Question about GE Coffee Makers & Espresso Machines
Burn plastic smell
I was making coffee one morning and started to smell burning plastic so i shut it off. the next day i went to make coffee and poured the water in and it started to pour out the bottom.
    Genius:
  • 1,036 Answers
This sounds like - as you say - something has overheated and melted a feed tube or a seal - or worse - part of the casing.
You really need to take it apart to find the problem - which luckily for you will be easy to spot. Once UNPLUGGED - apart and you can't see a problem - top up with water again.
After you've found the problem - Contact the manufacturer directly. If it could have caused a fire - GIVE THEM H£LL !
With any luck - you should be able to negotiate - a replacement part - or a replacement unit - or a full refund.
I do not like any equipment that overheats in use. Water leakage internally could have led to ELECTROCUTION / FIRE.
Be polite and concise on the 'phone. State what you want from them - and don't get fobbed off.
You will likely have to return the unit - so use recorded delivery for this - or they may "lose" it.
Best of luck with that.
(If you feel this is sound advice - please rate as "Fixya" as it is my time I give you for free. Thank you. )
Posted on Feb 06, 2009
Burning plastic smell when cold out run heater and fan inside car and out
Are you loosing radiator fluid. sometimes the heater core will rupture and you will smell burn odor. also check for strange rubbing sounds or screeching coming from the blower fan motor. or engine exhaust manifolds are hot when car is on, make sure nothing is leaning on them which will cause a burn odor. Any odor coming from outside will find it's way inside through the fresh air vents.
Feb 13, 2016 | Cars & Trucks
Refrigerator control panel failure, causing dispenser to run for hours, filling refrigerator with burned plastic smell
I have a artic and it has a motherboard in it. This is the most common problem.They are easy to replace and you can get one on the internet pretty cheap.First look at the mobo for any burnt spots on it. If so then get the # off the board and search for it.
Mar 16, 2014 | GE Refrigerators
Key stuck in starting position, ow wont start
You may have burnt the starter up. They will burn out if run excessively. If the switch continues to act up and get stuck, you will need to check that out. Might need a new switch. I had a similar problem in a Honda, drove 15 miles with the starter still engaged-it really fried it.
Dec 12, 2013 | Kia Cars & Trucks
Low humming noise and burnt plastic smell coming from 1990 acura integra
Jennifer what type of timing belt does your engine use ?
Is it Nylon ? When was the last time you had it changed ?
Burning plastic smell may be being caused by the timing belt bearing runners seizing and the belt is getting hot .
If the belt is due to snap you could cause a lot of damage to the engine if it breaks.
Might be worth getting a mechanics advice on this as a possible cause
Mar 04, 2017 | 1990 Acura Integra
I have an LG DLE5932W. I've been trouble shooting the dryer the past couple of days. It is making a loud vibrating noise that seems to be coming the element side of the dryer. Today I turned it on, went...
A vibration tells me it may be the idler pulley(s). If the pulley seizes, the belt will burn and break. If it smelled like burning rubber, then thats what happened
Feb 02, 2011 | Dryers
The unit works as of right now...but there is a smell of something burning
Quite often, if you smell like a plastic burning smell, one of the capacitors is faulty, and should be checked immediately. Quite often the compressor start capacitor, will get hot and start to melt. Have it checked by qualified technician or electrician, as they are dangerous and can give a fatal shock if not experienced with handling them, even when power is shut off. $20-$30 part, and 1/2hr. labor should take care of it. The cover on roof unit, has to be removed to access the capacitors, so watch for bees, wasps, when you do so. Make sure power is off at breaker panel.
Aug 01, 2010 | Coleman Heating & Cooling
Brand new portable air con- burn smell
Two units, same plug, burning smell ... hire an electrician to check your wiring
Jul 19, 2010 | Sharp CV-P09FX Air Conditioner
Saeco Vienna Deluxe odd burning smell
gears are probably broke. Happens when to much coffee and coffee ground too fine get compacted into the brew drive unit.
Shreds the plastic gears like butter.
Machine has to be sent out for service, gear replacement is long and impossible for anyone untrained. Trained techs it takes at least an hour if not more.
Apr 21, 2008 | Saeco Vienna De Luxe Espresso Machine
Notebook smells like burning plastic.
cud be your onboard voltage regulator for the battery charging. if you remove the battery and use the external power source does it smell also?
if the battery charges normal out of the unit, and the laptop works well with the AC power unit without the battery, then it's your voltage regulator for the batt charging
Mar 17, 2008 | Computers & Internet
Coffee Makers & Espresso Machines Logo
196 people viewed this question
Top GE Coffee Makers & Espresso Machines Experts
Joseph Hoffmann
Eric Taylor
Are you a GE Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
