Question about Whirlpool Duet GHW9150P Front Load Washer
F flashes on the front
An F flashes on front of washer. It won't drain or do anything.
    Genius:
  • 2,985 Answers
Inernbal contact or processor problem time call the engineer
Posted on Aug 01, 2007
Why won't my washer drain?
I'm assuming you're talking about your washing machine. Your washer's drain pump or a clogged drain pump is likely the problem. Access the pump by removing the front of the washing machine exposing the pump. Remove the hoses and you'll find your problem. If you're talking about anything other than a washing machine, you'll have to be more specific.
Mar 08, 2013 | Plumbing
Bosch classix water won't drain
check for blockages in the outlet pipes, filter and pump.
Dec 30, 2012 | Bosch Classixx WFL 2066 Front Load Washer
Duets washer won't drain
Probably a blocked filter, outlet pipe or pump.
Take the drain hose and lay it flat and lower then the level of the drum and this will drain the machine providing the blockage is not solid. When machine is empty check filter , pipes and pump and remove any blockage found.
Replace drain hose and you should then be able to carry on with your wash or spin the clothes.
Dec 28, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore front load 110.46462501 mid cycle all lights flash won't drain
Check your drain pump/filter may be located bottom right of machine/hold drain hose over bucket with around 2 feet from floor level should pump if no blockage....Remove any blockage .hope this also solves tray fault
Jun 27, 2012 | Kenmore Front Load Washer
F21 code still flashes after i've unclogged line - reset?
if you cleaned out the pump by removing the center part of it and it still shows f21,either you didn't clear everything out of the pump,after you pull out the center piece stick your finger inside where the impellar is to see if you feel anything rapped around it,if it's clear and still won't drain then you need to buy a new pump and remove the old pump and install the new pump part number 280187 and it's around 120 dollars http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Washer-Parts/Model-MFW9700SB1/3048/0153200/W0705107/00006?blt=06&prst=&shdMod=
Dec 10, 2011 | Maytag EPIC MFW9700S Front Load Washer
What does the LE flashing mean? Water won't drain out of washer.
LE means that the motor sensor has failed and needs a technician to come out and repair the unit. To remove the water, turn on the unit, press the spin speed button once and press start. It will drain the water out and spin the drum.
Jun 15, 2011 | LG WD-1280FHD Front Load Washer
I have an HE 3 front loading washer and I am having problems with
Hi
Thanks for using FixYa. F2 error means Long Drain. If the drain time exceeds 8 minutes, the water valves are turned off and "F2" is flashed. Press PAUSE/CANCEL twice to clear the display. Also, check the drain hose and make sure it is not plugged or kinked. Then check the electrical connections at the pump and make sure the pump is running. If still the issue is not resolved then replace the pump.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 16, 2010 | Kenmore Elite 45986 Front Load Washer
What does OE stand for on my washer
Hi
Thanks for using FixYa. OE is a drain error, it flashes when the washer won’t drain within 10 minutes. TO resolve this issue you’ll have to check the drain pump filter for any clogs, also check the drain hose for any kinks and clean the drain pump filter. If still the issue is not resolved then you might have to replace the pump. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 15, 2010 | LG WM-2277HW Front Load Washer
Oe code, i need to clean the black hose on the bottom of the washer how do i do that. thanks
Hi
Thanks
Rylee
Jun 03, 2010 | LG WM-2277HW Front Load Washer
Flashing F2
“F02” (Drain Problem)
Select PAUSE/CANCEL twice to cancel the cycle. Unplug
washer or disconnect power.
Check the following:
Is the drain hose kinked?
Is the drain hose frozen?
Is the drain hose clogged?
Is the drain hose more than 96" (2.4 m) above the floor?
After running this check list, plug back up and try a complete cycle using cold water and no detergent. Sudding can mimic a drainage issue as well. make sure you are using the correct HE detergent to prevent over sudding.
Feb 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
50 people viewed this question
Sal De
Marvin
Marvin
jimorris77
