Question about HP DesignJet 750c plus InkJet Printer
Allignement error HP 750C
I have a problem with our HP 750C. The cartridges were empty, so I replaced them. Now I get a ´allignement error´ and ´-------> continue´ on the screen.
Can anyone help me.
RSD
  • 53 Answers
One or all of the cartriges is not working. If you press continue, and do a color cartrige alignment page again, you will see what cartrige is not working properly
Posted on Feb 06, 2009
  • Rick Chadwick Jul 28, 2011
    I also had this problem and spent many days looking for the fault until I finally found it. Before this I had replaced:
    The service station
    Head carriage unit
    ribbon cables
    Mainboard
    To fix this problem perfom the following:
    Remove the Right hand control console cover.
    Remove the drop tank (2 screws hold this in place and a clip).
    Locate the main platen gear which is interlocked with a worm drive motor.
    There are two torx screws holding the gear to the platen and these will have come loose. Tighten them and secure them with threadlock.
    It might be a good time to clean out the drop tank (mine was half full!) and regrease the platen gear and worm drive.
    Hope this helps!
750c plus was turned off and now says printer cartridges missing
Pull out the cartridges, turn the plotter on and install the ink cartridges one at a time - making sure each one is recognized. One of them may have gotten a power surge and had the electronics burned out - - replace that cartridge with a new one.
Mar 28, 2013 | HP DesignJet 750c plus InkJet Printer
HP designjet 750C
Check with Island Inkjet or a similar ink provider. The ink must be the correct mix and density.
Ink must be refilled as soon as it runs out. Contact the ink supplier on how to transport empty cartidges. DO NOT ALLOW the unit to dry out. The cartridges are the print head. If the cartridge is out of ink AT ALL, it will clog. Clogged heads mean you need a brand new cartridge.
See about one set of spare print cartridges so they can be rotated.
Apr 19, 2010 | HP DesignJet 750c plus InkJet Printer
My 750C printer tells me to clear the cartridge path, I see no problem. How do I clear error message?
Your carrage belt probably needs replacing. Try and lubricate the shaft slightly with a drop of sewing machine oil. Look around either end of the belt where it goes around the motor on left side and tension pulley on left side, do you see a lot of purpleish bits/dust. If you do then the belt needs replacing.
Dave
May 13, 2009 | HP DesignJet 750c plus InkJet Printer
HP 755 CM CARTRIDGE MISSING ERROR
This normally points to a worn ribbon on the carrage. Make sure the ribbon where the cartrige makes contact is really clean, if cleaning make sure the plotter is turned off. Sometimes a build up of ink can cause problems. The bad news is that if the ribbon on the carrage is worn it firstly comes with the carrage as a unit, and secondally the carrage is no longer available from HP
Jan 13, 2009 | HP DesignJet 750c plus InkJet Printer
I changed the black ink cartridge as per instructions and the printer printed an alignment paper which i then placed in the printer for alignment but the alignment failed
the page should be absolutely new.and the scanner glass should be absolutely cleaned.and 1 main thing u replaced your black cartridge.but if your colour cartridge is empty it will not accept the allignment complete thing.it will show allignment failed as the particular colour is missing in your allignment sheet which is required to get the allignment complete.
Nov 23, 2008 | HP Office Equipment & Supplies
Align Print Cartridge Failure
hello..
You may be need to buy a new color cart., becuase the allignment page depend on the Yellow color when it become to scan..
or you can pring any allignment page from a friend and put it in the scanner instead that one you printed out....
Hope it's work
Yasser
Feb 20, 2008 | HP PSC 950 All-In-One InkJet Printer
'Cartridges Missing' error. I have just replaced the belt on my 750c plus and reassembled. However when I restarted the plotter, the plotter does not recognise the print cartridges promoting 'Cartridges...
HP 750C Black cartridge quit in the middle of plotting chart. Replaced black cartridge & does not make contact with something. Cleaned contacts, turned off plotter, disconneted cables, reconnected & turned back on. Still says that black cartridge is missing. HELP!
Dec 11, 2007 | HP DesignJet 750c plus InkJet Printer
HP DesignJet 750c plus InkJet Printer Logo
405 people viewed this question
Seeker5211
Seeker5211
