Question about Compaq Computers & Internet
Out of frequency range set lower resolution
I have compaq presario amd processor computer and compaq 7540 monitor since last two days it shows a sign of '' out of frequency range
set lower resolution, refer user monitor manual '' and screen goes blank after some time i tried to use mouse but no use or even buttons on monitor are not responding
    Scholar:
  • 127 Answers
Reboot the system by pressing F8 if your using windows OS and select last good configuration.
you can try also selecting Enable VGA mode (press F8 while rebooting and select ENABLE VGA mode).
hope this helps, please rate.
Posted on Feb 06, 2009
Out of range set monitor to 1024 x 768 @75mherz
Your monitor probably does not support this frequency. 60 Hz is most likely correct for a monitor of this size and resolution.
Oct 21, 2010 | HP Compaq 1501 15" LCD Monitor
Sometimes my monitor burnt smell and the monitor says "out of frequency range I installed the CD from the monitor.
your cable is tangled with the power cable. separate it and leave it on for one full day.
Sep 08, 2010 | HP COMPAQ 7540 CRT Monitor
Frequency out of range
the monitors resolution range is only to 1280X740 or 780
and your video card may also need an upgrade.
The game may require a higher resolution that is not compatible with the the devices mentioned.
Jul 08, 2010 | E-Machines eMachines Monitor E15T4
Cpu Models to upgrade Compaq Presario sr1920nx
CPU/Processor
  • Socket: 939
  • Supports the following processors:
    • AMD Athlon 64 X2 up to 4800+
    • AMD Athlon 64
    • AMD Sempron
CPU/Processor
  • Socket: 939
    • AMD Athlon 64
    • AMD Sempron
CPU/Processor
  • Socket: 939
    • AMD Athlon 64
    • AMD Sempron
Cpu/Processor Type
Socket: 939
    • AMD Athlon 64
    • AMD Sempron
Dec 22, 2009 | HP Compaq Presario SR1920NX PC Desktop
Compaq presario 2127AD
Flickering may b due 2 ur Display configurations so u may also use some Display software or u may manually correct it.
Properties>Settings>
1. adjust ur screen resolution
Change the refresh frequency for your monitor To change the refresh frequency for your monitor
  1. Open shortcutcold.gifDisplay in Control Panel.
  2. On the Settings tab, click Advanced.
  3. On the Monitor tab, in the Refresh Frequency list, click a new refresh rate.
note.gif Notes
  • To open Display, click Start, point to Settings, click Control Panel, and then double-click Display.
  • The default refresh frequency setting is 100 Hertz, although your monitor may support a higher setting. Check your manufacturer's documentation for information regarding the settings your monitor supports.
  • A higher refresh frequency reduces any flicker on your screen, but choosing a setting that is too high for your monitor can make your display unusable and cause damage to your hardware.
  • Changes to the refresh frequency affect all users that log on to the computer.
Jun 03, 2009 | HP Compaq Presario V3000T Notebook
Monitor displays Msg. frequency out of range, screen is black
Start your computer and press the F8 when the manufacturer's logo screen is showing. This will bring you to the Windows startup menu. Pick "start in VGA mode" and windows will start up with video settings you monitor can handle. Then you can change your video settings so Windows will start normally with your monitor.
Mar 31, 2009 | Compaq Computers & Internet
Out of frequency range set low resolution or refer monitor manual
TO RESET IT START YOUR COMPUTER IN SAFE MODE AND GO TO DISPLY SEETTINGS SET YOUR MONITOR AT VERY LOW 32BIT 800 BY 600 PIXELS IT WILL SOLVE THE PROBLEM THAN RESTART THE COMPUTER
Feb 06, 2009 | Compaq CV 7500 17" CRT Monitor
Monitor can not open
usual cause is defective 5 volts 3 pin regulator..
Jan 01, 2009 | Compaq V700 17" CRT Monitor
Monitor out of range when a game is booted up
The maximum resolution for the MV540 is 1024X768 @60Hz refresh. The other monitor isn't giving you an error message because not all monitors have that feature, but both the monitors are unable to display whatever data the computer is sending. If the display is normal until you start the game, then the game itself is setting the resolution to something out of the monitors' range. You'd need to set the game up to play at a setting the monitors could handle. I've never played WoW so I have no idea if the game offers a way of selecting the resolution. The game may simply require more graphics capability than your monitor can provide. Most systems now are using 17 or 19-inch flat screens or CRT's, and they offer more resolution and refresh rate options.
Jul 29, 2008 | Compaq MV 540 15" CRT Monitor
Computers & Internet Logo
343 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
