Question about Makita Drills
Hammer switch jammed on Makita HP1621K/2 Percussion Drill 2
Hi, I've had this Makita Percussion Drill for 1 1/2 years. A few days ago, after a fairly long drilling session to put some shelves up, the hammer/percussion switch on top of the machine jammed: I can no longer move it from the ''hammer'' to the ''drill'' position. I opened the machine but can't see any obvious damage - it just looks like the ball bearing that would normally swivel round into the hole where the drill head sits (and so pushes the head away from the cogwheels that cause the hammer action) no longer fits through.
  • 2,176 Answers
I looked at Makitausa.com website and it appears that you might be correct. there are 4 parts to this assembly and one of the problems might be the cam holder position #17. I would suggest that you go to their site and take a look at how the parts are supposed to be. I used the model number in the large header so this might not be the exact one that you have. Let me know and I will try and help further.
Posted on Feb 06, 2009
Makita battery wont keep charge
Given the problems with Makita Li-ion batteries there are 2 likely reasons, you have a faulty charger or both batteries are faulty, the best option is to find another charger to try your batteries on and see if they charge, depending on the age of the drill you may be able to get the batteries or charger replaced by Makita, a lot of them have been replaced out of the warranty period because they are known to fail prematurely, take the faulty item back to the place of purchase with you invoice and put the pressure on for replacement
May 03, 2014 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Charger hy66-30 Makita drill
Is that with the 24v batteries? Where would you be? I'm in Australia, and Makita doesn't sell anything with 24v batteries here. however there seems to be a few going on the UK ebay site. I hope that helps.
Jan 14, 2014 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Makita battery won,t charge
Return it to the place of purchase if under a year or send it to Makita UK in Milton Keynes
Dec 27, 2012 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Can the Makita BL 1830 Battery be restored to use after it has died?
You can try to put it in the freezer for 24 hours. When you remove it let it set at room temperature for at least a day before you try to recharge it. I don't understand why this works but I had someone reccomend this to me many years ago on my cell phone battery and it worked . I hope this helps you. Thanks
Nov 21, 2010 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
My Makita battery charger does not work it is a model DC1414 purchased about 5 years ago
The battery could be bad after 5 years. Check the contacts on the charger with it plugged up using a volt meter to see if it's putting out.
Jul 20, 2010 | Makita 12 Volt Cordless Drill/Driver Kit
Hi i broke the chuck on my 1/2 makita cordless
Put the biggest hex key you have in the chuck and tighten it then hit it clockwise with the spindle lock engaged a couple of times. The screw in the chuck will then undo clockwise and the chuck can be undone after by putting the allen key back in and unscrewing it anti-clockwise maybe with a light tap from a mallet.
Hope this helps
Jon
Jul 01, 2010 | Makita 6349DWDE 18-Volt Ni-MH 1/2-Inch...
My Makita 3.0ah cordless drill does not drive anything when I put pressure on it. Would the clutch be worn and if so is it easy to repair?
Clutch is part of the transmission assy - yes it is about the only thing that it can be causing your issue. It is a fairly inexpensive and easy fix on Makita - the worst part is removing the chuck.
Jun 25, 2010 | Makita 18V 1/2"CRDLS Drill Kit
Burnt Out Drill?
hi , the bad news is you have almost certainley damged the motor and may have damaged the switch ( it is also the speed controller ) , the good news is because its a Makita then you will have little trouble in getting spares for it , if you repost the actual model and what country your in and ask for a spares diagram/parts list i will help further
Jan 10, 2010 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Drills Logo
133 people viewed this question
Top Makita Drills Experts
John Trevino
EugenesDIYDen
EugenesDIYDen
Mike
Are you a Makita Drill Expert? Answer questions, earn points and help others
