Question about Microsoft Windows XP Home Edition
URGENT - Windows XP Home edition -ActiveX Control problem -URGENT
When I try to access certain pages for work, I keep getting
"This page provides potenitally unsafe information to an ActiveX control - your current security settings prohibit running controls in this manner - as a result, this page will not display correctly"...
I then get taken to an Adobe flash download page, where I proceed to try and donwload the flashplayer 8 needed.. but this very same message prevents the download from being processed correctly. I find Im having to keep doing 'system restores' on my sytem to back a few days to overcome this problem just so that I can get on for work - its becoming a nightmare!
Please help - uregent request
Terry
  • 565 Answers
This is a pesky problem with Adobe flashplayer that seems to be fairly recent. It's a real pain to fix. I'm beginning to wonder if it is not a virus of some sort.
On one of my computers, I had to back up my important files and re-install Windows XP. After doing that I went to Microsoft Update and kept downloading and installing updates and kept going back until no more updates were offered, it takes a while. Once that was done, I re-installed all my programs and defragged the drive (start>programs>accessories>system tools>disk defragmenter). I then installed and ran FIWW (Free Internet Window Washer) from Eusing.com.
After everything was running smooth, I went to the Java website and downloaded and installed the latest version. With that done, I created a system restore point and went to the Adobe website and downloaded and installed the Adobe Flash Player. Everything worked great.
My experience was that I spent almost as much time trying to fix my old XP to get flashplayer to work than I did just to do a clean install of XP. If you are not in a position to re-install XP, here are some things you can try (don't get your hopes up):
1...Defrag your drive.
2...Back up all your data before proceeding! (You'll have to do this for a clean install anyway).
3...Go to: internet explorer (or whatever browser you use), click on "tools", then "internet options", then select the "security" tab. The "Internet zone" icon should be selected, if not, click it and make sure that your security level is set to "medium high". This is the default XP setting. If the "default level" box is grayed out, you're ok. Click ok.
4...Go to the Java website and check to see if you have the latest version. (Sun Microsystems)
5...Go to Windows Update site and download and install all updates and keep going back until all updates are installed.
6...Go to the Adobe website and download and run the flash player _uninstaller_.
7...Bite lip and go back to Adobe website (do this directly, don't go through another website) and try to re-download and install the flashplayer (if you're lucky, you're done here).
8...If that doesn't work, run the Adobe uninstaller again, then go to Eusing.com and download the Free Registry cleaner and run it. Then repeat step 7. If you use another registry cleaner, be careful, as some of them are too agressive and do more harm than good. I'm not pushing Eusings software. I use it because it's free and in all the years that I've use their software, I've never had a problem.
Posted on Feb 06, 2009
  • Bob
    Bob Feb 06, 2009
    Thanks for the positve feedback and taking the time to vote. Not only did you increase my rating, but, thanks to your efforts, this solution goes out on Google as a FixYa so others with the same problem can get a free, fast, and accurate fix. It looks to me that atthaullah's solution should work too, as downloading all of the Windows updates includes updating the root certificates and updated signed active x controls.
    BobB
  • 54 Answers
The Lookout Web Client is implemented as an ActiveX Control. ActiveX Controls can execute any code on a local computer from a webpage (they can even delete files), so you should always be familiar with the origin of the control that is being loaded. There are two types of ActiveX Controls: unsigned and signed. Signed controls keep information about their origin (see the last picture below), while unsigned controls do not. Because the signing technology guarantees that the signature cannot be falsified (e.g., by a hacker), signed controls are usually considered safe.
Lookout 6.0 and higher uses a signed web client ActiveX control and is considered safe by Internet Explorer under the default settings. If the security settings have been changed (either by the user or system administrator), follow the procedure below.
Lookout 5.1 and earlier uses an unsigned web client ActiveX control. By default, Internet Explorer prohibits downloading and running unsigned ActiveX controls on your computer for security purposes. If you are familiar with the download, then you can relax the security settings.
  1. In Internet Explorer, Go to View (or Tools) » Internet Options » Security » Trusted Sites
  2. Click the Sites button.
  3. Enter the URL of the Lookout Web Client.
  4. Deselect Require server verification (https:),
  5. Click OK to return to the Internet Options.
  6. Make sure that the Trusted Sites security level is set to "Low".
    • If you do not see the slide bar for the level, click the Default Level button.
Or Try This
To resolve this issue, unregister the Comcat.dll file by using the Regsvr32.exe utility with the /u switch as in the following example: regsvr32 /u C:\winnt\system32\comcat.dll and rename the Comcat.dll file in the %SystemRoot%\System32 folder.
After you unregister the Comcat.dll file, reinstall Internet Explorer.
For information about how to rename a file, click Start, click Help, click the Index tab, type renaming, and then double-click the "Renaming files" topic.
If you remove Internet Explorer before you reinstall it, be sure to rename the Comcat.dll file after removing Internet Explorer.
I would like to know why i keep getting NO DATA RECEIVED every time i want to look at a specific page. i pay monthly, carolyn roberts
What service are you trying to join ?
(May be they don't support Windows XP any more - Microsoft stopped the support for Windows XP one year ago...)
Mar 08, 2015 | Microsoft Windows XP Home Edition
How to create home page
unfortunately windows xp has no more support for home users, but i believe it would be done as on xp with other operating systems, if your a home user you have option to upgrade to vista or win7 , but here is how you create a home page... just a ? are you trying to set up a network with a home page or ? here is what microsoft says.... How to Set Up Small Network with Windows XP Home Edition PART 3
Aug 07, 2014 | Microsoft Windows XP Home Edition
Descargas las fotos en computador con windows 7 y como la recargo y como se que esta tomando la foto
Install the DRIVERS for WINDOWS. Keep in mind that the OS in this drivers work in Windows 98 (including the second edition), Windows Millennium Edition (Windows Me), Windows 2000 Professional, Windows XP Professional, Windows XP Home Edition.
Additional details about format pics, charging with USB cable (page 17), and transfer pics from camera/pc (page 11) could fiind in the DS6618 Owners Manual (PDf format).
Hope helps (remember to rate this answer).
Jan 12, 2011 | Oregon Scientific DS6618 Digital Camera
Can you give me a product key for windows xp?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
Windows XP serial # (Try one of the following key)
(i) RHKG3 - 8YW4W - 4RHJG - 83M4Y - 7X9GW
(ii) QW4HD - DQCRG - HM64M - 6GJRK - 8K83T
Oct 11, 2010 | Microsoft Windows XP Home Edition
This is the third time I have tried to get assistance for free. I am unemployed!!!!! Have Windows XP home edition version 2002 I cn access first page of employflorida for job description but cannot access...
Most of the time you have to register with employflorida or any online job site first before you can actually apply for a job.
It's exactly the same here in the UK. You can view a job description but when it comes to applying for the job you are restricted until you register with the site.
Have you registered with them and uploaded your CV/resume?
Regards.
Jul 15, 2010 | Microsoft Windows XP Home Edition
An error occured in windows update the page show error in load as it does not that low down internet speed &as no window updation is done
when you update window fist the file activex install
then activex control search which files are not available on your system ,then it listed these files
after that try to down load these files from the web site,
when your system tries to down load these files from web site ,due to lack of proper internet speed,
please contact with your isp provider for increasing internet speed.
if you have any clarification mail me 754030@gmail.com
have a nice day
Feb 15, 2010 | Microsoft Windows Vista Home Premium with...
Firefox 3x doesn't render page elements properly
what do you mean with "in a test invironment"?
have you try to reinstall it?
Dec 31, 2009 | Microsoft Windows XP Home Edition
Unable to access home page or mail
Can you access other pages? If not, try entering the following into the address bar: http://64.233.169.99 and press enter. You should go to the Google homepage. If not, then there is something wrong with your internet connection.
Nov 19, 2009 | Microsoft Windows XP Home Edition
When I try to validate my Windows version I get an ActiveX error
turn pop up for cookies on, certain activex controls would popup in the seperate windows for that popup should turn on...
Mar 23, 2009 | Microsoft Windows XP Home Edition
How do i uninstall microsoft active x control on my pc?
Internet Explorer 3.0, 3.01, and 3.02 loadTOCNode(2, 'moreinformation'); 1. Click Start, point to Settings, click Control Panel, double-click Add/Remove Programs, and then click the Install/Uninstall tab. 2. If the ActiveX control you want to remove appears in the list of installed programs, click the ActiveX control, click Add/Remove, and then follow the instructions on the screen. If the ActiveX control does not appear in the list of installed programs, continue with the next step. 3. Click Start, click Run, type the following line in the Open box, and then click OK: regsvr32 drive:\windows\occache\filename.ocx /uNOTE: drive is the drive letter on which the Windows folder is located, windows is the name of the folder in which Windows is installed, and filename.ocx is the ActiveX control you want to remove.
NOTE: If you do not know the file name of the ActiveX control (.ocx) you want to remove, you may be able to determine the file name by viewing the Hypertext Markup Language (HTML) source of a Web page that installs or uses the ActiveX control. To view the HTML source of a Web page, right-click an empty area of the Web page, and then click View Source. 4. In Windows Explorer or Windows NT Explorer, click the .ocx file in the Windows\Occache folder, and then click Delete on the File menu.Occache is the name of the folder where ActiveX controls are installed in all versions of Internet Explorer 3.x. The Regsvr32.exe file is installed by Internet Explorer and can be used to register and remove registry entries for ActiveX controls.
Internet Explorer 4.x or Later (All Platforms) loadTOCNode(2, 'moreinformation'); Internet Explorer 4.x or later, include the Occache.dll file, which is used to enumerate, update, and safely uninstall ActiveX controls using a "shell folder." 1. Click Start, point to Settings, click Control Panel, double-click Add/Remove Programs, and then click the Install/Uninstall tab. 2. If the ActiveX control you want to remove appears in the list of installed programs, click the ActiveX control, click Add/Remove, and then follow the instructions on the screen. If the ActiveX control does not appear in the list of installed programs, continue with the next step. 3. In Windows Explorer or Windows NT Explorer, double-click the Windows\Downloaded Program Files folder or the Winnt\Downloaded Program Files folder, right-click the ActiveX control you want to remove, and then click Remove. 4. When you are prompted to remove the ActiveX control, click Yes.IMPORTANT: The following ActiveX controls should not be removed if you are running Internet Explorer 4.0: • DirectAnimation Java Classes • Internet Explorer Classes for Java • Microsoft XML Parser for Java • Win32 ClassesInternet Explorer 5.0 or later does not require these components in the Downloaded Program Files files.
Error Messages Removing ActiveX Controls loadTOCNode(2, 'moreinformation'); When you attempt to remove an ActiveX control using an Occache shell folder, you may receive one of the following messages: • Share Violation These program files are currently being used by one or more programs. Please close some programs, and try again. You may need to restart Windows. • Component Removal About to remove a Windows system DLL: (<path\filename>). Okay to delete?Share Violation:
This message occurs if the ActiveX control you are trying to remove is currently loaded in memory by Internet Explorer or the Active Desktop component.
To resolve this error message, follow these steps: 1. Close all open Internet Explorer windows. 2. Disable the Active Desktop. To do so, right-click an empty area on the desktop, point to Active Desktop, and then click View As Web Page to clear the check mark. 3. Remove the ActiveX control by following the steps in the "Internet Explorer 4.0 or Later" section earlier in this article.
NOTE: You may need to restart Windows before you remove the ActiveX Control.Component Removal:
This message occurs only in versions of Internet Explorer 4 prior to 4.01 Service Pack 1 (SP1) when the ActiveX control you are removing installed files into a folder other than a registered Occache folder (for example, Windows\System or Winnt\System32). Occache cannot always determine if those files are shared by their programs.
If you are certain the file or files displayed in the message are not being used by Windows or another program, click Yes. Otherwise, click No.
NOTE: In Internet Explorer 4.01 SP1 and later, Occache does not remove (or prompt you to remove) dependent files outside of a registered Occache folder.
Support for Multiple Occache Folders loadTOCNode(2, 'moreinformation'); Internet Explorer 4.0 and later supports multiple Occache folders. The list of Occache folders is located in the following registry key: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Internet Settings\ActiveX CacheBy default, Internet Explorer 4.0 and later uses the Windows\Downloaded Program Files or Winnt\Downloaded Program Files folder. If you upgraded from Internet Explorer 3.x, both an Occache and Downloaded Program Files folder may exist. In this case, all new ActiveX controls are installed in the Downloaded Program Files folder, but previously installed ActiveX controls still work in the Occache folder. When you open the Occache or Downloaded Program Files folder in Windows Explorer, Windows NT Explorer, or My Computer, all ActiveX controls are displayed regardless of the folder in which the ActiveX control's files are located. In this case, the following string values appear in the registry key: "0"="C:\\WINDOWS\\OCCACHE" "1"="C:\\WINDOWS\\Downloaded Program Files" For additional information about ActiveX controls, please see the following article in the Microsoft Knowledge Base: 154544 (http://support.microsoft.com/kb/154544/EN-US/) Description of ActiveX Technologies For information about how Internet Explorer downloads ActiveX controls if a conflict occurs (for example, if the file already exists), please see the following article in the Microsoft Knowledge Base:
HOPE THIS HELPS
Good Luck
Feb 07, 2008 | Intel Motherboard
Microsoft Windows XP Home Edition Logo
188 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
