Question about Samsung Tocco F480 - Pay Monthly Cellular Phone
Unable to turn keypad sound off
That annoying multi tone sound that chimes with every key I touch is driving me mad.......and means everyone knows when I am sending a txt.
  • 1 more comment
  • Anonymous Feb 17, 2009
    Is there anyway that you can just turn the Keypad sounds off though? The noise is annoying when you're trying to text, ect. But i still wanna hear my phone when it rings! x
  • Anonymous Feb 26, 2009
    surely you should be able to switch it off completely...if you turn down volume, then youve gotta remember 2 turn it bak on 2 hear the phone ? i just want 2 turn mine off...its driving me mad and everyone else
  • Anonymous Mar 03, 2009
    That doesn't work!!!
You can turn the volume down or off completely. Use the up/down volume control button at the side of the phone when you are on the home page.
Posted on Feb 11, 2009
7 dings and a beep when starting 2000 ford explorer? what does that mean
NOTE: The generic electronic module/central timer module (GEM/CTM) is connected to the ISO link and is diagnosed through the data link connector (DLC) with a scan tool.
There are five warning chimes and lamps the GEM/CTM controls: headlamps operating without the ignition on (chime only), door ajar (chime and lamp), key-in-ignition (chime only), driver seat belt warning (chime and lamp), and message center.
Audible Warnings Warning Condition Lamp Duration Audible Duration Audible Output Safety Belt 60 Seconds 6 Seconds Chime, 60/Min. 740 Hz Key In Ignition - Continuous Chime, 120/Min. 740 Hz Headlamps On - Continuous Chime, 240/Min. 740 Hz Door Ajar Continuous 1 Second Single Tone, 1000 Hz Message Center (Tone Request) - 1 Second Single Tone, 1000 Hz
When the is turned to RUN or START from OFF or ACC, the chime will sound for six seconds or until the safety belt is buckled.
The will turn on for 60 seconds or until the driver safety belt is fastened. Both the chime and the lamp turn on at the same time.
If the safety belt is buckled before the ignition switch is turned to RUN or START, from OFF or ACC, neither the chime nor lamp will be activated.
Anytime the is changed to RUN from START while the safety belt warning indicator is activated, the safety belt warning indicator will remain activated until either the timing sequence has been executed or the safety belt is buckled.
When at least one door is ajar and the key is in the RUN position, the door ajar cluster lamp is activated and remains on until all doors are closed. A warning tone will sound once any time the key is in the ignition switch and any door is open.
The key-in-ignition warning will sound when the driver side is opened with the key in the and the in OFF or ACC. It will continue to sound until the key is removed, the is closed, or the is in RUN or START.
The headlamp-on reminder chime will be activated if the headlamps or parking lamps are on, the key is not in the ignition switch, and the driver door is opened.
A single tone will be provided each time a ground signal is received from the message center. A one-second tone will sound for warning indications from the message center. A 100 milli-second tone will sound for each message center button depressed.
Feb 12, 2015 | 2000 Ford Explorer Eddie Bauer
My Samsung Adidas mobile phone makes a "beep" every time I press a key. This has just started happening this week and is very annoying and makes texting slower. If I put the phone on silent...
Hi..
This means you have activated the keypad sound, its very simple to deactivate, just go to settings-> tone settings, there you will get the option like "keypad tones" or similar to this.. just select that and make it "off"..
Hope this will help you..
May 14, 2011 | Cell Phones
How do i turn off keypad volume
My service provider couldn't even help me with this! So in case no one has answered this yet ,,, to turn off the key pad tones (very annoying sound) select menu>settings>profiles, then with 'normal' selected, hit the 'options' key (upper left soft key), then 'customize'- set up your audio profile the way you want it - go down the list til you come to 'key volume' and turn that all the way down with either the side control or the navigator dial. That will turn off those annoying key tones so you will bother other less while you use your phone in public.
Hope that helps.
Jan 28, 2010 | Pantech C470 Matrix Smartphone
Samsung SGH D900I- cannot turnoff keypad sound
The steps are outlined in the article below:
D900 FAQ – How do I disable or mute the keypad tone on my SGH-D900? admin March 6, 2009 --> Note: In order to disable the keypad tone, the Dialing Display Font Type must first be set to “Normal”
To change the dialing display font type follow the steps below:
  1. From the standby screen, press the left soft key for Menu
  2. Select Settings (9)
  3. Select Display Settings (3)
  4. Select Dialing Display (6)
  5. Select Font Type (1)
  6. Highlight either Normal or Theme, using the navigation keys
  7. Press the left soft key to Save the Dialing Display Font Type setting
To turn off the keypad tone follow the steps below:
  3. Select Sound Settings (4)
  4. Select Keypad Tone (2)
  5. Highlight Off, using the up navigation key
  6. Press the left soft key to Save the Keypad Tone setting
Aug 29, 2009 | Samsung SGH-D900 Cellular Phone
Possible ignition switch problem? 99 Explorer
key chime sounds if the little tab is grounded where the key contacts it. The theft light is supposed to blink when the system is armed to let you know it is armed. That's normal.
What do you mean by auto door locks won't unlock? The remote doesn't work? the door lock/unlock button on the door trim panel? Do they lock ok? Or, just unlock doesn't work?
NOTE: The generic electronic module/central timer module (GEM/CTM) is connected to the ISO link and is diagnosed through the data link connector (DLC) with New Generation STAR (NGS) Tester.
Audible Warnings Warning Condition Lamp Duration Audible Duration Audible Output Safety Belt 60 Seconds 6 Seconds Chime, 60/Min. 740 Hz Key In Ignition — Continuous Chime, 120/Min. 740 Hz Headlamps On — Continuous Chime, 240/Min. 740 Hz Door Ajar Continuous 1 Second Single Tone, 1000 Hz Message Center (Tone Request) — 1 Second Single Tone, 1000 Hz
  1. NOTE: The generic electronic module (GEM)/central timer module (CTM) must be reconfigured upon replacement. Refer to the New Generation STAR (NGS) Tester help screen on the configuration card to program the Tire Size, Axle Ratio.
    The power windows system and rear window defroster system are (GEM) controlled systems.
  • All Windows Operate With the Ignition in the OFF Position
  • Circuitry.
  • Accessory delay relay.
  • CHECK the accessory delay relay; REFER to Component Test. If OK, REPAIR circuit 400 (LB/BK). If not OK, REPLACE the accessory delay relay. TEST the system for normal operation.
report back
May 06, 2009 | 1999 Ford Explorer
I want to turn off keypad tones on a LG FK700 phone but I cant find it anywhere and it's driving me mad plaese help.
yes - this is VERY annoying. you need to go to phone settings, then touchscreen effects (item 7). scroll down to "tone volume" and set the level to 0. prob solved.
Apr 10, 2009 | LG KF700 Triband 3G HSDPA 3MP A2DP Phone...
I want to turn off the dialing tone
Under user mode ( MENU) - machine sett. - buzzer - off
Feb 12, 2009 | Canon FAX-L1000 Plain Paper Laser
Key pad sound
open ur phone menu first. then go to settings,open settings, then select ring styles,then select second option it can be as ??????detail.(???? = type of ring style u have selected,whther it is loud, soft, vibrating .vibe & ring or silent). just select second option,then scroll down and look for key tone type, select it and choose it as off, ur annoying keypad will silent. thanks best of luck.
Feb 24, 2008 | Motorola Mobility W375 Cellular Phone
Key pad tones
after changing to beep activate which profile did you select
Jan 06, 2008 | Samsung SGH-D900 Cellular Phone
Samsung Tocco F480 - Pay Monthly Cellular Phone Logo
1,104 people viewed this question
Top Samsung Cell Phones Experts
Fotis Papastamatiou
Bill Long
Mike Cairns
Mike Cairns
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
