Question about Konica Minolta magicolor 2400 Laser Printer
Thin black plastic belt for 2400W
Hello, I have a question about a part that I don't know the name of. It's basically the thin black plastic belt that you see when you open the lid. it's attached to the lid. It's behing the instructions on how to load an envelope. It's about the width of a sheet of paper, and spins around two rollers. Anyway, my son got to it and messed it up. Can it be replaced. Where can I find the part? and what is it called? Thank you
  • 210 Answers
It is called transfer belt or transfer kit, you can find it on any KM dealee but I have to warn you it's not cheap.
Posted on Sep 03, 2009
Konica minolta magicolor 2400w service call 16h
Transfer belt fault! Has it been replaced I? Installed correctly? Its the large belt inside the machine
Mar 17, 2013 | Minolta magicolor 2400W Laser Printer
This was my exact problem. When scanning from the ADF, I had a vertical black line down every page. I cleaned the larger glass surface several times with no effect. Then, I discovered that ADF scans do NOT use the large glass area, but use the smaller, thinner glass area on the left side. It has a piece of thin plastic over the top of the glass. The scanner is fixed and the paper rolls through this area. So, if a speck of dirt is under the thin plastic piece or on top of the glass or on top of the thin plastic, it results in a black line down the whole page. Aha, so now I cleaned the thin plastic (both sides) and the top of the glass under the thin plastic - actually saw the black dot that was causing the problem and voila, problem solved.
Jan 30, 2012 | Epson Office Equipment & Supplies
Error 5100
solution 1:
  • Look inside for a tiny object like a piece of paper, a staple...
Solution 2:
  • The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough . Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
Solution 3:
  • Clean the timing strip: there is a thin plastic strip running across the width in front of and below the drive belt: there are fine black vertical lines on this strip. If the strip gets a piece of crud on it, you get an error during the start-up sequence.Gently clean this strip with a damp lint-free tissue.
Dec 07, 2011 | Canon Office Equipment & Supplies
New canon mf4350d multi-function copier has a small plastic stick-like part located in the lower right front corner of the paper tray. This part is illustrated in various places in the owner's manual....
I must admit that I don't know on what plastic part do You mean, but I can send You the part's catalog, inside you will find all parts # and descripton.
Leave the e-mail.
Aug 26, 2011 | Canon MF6530 Black and White Copier
The stop button on my record player doesn't stop the record from spinning and the needle arm won't play through an entire record
hey there Jack, I have the exact same turntable and had the exact same problem. It's a pretty simple fix.
The control arm for the stop button,more then likely, got pushed a bit too far back.
Now bare with me, because I don't know the names of the mechanisms, but I'll try to make it sound simple.
First you're going to take off plate and belt, because you're going to be taking off the bottom cover of your turntable. If you don't remove the plate & belt, when you flip over the turntable, it's all going to fall and you could damage your belt.
Next your going to flip over the turntable and remove the screws that are holding on the bottom cover on. I think there are 5 of them.
Now that the cover is off, look at where the play and stop buttons are. Follow the thin metal arms that are connected to them. They should end at a white plastic piece (sorry, I don't know the name of it). Now check if the stop arm is hooked behind it or if it's pressed against the front of it. The stop arm should be RESTING ON THE FRONT of the white plastic piece.
If it's hooked behind the plastic piece, carefully pull it out and then place it against the front of the white plastic piece and you should be good to go.
Jan 13, 2011 | Audio Technica AudioTechnica ATLP60USB...
How to print black and white only on Konica-Minolta 2400W
Are using OEM cartridges? What about the transfer belt and transfer roller have they been replaced>
Dec 26, 2009 | Konica Color Stationary Workgroup Laser...
The ERROR light of my Minolta magicolor 2400W Laser Printer stays on. I have inserted a new drum and all the cartridges are full. What do I do?
Try to open the blue cover and close it. Then press a few times the "rotate toner" button. After that powerswitch off and on, should run.
If it´s don´t worked, make sure you have every transport secure away from the cartridges.
The contact`s should be clean in Printer and on cartridges.
If still the same prob, start from first tip.
It´s worked by my 2400W feed new toner.
Nov 25, 2009 | Minolta magicolor 2400W Laser Printer
Magicolor 2400w prints page and then says jammed
It`s possible you`re using too heavy paper, same problem´s with thin sheet´s?
Oct 03, 2009 | Minolta magicolor 2400W Laser Printer
Body part
hello my name is coman the front bumper that goes side to side and protecs the belt area and other areas from splash up from road debris is called a shild and it depends in wich area is it under the motor or betwen the belts and the well belt protector( shield ) thank you .
Sep 08, 2008 | 1998 Ford Escort
Konica Minolta magicolor 2400 Laser Printer Logo
98 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
