Question about SanDisk Sansa Clip MP3 Player
Not being charged?
Sansa clip 2 gb with fm radio is not getting charged when connected usb 2.0 port and also is not being recognised by system
i have real player 11 ver.on my system
pl.this problem.
bye
  • bambielvzu Feb 10, 2009
    when i try to turn it on it wont turnon then when i put it in the computer it donesnt come on or do anything
    Sniper:
  • 86 Answers
Sandisk Sansa Clip FAQ
The detection problem is addressed at that link.
Posted on Feb 09, 2009
How can I remove SlotRadio advertisement from my Sandisk Sansa Clip + 8Gb. I can't find any SlotRadio files in both UMS and MTP modes.
You will need to manually reinstall the firmware from the Sansa Website
Current version is 01.02.15 (at this date 1/30/11)
On your clip the version number may be followed with an "a"
Your clip should be at least 50% charged or greater before following these steps
DO NOT use the Sansa Updater
1. Download the current firmware for your Clip+ from the Sansa Website
2. Save the zipped firmware (clipplus01.02.15.zip) to a folder you can easily locate (Downloads)
3. Create a new folder naming it what you wish.. (Sansa Firmware)
4. Open the downloaded zipped file(clipplus01.02.15.zip) using something like Winrar
5. Delete the file clpp_data.dat (This is the slot radio ad)
6. Extract/unzip the remaining file clppa.bin to the new folder (Sansa Firmware)
7. Plug in your Sansa Clip
8. Drag and drop (copy) the clppa.bin file into the internal memory or root of the clip
9. Unplug the clip from the USB port on your PC
10. The firmware will update and the media will refresh.. and you will no longer have the Slot radio Ad on your clip
Good luck
I have three clips.. 2 of the 2 gb.. 1 of the 4 gb and now a plus 8 gb.. and yes..I too found the banner ad annoying as all get out.
Washoe
Jan 18, 2011 | SanDisk Sansa Clip MP3 Player
My computer is not recognising the ipod
Hi!
1. Please make sure that you have installed the right driver in your pc. If not. then, go download from here.
2. Connect the Sandisk Sansa at the back of your pc. The screen on your player should turn on, show 'Connected' and indicate the battery charging or full. If the player does not turn on try using other USB ports or use another usb cable.
Just post back if this solutions were not helpful.
Please accept if this is helpful. thanks
Nov 23, 2010 | SanDisk Sansa Clip MP3 Player
LANGUAGE IS NOT ENGLISH
It was your setting. You can change it to english.
For sansa clip:
1. From main menu, select settings (picture with 4 bars)
2. Use up/down button to find " FM...", the language option is right about FM..., select it and use up / down button to find English.
3. Press home button to come back main menu
Good luck
For sansa clip plus:
1. the same as about.
2. Getting into Settings, you have 4 options (Music, Audiobook, Radio, and System Settings). Languages with letters (a, b, c, ....), you can see "Radio...." option, move the selection bar down 1 - it is System Settings. If Languages without letters a, b, c, ...., you have to get in to each option, at each option you move the selection bar down or up to find letters " USB...." , it means you are inside System Settings, from USB, press down button 6 times, and select it (language option), scroll up/ down to select English.
3. The same
Good luck
Feb 04, 2010 | SanDisk Sansa Clip MP3 Player
MP3 Sansa Sandisk 1 GB
If it won't charge, then:
1) USB connector is damaged
2) USB port is damaged (Have you tried other port and/or other computer ?)
3) MP3 Battery is damaged
May 27, 2009 | SanDisk Sansa m240 MP3 Player
Will not take a charge. took two charges prior but has now stopped
I found this online at www.sandisk.com under warranty and manuals link.
I believe they have an excellent Return Authorization system, that if you truly have trouble with your disk player and it's still under warranty, gather your receipts and get on line to get an RMA. I have successfully returned to disc players that were infact faulty (FAT problems) and received two replacement players. Get on it right away. Look at the manaul online too. IT can be very helpful. I've included the Battery info, and the link for the manual at the end.
Battery
The Sansa
Clip player comes with an internal rechargeable battery. To use the player for
the very first time, remember to fully charge the battery. You can charge your Sansa
player through the USB port of your computer, a car adapter (not included) USB port, or AC
adapter (not included) USB port.
Charging
To charge the battery, please follow these steps:
1. Connect the larger end of the USB cable into an available USB port on the
computer.
2. Connect the smaller end of the USB cable into the Sansa
Clip player.
3. The computer must be on for most USB ports to charge your battery. Your
Sansa
will show connected and the yellow charging indicator will appear.
The battery level indicator will blink while charging. You will not be able to
play while connected to the computer USB.
4. To stop recharging, simply disconnect the cable.
The battery can also be charged using an AC adapter (not included) or a car adapter
(not included) and you will be able to play your device while charging with one of the
adapters.
NOTE: Some low-power USB ports may not be able to provide enough charge
power. Also note that the rechargeable batteries are not replaceable.
http://www.sandisk.com/media/175960/clip_um_0608_eng.pdf
May 12, 2009 | SanDisk Sansa m200 SDMX3-512 MP3 Player
My sanDisk Sansa Clip MP3 Player will not charge anymore. At least not on the computer I'm on. I have had it hooked up to charge for 2 days now and nothing. Why is this and how can I charge it?
This is direct from the sansa FAQs at http://www.sansa.com/support/sansa_clip/faqs 02. Why won’t my Sansa Clip charge when I connect it to my computer? USB Cable
Make sure that the USB cable is properly plugged in and use the original cable.
Computer in Hibernation mode
Make sure that the computer isn’t entering hibernate or sleep mode while the device is connected. The computer must be on in order to charge your player.
USB Port 2.0
Make sure your player is connected USB 2.0 port (1.1 occasionally causes charging problems).
USB Port location
Try plugging in different USB port (i.e. USB port in the back of the computer); sometimes the front USB ports have problem charging up the device.
Battery
Make sure the battery is fully charged. It takes approximately 3 hours to fully charge the battery.
Latest firmware
Make sure to update firmware by downloading and installing the Sansa Firmware Updater.
I hope this helps, and don't forget to rate the answer.
Mar 05, 2009 | SanDisk Sansa Clip MP3 Player
Sansa clip wont power up unless hooked up to usb
Windows XP SP2
• Windows Media Player v10
• Intel Pentium class PC or higher
• CD-ROM drive
• USB 2.0 port for hi-speed transfers and charging
Make sure HOLD button is not on.
Battery
The Sansa
Charging
computer.
Clip player.
Sansa
adapters.
Feb 26, 2009 | SanDisk Sansa m200 SDMX3-512 MP3 Player
Sansa clip - not able to playlist listen on car radio w/ adapter
1) Go into the settings menu, go to FM settings, and make sure the FM Region is set for United States. If you are outside the US, change it to "World"
2) The radio might initially be set for Pause - to test this, turn to a specific radio station that you know you get, and press up on the clickwheel. The "block" icon underneath the radio station should now change to a play arrow, if indeed it was on pause.
Jan 02, 2009 | SanDisk Sansa Clip MP3 Player
Sansa mp3 player not detected by system
1. I assume you are using a USB Port to connect the device?
--Yes - Continue - If No, please specify connection method
2. Does using another USB Port on the PC make any difference?
--No - Continue - If Yes, that port on the PC is not functioning.
3. Are other USB devices that you plug into the PC detected?
--Yes - Continue - If No - the USB system on the PC is not functioning - upgrading or reinstalling the driver might work if it is not a hardware malfunction.
4. Did you install any type of driver for the Sandisk mp3 player?
--No- Continue - If Yes - uninstall and reinstall the driver.
5. Do you have another USB cable to try with the device?
-- If No, try another PC.
CL23
Feb 15, 2008 | Computers & Internet
SanDisk Sansa Clip MP3 Player Logo
107 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
venugopal durairajan
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
