Question about Dell Latitude D600 Notebook
H.D failure My laptop D600 doesn't detect the hard disk ank there is vioce of plates of H.D and system can't be boot doot due to H.D failure.. What should I do???
  • 95 Answers
Its definitely the Hard drive that might have crashed. You can try booting the system by using a windows CD and see if it boots. Secondly you can try using a different hard drive from some other laptop, if you know someone using this one. Or you have to purchase one. If you think of replacing it with a new one, I can assist you to replace it. Dont take it to a service center, they would charge you a good amount.
Posted on Feb 06, 2009
Reboot and select proper boot device, pxe e61 media test failure check cable
The error PXE-E61: Media test failure usually means the hard disk has failed or the hard disk needs re-seating or the disk controller is faulty. First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Nov 04, 2012 | MSI L1350D-1672US Netbook
Getting boot error message
The error PXE-E61: Media test failure usually means the hard disk has failed or the hard disk needs re-seating or the disk controller is faulty. First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty. Next - to check if the hard drive is faulty, remove the hard drive and insert it into an USB hard drive adapter and connect it to a working computer's USB port. If this computer cannot see it as an USB mass storage device and you cannot open the various folders and files on this drive, then this confirms the hard drive is faulty. Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Oct 09, 2012 | mpc X3000 Laptop Transport 14.1" Barebone
Operating system not found
Sep 22, 2012 | Dell Inspiron 910 Laptop/notebook Black
Laptop won't start up
Aug 12, 2012 | Toshiba Computers & Internet
The error PXE-E61: Media test failure usually means the hard diskhas failed or the hard disk needs re-seating or the disk controller is faulty.First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.The hard drive needs to be replaced in the computer/laptop, Windows installedand the computer or laptop's device drivers plus your programs etc. to get afunctioning computer/laptop again.
Feb 02, 2012 | Microsoft Computers & Internet
DISK BOOT FAILURE, INSERT SYSTEM DISK AND PRESS ENTER
The computer is having trouble finding the hard disk.
The problem could be a faulty hard disk or a faulty disk controller.
First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Jan 27, 2012 | Computers & Internet
A disk read error occured and keep on re-start
Please check that the hard disk is connected properly. If you know that the hard disk is working, check whether it is detected or not. If it's not detected, you'll need to recheck it again with the power supply. If possible, try it to another Laptop so that you can make sure that Hdd isn't the culprit. In case it's detected and the problem still persists, repair the operating system installation, this will definitely solve your problem. Good luck.
May 26, 2010 | Dell Latitude D600 Notebook
DELL D600- UNABLE TO DETECT HARD DISK TO BOOT SYSTEM
You might have to reformat the drive sounds like you got a virus in your boot sector on the hard drive.
I hope you backed up everything you needed. when ya get it running again get an external drive and make regular backups of your stuff.Where did it move the files to ? you should have a backup of your system on your harddrive that came with the machine when you bought it ,try to reformat with this sector of the hard drive its called d: backup
Dec 31, 2008 | Dell Latitude D600 Notebook
UNABLE TO BOOT DELL D600 - FAILURE TO DETECT HARD DISK
If you press F12 during bootup, you should get the boot menu. Run the hard disk diagnostic. If the hard disk is bad, you will get a DST Short Test Error code.
Replacing the hard disk in a D600 is a piece of cake though so if you need a new HD, it's easy to do. The tedious work will come afterward.
Dell Latitude D600 with new Hitachi 30GB Drive Not Recognizing
XP install is not detecting any hard disk.
No jumpers are required for laptops, can only have one hard drive in a laptop.
Check the BIOS for the hard disk configuration, make sure that it is set on Auto (detect).
You may have a faulty hard disk, you can check it by booting up with a floppy DOS boot disk, run fdisk to see if it detects the hard disk, OR connect this hard drive to a USB hard disk adapter and connect it to a working computer's USB port and if it detects it as an external drive the it is OK.
Nov 30, 2008 | Dell Latitude D600 Notebook
Dell Latitude D600 Notebook Logo
79 people viewed this question
Alun Cox
