Question about Electrolux Pronto 2-In-1 Stick/Hand Vacuum - Cayenne
Need a belt for Pronto 2 in 1 stick vacuum.
Belt on my electrolux 2 in 1 stick vaccuum is lose and will not turn the brushes. Can not find a belt anywhere.
  • 21 Answers
Your not gonna find a belt because the belts on these units are not designed to be replaced by the consumer and would need to go to a service station
Posted on Jul 19, 2009
    Sergeant:
    Champion:
  • 373 Answers
Www.totalvac.com/Electrolux
vacuums24x7.com/ElectroluxParts
Posted on Feb 06, 2009
We have an Electrolux Epic vacuum and have a clogged hose
Hi, it's Allie from Crucial Vacuum!
Keeping your vacuum's hose unclogged and clear is very crucial to maintaining your unit running properly. Start by unplugging your unit for security reasons. Detach the hose from both ends of the unit and wand. If there is a clog you can use the end of a broom stick to gently push out the clog. Be very careful with this as you do not want to tear your hose.
If the problem doesn't seem to be a clog you may need to take a look at your belt and brush roller.
Most brush rollers can be fixed with a good cleaning. If there is too much debris cluttered around the roller and bearings, it will be unable to turn properly. Since the brush roller is connected to the belt, a dirty roller can overstrain the belt causing it to break or burning out the motor. A vacuum belt assist in turning the roller using tensions. Over time, a vacuum belt will stretch out and lose tension. A vacuum belt should be change every 6-12 months.
You can purchase direct your replacement parts from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/electrolux.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Alejandra (Allie) Sepulveda-Rivera
Crucial Vacuum Customer Care
Sep 11, 2014 | Electrolux Epic 3500 Vacuum
How do I adjust the belt on the ergorapido? It's making a noise and seems to be off center.
This model does not have a belt it is a direct drive motor in the bottom unit. Turn the head over so you are looking at the brush, to one side is a screw which a coin (penny works just right) will turn. Take out this small cover and remove the brush unit. Clean the ends of hair or whatever is clogging it up and set it back in place, be sure to engage the brush teeth at the other end. Hope this helps Fix Ya up. Be sure to clean the filters yes there are two, one is inside the other.
Aug 09, 2011 | Electrolux Pronto 2-In-1 Stick/Hand Vacuum...
I have a electrolux Pronto 2 in 1 and the suction really never seems strong plus the brush in the base doesn't turn and the vacuum has been plugged in for two days. how can I get more suction and make the...
There is a filter inside the main filter. Once that filter gets clogged it will loose suction. Pull the filter and clean it, you can wash it by hand. Turn the unit roller side up and check for a small screw cover that you can use a dime to loosen. This cover is used to remove the roller unit. Once out check and clean then check the gear assy. for miss-alignment.
Jan 24, 2011 | Electrolux Pronto 2-In-1 Stick/Hand Vacuum...
The brush turns then it stops. Does anyone else have this problem?
The reason its stopping is because the belt is stretched out and when it rests on carpet or floor the weight of the vacuum presses down on floor causing more stretching and straining on belt. When belt heats from friction it gets softer thus causing more slippage.
Oct 26, 2009 | Electrolux Pronto 2-In-1 Stick/Hand Vacuum...
Need replacement belt PN 43409 for Electrolux Commercial Upright
Just about any vac shop should have the belt. This belt is the same belt used in the upright vacs as well as the power nozzels. The new oem part number is 48359.
Sep 25, 2009 | Electrolux UltraLux 2000 Bagged Canister...
I have a velocity pet lover 1900 only 2 months old
You have broken the rubber belt that drives the brush. Flip over and remove the old belt and replace it with a new one.
Jim
Jun 10, 2009 | Electrolux EL1000A2 Pronto Bagless Stick...
Electrolux velocity pet lover 1800
we had the same problem and replaced the driver belt. The only problem is that we seem to have to replace the belt everytime we hoover!
Sep 07, 2008 | Electrolux EL1000A2 Pronto Bagless Stick...
Electrolux Pronto 2-In-1 Stick/Hand Vacuum - Cayenne Logo
294 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
