Crystal Eye is a webcam application included with some Acer laptops. Laptops that have the Crystal Eye WebCam application installed also have a camera built in to the monitor. Crystal Eye can adjust the camera's brightness, contrast and color intensity, and capture photos. If you removed the Crystal Eye WebCam application from your Acer laptop on accident, you can download the software from the Acer website and reinstall the application to your PC.
Click "Start." Click "Control Panel." Input "device" into the search box. Click "Device Manager." Expand "Imaging Devices." Double-click the Web camera to find the name of the manufacturer. Go to Acer Support. Select "Notebook" from the "Select Your Product" menu. Select the notebook's product line, then select its product model. Click "Confirm." Click the "Applications" tab. Select an operating system from the "Operating Systems" drop-down menu on the far right. Scroll to "Camera." Download "WebCam Application." Use the manufacturer information found in Device Manager to determine which vendor to download from. Save the file to the desktop. Double-click the file to run the setup for the Crystal Eye WebCam. Follow the on-screen instructions to complete the installation.
Acer support
http://support.acer.com/us/en/default.aspx Click start control panel view devices and printers you should see your webcam from there if you are have trouble with your webcam Click start control panel administrative tools computer management device manager scroll down image devices you could see a yellow question mark? right click to reinstall drivers or update driver xp Click start right click on computer select properties device manager scroll to image devices expand right click to update driver in W7
http://download.cnet.com/2000-20_4.html on the home page you should see a search tab just type in what you are looking for IE: webcam name webcam driver you might have to try a few times to get it right software if you dont have the driver you will need to download one here
rather doing a driver hunt which can take hours http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html Windows XP/Vista/7/8 It might take some time being a freeware driver solution note: it will find all of your outdated drivers this is a free driver solutions This will automatically search for and find the correct driver you will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point click no to both of these then continue updating each driver free then restart once all of the drivers have been updated Some webcams and programs require additional software, although that should be installed with the webcam if things are right. But is does not harm to check if your
Java, Flash and
Quicktime software are installed and up to date. But certainly check your DirectX software, since all video applications, including webcams, use DirectX for video processing. Try downloading the latest DirectX version and install it (Windows XP:
DirectX 9.0c - Windows Vista
: DirectX 10).
http://windows.microsoft.com/en-US/windows7/Which-version-of-DirectX-is-on-your-computer
installed software successfully,went through device manager to install drivers,as soon as it installs the green light goes out & any attempt to run the web mate software gives an error message
