Question about LG LS-L1210CL Mini Split Air Conditioner
Loud sound when turning on LG aircondition unit
Does anyone know what the problem is when you turn on the aircon unit and a loud sound starts to occur when the fan begins it sounds like their is something interfering with the fan, is there a way to get into the unit to have a look, the air still works its very odd.
  • 56 Answers
Is it the outside unit ofr the inside... either way sounds as if the blade is hitting the fan shroud. you should be able to access unit to see exactly where noise is coming from.
Posted on Feb 12, 2009
What could be causing loud grinding noise when i switch on aircon? Aircon now not working but only makes loud sound.
Sounds like the bearing or part of the clutch in the A/C compressor has failed, or possibly component on a/c fouling on something due to recent repairs however would be unlikely and probably just a coincidence..
Check A/C compressor turns by hand, should be firm but not make any noises.
Check for fouling components related to a/c compressor clutch.
Feb 12, 2016 | Cars & Trucks
2 and 1 aircon error ch 05
Try resetting the system. First turn the breaker off for the condenser and wait about 20 seconds. After you turn it back on the system should reset. If you have any other Air Conditioning Repair Questions don't be afraid to let us know
Aug 30, 2014 | LG Heating & Cooling
My airconditioning was on and then started making a loud noise
May 06, 2012 | 2003 Buick Century
I have an old zenith sentry tv, and up to know has never had any problems. Afew days ago it started making a very loud noise as soon as I turned it on. It sounds like it's coming from the right
someone needs to open it but it sounds like a part arcing which was not uncommon in those sets====you would have to decide if you want to attempt to have it repaired----some shops will not repair a set that old and unless you really want it done---I would replace it.
Mar 17, 2012 | Zenith Televison & Video
AVR SR6004 switches off while BD player is playing. What do I do?
There are two circumstances that I know of that a properly installed unit such as your Marantz would shut down. So here is the Theory and Data I know of.
A Your receiver has a great deal of amplification power. If it is in a closed cabinet without excellent ventilation, it will shut down if used at high volumes because because over heating. Because of it's very high power, when played loudly, it generates excessive heat.
When watching certain movies the BD player may be over-driving the limits of the amplifier section of your receiver. Page 78 of your owner's manual addresses this. Here is a link to download the manual from Marantz.
B There is one other very important thing I should mention to you. When people use high powered equipment and initially turn up the sound. After a short time, the mind turns it down. What next happens is the reason professional musicians and sound engineers often have permanent hearing loss after a relatively short time.
What tends to happen is that the listener and often the engineer running the sound mixing board at a concert(after a certain period of time) believes the sound is not loud enough when it really IS loud enough. (this tricks the audience as well) and engineer turns it up. After turning it up, his mind (and the audiences') turns it down mentally and they again think and agree that it not loud enough and then again, the volume level is turned up. And up. And up. The only reason I'm not deaf is that I discovered this when I was building sound systems as a kid. I also studied about it. So please be careful when you play things loud. Permanent hearing loss starts to occur at the very high frequencies and rolls down from there over a period of time. Hearing loss can start to occur in just a few hours at 110 decibels. permenant hearing loss is exactly just that. Permenant! It just doesn't come back. If you use this information, you will enjoy hearing music for the rest of your life.
I hope this helps,
Best Regards,
Jan 22, 2011 | Marantz Audio Players & Recorders
I have a 52" rear projection vivitek dlp tv. Picture is fine, but it has a loud humming sound. Does anyone know what it is or how to fix it??
turn on video mode if loud humming still occurred replace filter capacitor on audio section from your tv ckt board.
Mar 31, 2010 | Vivitek V37655 56" DLP TV
My aircon unit turns on runs for a minute then indoor and outdoor unit switch off
If this is a LG Airconditioning unit.
It has reached the set parmeter of the safety switch point.
1 The unit could be running on too low refrigerant charge and cuts out on low temperature on the indoor unit coil (-5°C longer that 30sec switch off)
2 The unit might be drawing to much current, to much refrigerant, cutting out on high pressure.
Check the refrigerant charge and check the indoor pipe temperature thermister (calibrated at 5kΩ @ 25°C)
Mar 18, 2010 | LG Heating & Cooling
Loud white noise sound when i switch my LCD tv on.
the main total assy is failing. it has the tuner ,sound, and a lot of the processing for the set check there first
Jul 09, 2009 | Televison & Video
Yamaha YSP1
We have the same issue. I owned the unit for about 2 1/2 years before it quit working. The Yamaha YSP-1 has been sitting on my shelf for the last 2 years now collecting dust. If anyone finds a solution, please let me know
Dec 22, 2008 | Yamaha YSP-1 System
Loud Popping Sounds
If this is a heat pump system it is possible that your fan blade is hitting ice on your condenser coil.
Nov 17, 2007 | GE Zoneline AZ55H07D Air Conditioner
LG LS-L1210CL Mini Split Air Conditioner Logo
231 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
