Question about TimeValue Software TValue 4.0 for PC
Tvalue 4 for windows will not print with a new printer
TValue 4 for window was working fine with my old printer (a laser jet) but I recently got a new printer (HP Laser Jet P2055dn) and now when I try to print the amortization schedule and error comes up and shuts the program down. Help!
  • Anonymous Apr 19, 2009
    I have the same problem with my new HP 6988 deskjet. The work around did the trick. Has anyone contacted tech support from TimeValue software?
    Dean
This is a work around as I have the same problem. If I change the default printer to something other then the HP printer, then select Page Setup, I can then select the HP without the program erroring out. You can even set the HP back to default and TValue will continue to work fine until you restart the computer.
Posted on Mar 12, 2009
TValue 4 is a 16 bit application which was last updated in 1997. By using a new printer you are mixing old and new technology and therin compatibility becomes an issue.
The only work around is to return to your old printer, or purchase the new version of TValue which is compatible with newer OS like Windows 7.
Posted on Oct 20, 2010
I was able to get around this buy setting up a driver definition for a LJ P4015 using driver for LJ 4000 and pointing the the IP for the LJ P4015. Apparently the LJ 4000 is 16 bit.
Posted on Oct 19, 2011
HP Laser Jet 4250, print getting very light in last few months or year. 135K page count, 6 years old, 600 DPI, PCL 5 - Windows Vista HP Cartridge, or compatible cartridge no difference - still light No...
The laser mirror could be dirty, the transfer roller could need changing. Looking at the "print quality" sub menu, the toner density default setting is 3. Up it to 4 or 5. See if that makes a difference. Remove the cartridge and open the covers. Use canned air or an air compressor and blow out the printer.
Sep 01, 2011 | HP Office Equipment & Supplies
All of a sudden my D680 will not print from print command or quick print. IT works on my secondary Canon MP970 printer. I unplugged printer, rebooted computer moved the USB cable from the Canon printer...
Have you recently changed/upgraded you operating system, e.g. XP to Vista or Windows 7? If so, you snould go to canonusa.com and get the drivers for the new operating system. Even if you have not, I suggest at least downloading and reinstalling the driver from there instead of from the 8 year old disc. Other than this, you should call support at Canon and ask them how to do a "cold reset" or "restore factoy settings" on the printer.
Apr 24, 2010 | Canon imageCLASS D680 Laser Printer
I can't print out with my 1160 and computer
Always try downloading the appropriate driver first, but if it just doesn't work you can always use the postscript version of the HP Laser-jet 4 driver in the Windows driver list and still get most functionality under Vista on almost all HP laser printers.
Mar 02, 2010 | HP LaserJet 1160 Printer
Will not instal on vista
Check out this site:
http://support.microsoft.com/kb/929427
Confirm that you have updated, and check any of the manual updates.
Unfortunately Vista does have alot of updates marked "manual" which are very important.
The site also explains how to run the program, once installed, in compatibility mode, which will be required.
Don't get discouraged, many of us have to fight with these issues do to Vista's infancy.
Let us know
Good Luck
Apr 15, 2009 | TimeValue Software TValue 4.0 for PC
Unable to install DP G 301 For laser jet 5 printer
0.Follow the manual instructions to configure the Printer Server (tpc/ip), connection toyour local wireless LAN, etc. then, specific for Vista: 1.Vista Start Button 2.Control Panel 3.Printer 4.Add New Printer 5.Select Local Printer 6.Click on "Create new Local Port" and from the menu "Standard TCP/IP Port" 7.Click on "Next" button 8.Menu "Type" select TCP/IP and write the IP address of your Printer Server. UNSELECT "detect printer to..." then press "Next" button 9.If everithing is fine, it must find your printer server. 10.Select your driver ... that's it .... unfortunately I found some problems printing documents: it works till half page then the printer stop and I must cancel manually from the printer the job in order to reset the printer itself.... looking for solutions
Mar 16, 2009 | D-Link Computers & Internet
Cannot print from new CPU to new printer.
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 03, 2009 | Office Equipment & Supplies
Laser Jet 4 plus can't print with USB?
1.check the cable compatibility
2.install the driver HP laser jetIII
Sep 05, 2008 | HP LaserJet 4 plus Printer
Happy Laser Jet 4
Hi there you could try the following see if this helps.
  • Click Start
  • Select Printers and Faxes
  • Right hand click on the printer Icon
  • Select Properties
  • Select Advanced located at the top of the window
  • Select Print Processor
  • On Right side of window select Raw [FF auto]
  • Exit all open windows then test
If the same problem repeat above and select different graphic mode. Hope this works for you
Thanks J
Jan 07, 2008 | HP LaserJet 4 plus Printer
TimeValue Software TValue 4.0 for PC Logo
2,264 people viewed this question
Top TimeValue Software Computers & Internet Experts
David Payne
David Payne
Are you a TimeValue Software Computer and Internet Expert? Answer questions, earn points and help others
