iFixitI put up with it turning off of a couple of weeks and then the power cord blew up ... The slim edition of the classic Xbox 360 with a 250GB HDD and built-in Wi-Fi. ... After your description, I am starting to think that your power brick is the problem. .... in i cant donothing about if i was trying to play my gta4 in keep cutting off in 1 ...
Sep 14, 2015 - 5. Check Your Xbox 360 Hard Drive. Not only can the cache corrupt from .... I unplugged the console when it froze instead of turning the power off. ... hi my 360 keeps on freezing on any game i play and like the screen frezzes but .... It willnot, even after 6 goes, play, it freezes, and after about 2 mins, it ejects.
The only chance that you have is to return the Xbox One back to the store where you bought it at. Also make sure to keep the receipt as they make ask for that. Hope this helps!
Try using a DVD cleaning disk, It's odd that it would have a dirty lens if it is somewhat new still. Also, try seeing if it freezes when you turn the xbox on (with game inside) by using the main button on the console. For some reason certain games will freeze randomly if you turn your system on with the controller (I'm not sure why yet)
If that doesn't work, you will most likely need to contact microsoft, a new game should not stall a new xbox. Your xbox should be under warranty for internal issues ( Don't open it yourself )
You can check out the article atezinearticles.comhttp://ezinearticles.com/?Xbox-360-Freezing-Fix&id=1527369for moreinformation on fixing freezing problem of your xbox 360
Hi Mattrobi8886, It sounds like your console is heading for a 3 red light error, I know from experience that freezing is not good and probably means there is trouble on the way.
Adding extra cooling to the XBOX or doing an X-Clamp replacement fix works in these situations. Getting the console apart is pretty straight forward and is quite easy, I've done it plenty of times, visit the Tutorials sections here http://360solutions.eamped.com/ for instructions on taking the 360 apart.
xbox-scene.com also have allot of X-Clamp tutorials. I hope this helps in some way, leave me a message on the forum if you need more pointers.
