Question about Logitech ClearChat Pro USB Headset
Logitech ClearChat Pro USB - sound volume is too low
I bought this headset a week ago and I have problems with the sound output. It is too low, at 5/10 of the sound volume meter (WinXP) I can barely hear anything. At full volume it just gets normal. With my previous Koss SB-45 headset I used to set the volume meter at like 2/10 or 3/10 and it was just great - like at 8/10 with this Logitech thing.
What can I try to resolve this issue?
SOURCE: logitech clearchat pro headset
I WASTED 40 ******* DOLLARS ON A PIECE OF **** THAT DOESNT WORK ALL IT DOES IS MAKE A ******* SPUELLING NOISE
Posted on Jul 03, 2008
SOURCE: i cant get my logitech clearchat stereo headset to work for vista
I had the same problem until I noticed I was running Vista SP1. Search and download Vista SP2 and you will be good to go
Posted on Jul 13, 2009
  • 118 Answers
SOURCE: I need a vista driver
no you don't, you need drivers for the vista itself. try reinstall the sound card driver from the pc manufacturer's websight. try on another pc if it works there it is your vista computer. go with step one. if it does not work cal logitech.
Posted on Jul 18, 2009
dnewcombe1
  • 1564 Answers
SOURCE: I just bought a Logitech Clearchat Stereo Headset
You should go to your Device Manager in the "System" category of the Control panel and see if indeed the driver for your mic is present. It will be listed under "Sound, Video and Gaming devices."
Posted on Sep 22, 2009
therewhite
SOURCE: ClearChat Pro USB headset asks for driver upon install
  1. (Vista) Confirm your system restore point first. It needs to be prior to what you're going to attempt here. If it has a recent restore point, great, but if not, make a system restore before you do this, in case it doesn't work.
  2. In the Control Panel, click System, Advanced System Settings, click System Protection, and click System Restore.
  3. (Optional) Try updating your usb drivers before trying the final step, reinstalling the Vista Service Pack 2.
  4. Here's how to verify if your USB (drivers) in the Device Manager are up to date.
  5. Open the Control Panel, System, Device Manager.
  6. Open the Universal Serial Bus controllers (usually at the bottom of the device list).
  7. Right-click, on your first USB, Updating Driver Software. It will look for the update or let you know (which may take a bit of time) that it is up to date already. Repeat this process on all the USB devices.
  8. If that doesn't work, try this: plug in your headset, and keep it plugged into the usb.
  9. In your Windows Updates, re-install the Service Pack 2. After Vista reboots your computer and finishes the install, unplug your headset from the USB and then replug it in. What you are likely to see is a Windows message indicating that it sees the software and is installing it (minus the windows pop-up message of "where's the driver disc for it?").
  10. Now the trick is to get the headset to play the microphone through the speakers appropriately!
Posted on Oct 21, 2009
My headset was working fine but all of a sudden the volume will not stay at the level I turn it up to. It keeps rolling back down to barely any sound coming through. I try to use the button on headset but...
Good morning, afternoon, evening or night; whatever time of day you are viewing this solution post. Thank you for choosing FixYa to solve your problem. Your Logitech ClearChat Pro USB Headset's volume will not stay at the level you turn it up to, and as a result it keeps rolling back down to a lower sound quality. Your volume control button doesn't solve the problem neither. Well, when a problem occurs, you should first troubleshoot where it's coming from. We will use a method called "Process of elimination". Your headset's volume has two controls: one control is on the headset itself, and the other control is located in the sound settings of the device you have your headset plugged into. With this thought in mind, lets go up to the problem explanation above. You said that the volume control attached to the headset didn't make a difference, this means the you can eliminate the hypothesis that it's the volume control causing this. The problem is coming from the earphone portion of the headset. Either a mute setting has been activated, volume is turned down real low or your headset is not the default device to receive sound input. The first part of the investigation is done; now, to get further into the investigation, you will need to connect your headset to your computer. This is where troubleshooting and solving the problem meet. Step-by-Step, I am going to explain to you how to get audio presentations into your headset. This device works with two Windows Operating Systems (Vista and XP) and one Mac Operating System (OS X). If your computer's operating system is Windows, open your Control Panel. Under the Hardware & Sound link, click Manage Audio Devices (for Vista users), and the Sound & Audio Devices link (for XP users). If your coumputer's operating system is Mac OS X, open your System Preferences and click the Sound link. In Windows Vista, click the name of your device, then click Set Default. Click the Properties button and increase the volume slider or unmute the volume if needed. If applicable, click the Apply button, then click OK. If the Apply button is void, just click OK. Click the Recording tab and perform the same procedures as you did before, only difference is that this will make your headset microphone the default recording device. In Windows XP, click the Audio tab and set the headset as the Sound Playback and Recording device. Increase the volume or unmute it if needed. When finished, click the Voice tab and perform the same procedures as you did before. In Mac OS X, click the Input tab and select the headset as the input device. If you still can barely hear anything, increase the volume slider. When finished, click the Output tab and repeat the same steps as before; only thing, you will be making this the sound output device, meaning the sound of your voice will be outputed from the microphone. Increase the volume slider if needed. You should be able to receive sound in and out of your headphones now. If we succeded, through this experience we have: troubleshooted where the problem was coming from, found a way to solve it and fixed the problem! Thank you for choosing FixYa as your one-stop solution spot for problems, questions, concerns and requests. Visit our website again the next time you need assistance with something. Thank you and have a good morning, afternoon, evening or night; whatever time of day you are viewing this solution post.
May 27, 2011 | Logitech ClearChat Pro USB Headset
It wont play sound through ps3 the system finds the headset the microphone works but not the speakers
you need to access the audio device settings in the acessory menu and set both input and output to the same device ok :)
Feb 16, 2011 | Logitech ClearChat Pro USB Headset
I cant hear through the headset its a usb mic
you have to go to settings then go the accessory settings then click on audio device settings where it says output device (next to it it should say logitech usb headset) click on it them put it tosystem default device
Apr 11, 2010 | Logitech ClearChat Pro USB Headset
Logitech ClearChat USB Headset Model: A-00006
You can buy replacement dongles from Logitech. Don't listen to lawrenceguo
Feb 11, 2010 | Logitech ClearChat Pro USB Headset
Apparent broken wire issue
I somehow think that it may not be the headphones, but rather the hardware in the computer...but then again if they are under warranty definetely get them fixed(if they are broken?...)
Good Luck!
Jun 12, 2009 | Logitech ClearChat Pro USB Headset
Not able to increse volume.The volume controller on my laptop automatically slides down even if I increase it while using the headphone.
your head phone volume controller /speaker/s has been short circuited so please replace /purchase new headphone
thank you
May 24, 2009 | Logitech ClearChat Pro USB Headset
Logitech clearchat pro
The headsets are defective. I believe the manufacturers warranty is 2 years.
Mar 30, 2009 | Logitech ClearChat Pro USB Headset
Logitech ClearChat Pro head set
Go to your play control (double-click the speaker icon in the system tray) and mute the mic on the "Play" control to avoid feedback.
Jan 15, 2009 | Logitech ClearChat Pro USB Headset
Microphone in Ventrilo is too low
try on another pc in sound recorder if working there then the headset is not the problem. try uninstalling the sound card and rebooting the pc.
may correct the issue.
Dec 29, 2008 | Logitech ClearChat Stereo Headset Headset
USB Device Not Recognized
Turn off CPU, Unplug Power cable, And all usb devices, let it sit for about 20mins. Plug it all back in. Turn on the CPU!
Oct 13, 2008 | Logitech ClearChat Pro USB Headset
Logitech ClearChat Pro USB Headset Logo
301 people viewed this question
Top Logitech Radio Communications Experts
Bharat Das
Bharat Das
Are you a Logitech Radio Communication Expert? Answer questions, earn points and help others
