Intermittently some print jobs result in pages and pages of garbage / gibberish. Sometimes solved by turning off printer and starting again. Occurs when printing from 2 different machines: MacBook, and MacBook pro, each with different version of OS X.
SOURCE: Printer will only print page 1 of multiple page documents
1. Check that you are using the latest print driver - from kyocera website.
2. If the issue is when you print pdf files then make sure you set the printer in KPDL Auto mode - check the print driver settings about this and the printer menu.
3.You may check if you have the latest firmware installed within the printer - print a service status page (Menu->Others->Service).
SOURCE: Kyocera FS-2000D is printing a grey stripe down the side of page
In this case what i would request u to do is.......
Take out both the catridges from the Printer.........
Take 2 Paper Towels one should be wet with Luke warm water and the other one should be dry...........
Take the Colour catridge first turn it upside down and u will see a small copper plate on the catridge from where the ink comes out.......
Place the wet paper towel using ur thumb on the Copper plate and press it a lit bit for 10 Seconds......
Now remove it and see whether u see any ink on the paper towel..........
U should see some ink on it now place the dry paper towel on the ink catridge in the same way........
Now do the same procedure again..........
Do the same procedure twice on the Black Catridge.................
Now take the dry paper towel and turn the direction of the cartridge so that u can see a Copper plate on it with small boxes just clean that copper plate with the Dry Paper Towel..........
Know insert both the catridges inside the Printer...........
Good Luck
SOURCE: Kyocera FS-c5030N printing pages yellow
Push in the charge corona assy. Its behind the left door. Each color has a cleaning rod and charge assy. I've seen this more than once.
SOURCE: My Kyocera FS-C5030N is printing blank pages
there are a good few possibilities... your cheapest route is to call a local service tech... anything I tell you is going to cost you more... call him and see what he says... but I am leaning towards bad ram best case and worst case a blown main board...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
