Question about IBM Computers & Internet
Ibm 8303-21g front audio pin configuration
I need the configuratuion of the pins of the front audio panel on the motherboard.
ibm netvista 8303-21g
  • kcinaykcinay Feb 07, 2009
    no diagrams into the manual.
    New Friend:
For AC97 Front Panel Audio
Pin Signal Description Pin Signal Description 1 MIC Front panel microphone input signal (biased when supporting stereo microphone) 2 AUD_GND Ground used by analog 3 MIC_BIAS Microphone power / additional MIC input for stereo microphone support 4 AUD_GND Ground used by analog audio circuits 5 FP_OUT_R Right channel audio signal to front panel (headphone drive capable) 6 FP_RETURN_R Right channel audio signal return from front panel (when headphones unplugged) 7 AUD_5V Filtered +5 V used by analog audio circuits 8 KEY No pin 9 FP_OUT_L Left channel audio signal to front panel (headphone drive capable) 10 FP_RETURN_L Left channel audio signal return from front panel (when headphones unplugged)
Posted on Apr 26, 2011
    Sergeant:
    Champion:
  • 357 Answers
Manual usually has diagrams and pin configuration for your system.
If you don't have the manual go to their web site and take a look.
Posted on Feb 06, 2009
SOURCE:
HOW TO CONNECT FRONT AUDIO PINS
the connector is marked F_audio and it is located directly behind the rear facing audio jacks. should be only one plug either marked "hd audio" OR "ac97 audio". some cases are setup for either, but you only need one of them depending on what your motherboard supports.
11) F_AUDIO (Front Audio Connector)
This connector supports either HD (High Definition) or AC97 front panel audio module. If you wish
to use the front audio function, connect the front panel audio module to this connector. Check the pin
assignments carefully while you connect the front panel audio module. Incorrect connection
between the module and connector will make the audio device unable to work or even damage it.
For optional front panel audio module, please contact your chassis manufacturer.
By default, the audio driver is configured to support HD Audio. To connect an AC97 front panel
audio module to this connector, please refer to the instructions on page 72 about the software
settings.
Pin No. Definition
1 MIC
2 GND
3 MIC Power
4 NC
5 Line Out (R)
6 NC
7 NC
8 No Pin
9 Line Out (L)
10 NC
AC'97 Audio:
Pin No. Definition
1 MIC2_L
2 GND
3 MIC2_R
4 -ACZ_DET
5 LINE2_R
6 FSENSE1
7 FAUDIO_JD
8 No Pin
9 LINE2_L
10 FSENSE2
Mar 27, 2010 | Gigabyte GA-945GM-S2 (0818313003065)...
Netvista will not bootup
ada tampilan no processor waktu looding
Jan 24, 2010 | IBM NetVista PC Desktop
The extra pin in Netvista/thinkcenter front panel USB
Thank you, you are most kind.
I would wish that you would take a moment, and join FixYa. It is free to join, and we'd love to have you on board.
Regards, joecoolvette
Dec 22, 2009 | IBM NetVista PC Desktop
Power switch pinout for the 02R4087 motherboard Hi guys I have an old IBM motherboard IBM 02R4087 Netvista Motherboard which appears to be from a Netvista model (NetVista 8182, 8305, 8306, 8309, 8313 ). I...
Progerssed the internet and got a FREE note Free response. Did not have to spend money on your pathetic permium system. Why should you charge for what others give for free?? Parasites
Jul 09, 2009 | IBM (02R4087) Motherboard
I need to know front panel pinout values for IBM NetVista 49P15
THE VENDOR HAS THE PIN LAYOUT AND SOME OF THE PLACE WHERE YOU DO BUSINESS WILL HELP WITH GETTING YOU THE DIAGRAM PAPER WORK.
ROD
Feb 16, 2009 | IBM (33P0825) Motherboard
Ibm rear audio
My IBM NetVista 8307-P8G SoundMax Driver Not Support 5.1 speaker settings. pls help me
Dec 08, 2008 | Computers & Internet
Front panel Pinout
the pins are usually labeld on the board itself or in the board manual
May 22, 2008 | IBM NetVista PC Desktop
IBM NetVisat 02R4084 Mainboard
With the power on cross the pins with a slide on connector. When it fires on you know which one is the sw. When you cross the reset it will restart. When you try the HD the light will come on during HD activity. And the power light will work when you have the power light plugged. It isn't to hard. Just be careful.
Sep 27, 2006 | IBM (02R4084) Motherboard
Computers & Internet Logo
1,593 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Steve Allison
Steve Allison
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
