Question about KitchenAid KGSA906PSS Gas Kitchen Range
KitchenAid KGSA906PSS00 Gas Kitchen Range
LED display reads "ERR F2EO STUCK KEY" anyonee know how to fix this?
4 Suggested Answers
aborcass
  • 2651 Answers
SOURCE: Kitchen Aid Gas Range, Model KGR 1801
F2 - E0 Shorted keypad Replace Electronic Range Control/Clock(ERC) theres the bad news its reading a stuck key pad. replace the control..
there may be a good side and that is depending on age of machine they usually come with a 5 yr part warr on their electrical components, in which case youd only pay service and labor to install it
Posted on Mar 20, 2008
SOURCE: Error
f2eo stuck key sign
Posted on Dec 22, 2008
reyjoshua07
  • 1157 Answers
SOURCE: KitchenAid range ProLine series kesv908
Hi barbsofarell,
The error F2 - E0 code means a shorted keypad (also called touch pad). Please follow the steps below to correct the problem.
1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Hope it helps.
Thank you for using FixYa.
Posted on Sep 22, 2011
Error code F2EO
Hello Marie,
The F2EO error code means that button on the keypad has shorted out and the keypad(touchpad) needs to be replaced.
GENE
Nov 06, 2011 | KitchenAid KGSA906PSS Gas Kitchen Range
KitchenAid range ProLine series kesv908 and ykesv908 Oven desplay comes up with err button stuck F2EO
Hi barbsofarell,
Hope it helps.
Sep 21, 2011 | KitchenAid Kitchen Ranges
Hi, I have Kitchenaid gas stove. the control panel shows the error code F2/E1.. What should I do to fix that?
Most of your F2 errors on stoves has to do with a stuck key. Use a hair dryer or a hot dish towel to warm up the keypad to loosen up that stuck key.
Jan 31, 2011 | KitchenAid KGST307 Gas Kitchen Range
We have a kitchen aid KGSA906PSS00 gas range. for the first time today the wife decided to run the self clean function. At some point through the self clean the oven shut off and the control panel died....
Sounds like my problem two days ago. I have a Kitchen Aid free standing gas oven/range model
KGRI801PWH00. I read online that the thermo-fuse might've blown. I found the thermo-fuse after removing the rear panel. It was at the top/center. Mine is T-O-D (brand) 60F24; Westinghouse #8300802. I ordered mine from appliancepartspros.com for only $34.75; arrived in 36 hrs with regular shipping!! Easy to fix, sure beats several hundred $$ to repairman.
Don't bother to call Kitchen Aid - they'll just blow you off just like the hundreds of complaints said that I found online.
Jan 27, 2011 | KitchenAid KGSA906PSS Gas Kitchen Range
F2 Error on Whirlpool Dual Fuel Range
I was baking and the stove suddenly changed to Maxi Broil and then to ERR F2EO Stuck Key. I cannot seem to change it by start or off or even turning the unit off and then back on. Any suggestions? Thanks.
May 11, 2009 | Whirlpool RF315 Dual Fuel (Electric and...
Error
f2eo stuck key sign
Mar 26, 2008 | KitchenAid Kitchen Ranges
Mar 20, 2008 | Kitchen Ranges
Oven not working
F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean 2. Test relay contact operation 3. High resistance in oven temperature sensor
Sep 05, 2007 | KitchenAid KESC300 Electric Kitchen Range
KitchenAid KGSA906PSS Gas Kitchen Range Logo
269 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
