Question about Toshiba e-Studio 161 Copier Copier
Developer leakage while copying
I have replaced the New Drum & Developer, after taking around 50 copiers the developer comes out along with copies and developer spillage in paper feeding section. I have same problum in 4 machines after replacing Drum & Developer (genune). Is it any programe needs to be done after changing the consumables(developer). or any other suggestion. please help me guys.
  • AGUBOSIM CHINEDU
    AGUBOSIM CHINEDU Mar 11, 2014
    this was a little helpful
  • AGUBOSIM CHINEDU
    the problem was from the magnetic roller. I adjusted it and It started working.
After replacing wit new developer switch on machine holding 0and 5 then 200start wait for 4 min and switch off and on machine your copy must be fine if you meant copy back ground by telling leaking!!!!!
Posted on Sep 14, 2013
    New Friend:
  • 16 Answers
1. Check the spiral beneath the mag roller. The spiral is not a single piece. there is a joint in the edge (a lock). this may be worn out. You need to remove the mag roller to check this.
2. Check the grid of the main charger. Replace the main charger if required.
Posted on Nov 28, 2012
    Problem Solver:
  • 5 Answers
After replace  developer you dont turn round the developer wheel left side. only right side.try this take out the developer and after re fill in to the developer unit. and u change the main charger unit also.
Posted on Mar 22, 2009
When want a copy ,it says ready to copy but won't. ?
Sir/Mam,
Have you had the developer and drum replaced recently, or does the screen say Replace PC Drum? There are certain house chores the copier does before "Ready to Copy" it is waiting for them to get done, so that equals "Please Wait". One big item is making sure the developer and toner are properly mixed inside the image unit underneath the drum or next to it depending on the series. Might want to have the developer replaced and drum/cleaning blade normally done all together, then run the F8 procedure/Developer Charge, and make sure the counters where cleared. Did you recently replace the drum and the developer if so did you clear the counters for the drum and developer, FIRST? IF not then the copier thinks the new drum and new developer are old. The copier works on the counters that is how it knows it got a new drum and developer. Get new developer and a new drum and have it installed correctly. Counters are clear before the unit is yanked out of the machine, then you remove the image unit/drum unit replace the developer/drum and cleaning blade. (DO NOT USE A VACUUM CLEANER WHEN REPLACING THE DEVELOPER static electricity can destroy the sensor located below the developer unit. Then reinstall and RUN F8/Developer Charge. Make sure the fax line and Ethernet cable is removed can't print anything until the F8 is run. Or you will start all over again with new developer and a new drum.
Apr 30, 2016 | Konica Minolta Bizhub C350 Digital Copier,...
My machine don'y copy, I receive message:Now warning up. Ready to scan
Sir/Mam,
Feb 26, 2016 | Konica Minolta bizhub 750
PROCEDURE CHANGE DEVELOPER KONICA BIZHUB 600
First clear the developer counter in service mode.
then remove the drum cart. remove developing unit. remove old developer. then run Auto max density. If you don't and make a copy or print you will have to replace the developer again
. recommend cleaning all toner around the drum and drum sensors requires removing drum be careful a nick on the drum will show up on all copies/prints
Apr 24, 2014 | Konica Minolta Developer 02xk Dv710 for...
How to repair konica 7040 copying in progress always
Have you had the developer and drum replaced or does the screen say Replace PC Drum? There are certain house chores the copier does before "Ready to Copy" it is waiting for them to get done, so that equals "Please Wait". One big item is making sure the developer and toner are properly mixed inside the image unit underneath the drum. Might want to have the developer replaced and drum/cleaning blade normally done all together, then run the required procedures and make sure the counters where cleared. Did you recently replace the drum and the developer if so did you clear the counters for the drum and developer, FIRST? IF not then the copier thinks the new drum and new developer are old. The copier works on the counters that is how it knows it got a new drum and developer. Get new developer and a new drum and have it installed correctly. Counters are clear before the unit is yanked out of the machine, then you remove the image unit/drum unit replace the developer/drum and cleaning blade. (DO NOT USE A VACUUM CLEANER WHEN REPLACING THE DEVELOPER static electricity can destroy the sensor located below the developer unit. Then reinstall and RUN F8. Make sure the fax line and Ethernet cable is removed can't print anything until the procedures is run. Or you will start all over again with new developer and a new drum.
Apr 07, 2014 | Konica Minolta Office Equipment & Supplies
Bizhub 350 printing blank copy
Does you machine say replace PC drum on the control panel if so need to have the drum developer replaced at the same time. The code is dealing with the image unit the drum is one part the developer section is the bottom part or the sensor at the bottom of the image unit is bad. If developer was replaced did that person use a vacuum clean if so then the static electricity from the vacuum clean destroyed the sensor. NEVER USE A VACUUM to remove old toner. Worse case the main board that the sensor feeds is bad. Also when (if the drum and developer where replace did that person clear the counter for developer and drum. Machine works on info from counters to set certain voltages on certain assy. If the counters are not cleared then the copier thinks there is old developer and old drum in the machine and sets voltages for those units when in reality there are new drum and developer . Also after the developer was replaced was the required F8 run. And no prints/fax or copies where made before the f8 was run. When replacing the developer and drum the fax line and the Ethernet cable need to be removed first even used F8 and counters are done in service mode.
Mar 05, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
How do I change the drum on a bizhub 3510
First ensure fax line and and network cable is disconnected (If no FAX or network dont worry) dont want any print jobs or faxs arriving before you run Developer and drum checks after replaceing both.. Second go to the service mode and clear the drum and developer counters touch end then power off the using main power switch left hand side rear. You will be replacing both do not just replace the drum. Ensure your drum comes with what is called a drum cleaning blade, along with your developer. Secondly open the right side door and remove the Image unit. Dissamabley the image unit four silver screws two per side. Then pull each side apart from the base and lift up. T change developer remove the 3 alummin screws fro the base top. Then dump the old developer DO NOT USE A VACUUM CLEANER THE STATIC ELECTRICITY WILL DESTROY THE SENSOR AT THE BOTTOM OF THE DEVELOPER UNIT!!!!!!!!!! Turn the gears on the side so that large roller that runs along th\e front of the developer unit turns downward. keep turing it unit all of the old developer is out. DO NOT USE WATER OR WET RAGS to cleanup use a brush. Add your new developer. One Bag only. Reassamable. Now for the Drum. Remove both side covers one side has small plasitic been so be careful. Reove drum remove three screws to remove old cleaning blade this section you can use a vacuum clean turn the gears to get the hold section clean. install the new cleaning blade and drum DO NOT TOUCH THE DRUM use only the side gears. Replace the SCTRON Grid and Charge Corona UNIT. REassaembly Image Unit.Then POwer up the machine, Enter service mode and run Fuction F8. Do not may copies or prints before this or you will have to buy new developer again.
IF YOU REALLY WANT TO DO THIS?????? HAVE SERVICE TECH COME OUT AND DO THIS
Jan 17, 2014 | Minolta Di3510f Bizhub Copier
How to replace drum
Enter service mode and clear counter for drum, then power off the machine remove drum cart. then remove drum and replace with new one recommended that developer also be replace at the same time clear that counter first along with drum counter. once drum and developer replaced run F8 in service mode before making any copies or prints or will have to do it all over again.
Jan 12, 2014 | Minolta bizhub 250 Black and White Copier
My bizhub 600 is showing message warming up ready for next copy
Sir/Mam,
Mar 31, 2012 | Konica Minolta Bizhub 600 750 Image...
The developer box does'nt keeps toner in it, is it probably because of already 'old developer' or do i need to add some developer...how much is developer? Mine is toshiba e45. Thanks a lot.
Hi
The developer life span is about 150.000 copies, then it should be replaced.
If the developer has not done 150.000 copies then there could be another problem.
The cost of the developer is about R1000.00. {in South Africa}
Please remember that the life span of the drum and drum cleaning blade is also 150.00 copies, so the developer, drum and cleaning blade should be replaced at the same time.
Regards
Apr 12, 2011 | Toshiba e-Studio 45 Black and White Copier
Light Copies Canon imageCLASS D320
hi im jules_09,check the developer,if its past over 60,000 copies if its over 60,000 copies you need to change the developer along with the opc drum and cleaning blade or roller,all copiers need to be replaced with new developer,opc drum and cleanign blade or roller when it reach its copy life,that may be the cause of light copy of print
Nov 21, 2007 | Canon imageCLASS D320 Digital Copier
Toshiba e-Studio 161 Copier Copier Logo
419 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
