your data. Even system restore CD's allow for a win reinstall without a format, however if the cd does not allow you to reinstall win unless you do a format. Than windows startup files are too screwed up & you'll have no choice but to format.
All you can do is try the above & cross your fingers.
Mike
Mar 22, 2008 | Gigabyte GA-8SR533 Motherboard
Pc is not working
as computer starts hold down F8 and youll see a safe mode. use the safe mode and it might just come back, restart it....sometimes strange viruses does this but i dought in your case.it should come up in safe mode allowing you to save your files ...folders to cd record disks...then you can format and reinstall all programs.
Sep 01, 2007 | ASUS P4BGL-MX 845GL (AS04P4BGL-MX)...
Mercury P4VM800M7 Motherboard Logo
56 people viewed this question
Top Mercury Computers & Internet Experts
Mark Gough
Abhinandan  Patil
Abhinandan Patil
Alun Cox
Are you a Mercury Computer and Internet Expert? Answer questions, earn points and help others
