Question about Refrigerators
My Jackaroo 3 way (lpg, 240v, 12v) will only operate on LPG. A light is showing to show that it on 240 or 12 volt but it is not working, Could there be a fuse that has blown?
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
To my understanding most 3 way fridge are manufactured by the same firm in China and marketed under different brand names. The design and electrical system are nearly identical. There would be a resettable circuit breaker and 2 fuses. Additionally they should operate on either gas, 12V or 240VAC but not on two system simultaneously. Of the 3 sources of energy, the 12VDC is the least efficient. At most this could only maintain the cold but not cool food items down, meaning the food items has to be cooled initially before placed in the fridge if the 12VDC is to be used continuously. The gas or 240 is more efficient. Since these designs do not use a compressor, there would be no mechanical/audible indicator that the electrical system really works. Additionally, there are no thermostats to control the temperature. Below is a typical wiring of some 3 way fridge.
Good luck and thank you for using FixYa.
Posted on Feb 06, 2009
  • 495 Answers
I believe that it is best to run your acessories off of your 2nd battery with a seperate fuse box. When they say to run the fridge directly off the battery they mean not to take it through the normal wiring loom. I do not know what size wire they run to the rear plug but, being cynical, I would not expect it to be over large. Run a nice heavy cable, at least 6mm, to the rear and get a better plug/socket combination to replace the cigarette lighter type that is usually factory fitted. If you are not too okay with the electrical side get your auto elec involved. P.S. The better plug/sockets are readily available at caravan supply places.
  • Refrigerators Master
  • 13,433 Answers
Test the power outlet with another device, a lamp for example and see if the power is coming there.
Next check the wiring in the refigerator, the 12v side should definitely have a fuse.
Gas tank will not fill up on 2001 ford expedition
Gas as in gasoline or gas as in LPG gas? If its petrol, the fuel sender may be out of adjustment. (Usually means a new sender) If its LPG, the fuel stations are set to automatically shut off at 80% full. The gas tank will never actually be full to the brim but the gauge should be showing full if the gas nozzle keeps shutting off. Have a look on the LPG tank itself, they have a little gauge on them which shows how full it is. I have 2 tanks on my car , when "full" or when the pump shuts down, the tank gauges show just under full but the gauge on the cars dash shows full (2005 BA Ford)
Feb 18, 2015 | Ford Expedition Cars & Trucks
I have acquired a finch b533g 3 way fridge but without instructions. Can anyone help with simple steps for 240v and 12v . The gas is covered by factory stickers. Thanks in advance
as this product is rather ancient, manual is difficult to obtain, i can suggest enquire in sports stores which still sell this product, manufacturer is obscure, but fridge itself is one of teh best and cheapest on the market! new one is sold for anything between $500 and $800. it was first manufactured over 25years ago... have friend which is still using it...
have short preview for it:
http://www.wholesalervequipment.com.au/chescold-portable-fridges/freezers/dometic-b533-575-12v/240v-33ltr-lpg-finch-fridge/prod_14.html
and i think this will be best manual for it:
http://www.google.com.au/url?sa=t&rct=j&q=&esrc=s&source=web&cd=8&cad=rja&uact=8&ved=0CGAQFjAH&url=http%3A%2F%2Fernie.awa.com.au%2FArticleDocuments%2F1168%2FUser%2520Manual%2520Memphis%2520TWF45L.pdf.aspx&ei=WwTaVKvxHZLd8AX5lYCgBQ&usg=AFQjCNH26A-FH7kUw55NIz3gZBzjHGezkQ&bvm=bv.85464276,d.dGc
hope this will help you - do not forget to vote...
Feb 10, 2015 | Refrigerators
Hi the other day i started the toyota up after finishing work it backfired now it wont run on lpg. It runs on petrol but wont on LPG any ideas would be great.
the fact that it runs on fuel means that the electronics of the vehicle are all operational. The problem is the fuel selection process for he LPG. The converter for the lpg is prone to corrosion and failures internally so I would suggest that you have an accredited Auito gas specialist look at the gas system
Dec 03, 2014 | 1992 Toyota 4Runner
Lpg converted engine wont run using lpg without gasoline in tank
It is normal. All LPG converted engines start with gasoline. Then when they reach 2000 rpm move on LPG system.
If you want to start directly with LPG must call a professional to modify your installation.
Jan 30, 2014 | Cars & Trucks
I purchased spark lpg before two months & found occasionally malfunctioning indicator comes up & low pick up in lpg mode.Even after showing in the service center twice for 3 days they are not able...
please explain what the problem is in plain english as iam having trouble working out whats wrong ,i am assuming that vehicle has had LPG conversion fitted and now its a idle problem ,well on the intake side is a valve thats fitted for the LPG and this valve isnt letting enough air through its some sort of safety valve as i remember and what i do here is remove it and make a flap type valve from a coca cola can ,then it will work ok
Dec 19, 2010 | Chevrolet Chevette Cars & Trucks
I have a Norcold 323 Refrigerator in a camper that will not cool when operating on AC but does work on gas, ( I cant test the DC as I dont have a 12 volt power sorce). After running in on gas for a while...
the unit runs on gas(LPG) so the unit is operational
by ac I take it you mean mains power and by dc you mean 12 volts it being a 3 way cooler
you cannot "jump start" a gas system so I am a bit lost with that statement
check the heating element in the unit for continuity as both the mains and 12 volt power only heat and element that boils of the coolant liquid in the system the same as the lpg flame does
it could be a relay problem for the electrical part
May 26, 2017 | Thetford Norcold N323 1.7-cu ft 3-way...
My LPG gauge shows 2 leds but I can't run on gas?
FILL IT UP FIRST ...DONT TRUST THE LIGHTS MAY BE A SELONOID GONE AND NOT LETTING THE LPG THROUGH
Jan 28, 2010 | 1995 Land Rover Range Rover
Dual fuel vauxhall combo 53 plate -will not switch over to lpg
did you solve problem? i have exacly same problem!
Aug 19, 2009 | 2003 Volkswagen Eurovan
Magna 3.5 on LPG Duel Fuel
LPG fueled vehicles are inherently "cold-natured" due to the temperature drop when the "liquid" gas under pressure reverts to gaseous state causing a frost build up around nozzles and jets. The only solutions are to start on pump gas until up to operating temperature and the switch fuels, or allow the engine to warm up to operating temperature on LP gas before driving, thus avoiding the stall point.
Jun 02, 2008 | Mitsubishi Lancer Cars & Trucks
Refrigerators Logo
163 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
