Question about Sony BM-147 Desktop Cassette Transcriber / Recorder
Problem with playback using foot pedal
When i press play on the foot pedal sometimes nothig happens. I have to push it several times before the transcriber will play. Seems to be a short in the connection between the transcriber and foot pedal. Can this be fixed?
  • 207 Answers
You probably have a broken pedal here is one in a great price
http://www.tvps.com/Products/ECS-Sony-IN-75-Heavy-Duty-Foot-Pedal---Pre-Owned__ECS-PIN-75.aspx
Or if you feel better to send unit to service try this.
Send an email to service@tvps.com or call (800) 644-9525. Please indicate model, serial and detailed description of problem
Posted on Dec 18, 2009
My 2005 gmc envoy is vibrating only when my foot is on brake or when I stop
If you are not a heavy footed braker... then you have an ABS module problem. There are several sites on line that will do an exchange for a rebuilt one for around $100. If you are a heavy footed braker, your car is behaving normally, Just don't press so aggressively and the vibration won't happen. ABS brakes are supposed to shudder and vibrate when activated, they apply pressure to your brake calipers at roughly 15,000 times a sec, off and on to prevent the brakes from locking up and the car loosing control. In a panic stop, press a car with ABS brakes ALL THE WAY TO THE FLOOR as hard as you can, use the steering wheel for leverage and push the pedal down a bit more, RIGHT BEFORE IT COMES TO A COMPLETE STOP.
Mar 12, 2015 | GMC Cars & Trucks
How do you know that a brake booster is bad?
Booster problems are rare but they do go bad sometimes.
A bad booster generally causes the brake pedal to feel hard to push down, and a lot of pressure on the brake pedal is required to make the car stop.
Rarely, a vacuum brake booster will develop a vacuum leak, which can cause engine performance problems, hissing or whistling noise, as well as requiring increased pressure on the brake pedal to stop.
The first test:
With the vehicle parked, turned OFF, and the parking brake set, pump the brake pedal 5 to 6 times. If the pedal gets harder to push after several times, your booster is probably good.
The second test (To make sure):
After the test above, without making any changes, press and hold the brake pedal with light to moderate pressure.
Now with your foot still on the brake pedal, start the vehicle.
If the booster is good, you will feel the pedal go down when the engine starts.
Hope this helps!
Jun 21, 2014 | 1993 Cadillac DeVille
Nothing happens when I push the foot pedal
Please check the Stitch regulator & Presser foot lifter.
Jan 03, 2014 | Singer 7442 Mechanical Sewing Machine
Foot pedal not working
Well, you are definitely getting power from the electric plug in.
Let's do some diagnostic work. Do you hear anything when you press the foot pedal? Any hum? Did you happen to leave it in bobbin winding mode?
your machine doesn't have a "sew" button for use without the pedal. So please rotate the hand wheel toward you as you press the pedal. Did the motor take over and sew?
If you know someone with a meter... have them test the pedal. (they will place probes on/in the part that plugs in which tests for shorts, etc.) If that tests ok... then we know it's something more than the pedal and it will need servicing by a Singer Tech.
Aug 27, 2012 | SINGER 7470 Sewing Machine
I've recently purchased a Roland foot pedal for my casio privia px-300 keyboard. When playing a note, even though the pedal is not pressed, the note sustains. When I press the foot pedal down, it cuts...
Sorry, but Roland uses the opposite sense switch. They use normally closed where Casio requires normally open contacts. SOMETIMES one can rewire the pedal internally, but you have to be mechanically and electrically inclined to do that.
Jun 04, 2011 | Casio Privia Keyboard Case
Sanyo TRC-8080 transcriber only When using the
Hello your unit may have a desolder autobackspace slide control or maybe your pedal is going bad here is a link for your pedal replacement http://www.tvps.com/Products/Sanyo-FS-56-Transcription-Foot-Pedal---Pre-Owned---FS56__SA-P-FS-56.aspx or send your unit to service at Send an email to service@tvps.com or call (800) 644-9525. Please indicate model, serial and detailed description of problem
Mar 04, 2010 | Sanyo TRC-8080 Desktop Cassette Voice...
There is a constant loud hum/buzz whenever I turn the pedal on. With my Boss Mt 2 Metal Zone effects pedal. It happens whether or not the power supply is plugged in. Ive tried switching cables and...
First and foremost , check your signal chain. By that, i mean put the pedal aside, ...just unhook it and take it out of your signal path. Using the same cables , guitar , amp, other pedals - borrow a friends MT-2 if you can get one , and try THAT to see if THAT works , OR any other kind of distortion pedal. If another one works ok , it's YOUR MT-2. Boss pedals are pretty rugged , but sometimes the little actuator (on/off switch) underneath the treadle (where you push your foot down) will become faulty. That's a high-gain pedal - are you using a basic Strat or other single-coil pickup guitar? If so , are you playing close to any flourescent lights? SIngle coils are noisy around those lights. Will cause a hum / buzz if using a heavy dist. pedal. You can check that by moving around as you play.
Nov 02, 2009 | Boss Mt 2 Metal Zone Effects Pedal
Toyota corolla 98 1.6L unleaded does not start
the alternator ground must be loose... try tracing the both negative and positive... tighten the connection... if problem persists try replacing the alternator
Jul 19, 2009 | 1998 Toyota Corolla
I have a 720. Sometimes when I press play it will rewind.
Hello I can read your full problem but when it hapen unplug your foot pedal to see if the pedal is causing the problem here is a link for a original foot control replacement http://www.tvps.com/Products/Philips-LFH-0210-Foot-Pedal---New__PH-LFH-0210.aspx or just send your unit for service at Send an email to service@tvps.com or call (800) 644-9525. Please indicate model, serial and detailed description of problem
Jun 15, 2009 | Philips Desktop 720-T Desktop Cassette...
Foot pedal FF or Rewinds when pressing Play
It's possible that there's a broken wire in the cable that connects the foot control to the machine. This usually happens near the plug that plugs into the machine, or by the end that goes into the foot control.
You can usually duplicate it if you put the auto-backspace up a bit and then hold down the play pedal on the foot control. While holding down the play pedal, try moving the cable near the machine or near the foot control in a circular motion. If the machine stops, rewinds or fast forwards, then odds are that the problem is with the cable.
Mar 13, 2009 | Dictaphone 3750 Desktop Cassette...
Sony BM-147 Desktop Cassette Transcriber / Recorder Logo
178 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
