Question about Kenwood 1090VR Receiver
Kenwood:1090VR Cracking sound from front speakers
I get crackling sound on my Kenwood 1090VR Receiver and it trips sometimes. This problem reduces after the receiver is used for sometime, But problem returns again every time I start it when the Receiver is cold.
  • Sachin
    Sachin Feb 09, 2009
    Thanks Dan,
    I tried and have resoldered a lot of connections, I also resoldered the 3 legged transistor on the heat sink...but the problem persists...
  • Sachin
    Sachin Feb 10, 2009
    Thanks Dan, I think your help with the possible parts and the service manual would really be helpful. One of my friends who is a good troubleshooter was tellling me that even the board could be leaking (I could not understand that), even he had suggested to go thru the oscilloscope route. Look forward to get an idea of the possible parts required.
  • 4,234 Answers
There are poor solder connections somewhere on the board. Usually these are at the voltage regulators where there can be some heat. Look for 3-legged transistors attached to small metal heatsinks, If you can solder, resolder the pins on those parts. Also look for any connections that appear to be grasiny or have rings and resolder them too.
Keep us posted.
Dan
Posted on Feb 06, 2009
  • ABRsvcs Feb 09, 2009
    If the resoldering does not resolve the problem, there is a defective transistor most likely in the pre-amp section. The transistor is breaking down which is causing the noise. Unles you are familiar with electronic troubleshooting and have access to an oscilloscope, this will be difficult to trace. I'll try to locate the service manual on this to give you a couple of possible parts, but it may take a few days. Your other alternative wuold be to request a detailed estimate from a local shop. Post the results here if you go that root.
    Dan
Kenwood 1090vr AV surround receiver schematics
Disconnect speakers, turn the system on, if its ok check speakers, impedance could be too low
Mar 29, 2014 | Kenwood Audio Players & Recorders
Crackling from Creative Tech Gigaworks T40 2 speakers
I do also get this same issue, They were working just fine, and 4 or 5 months ago, the right speaker crackles, if i unplug the right speaker all is fine. But as soon as I plug the right speaker in, i get a cracking sound. Have you solved this ussue?
Oct 28, 2012 | Creative Technology Gigaworks T40 2...
My mackie thump amp will start to have a loud cracking sound. The cracking goes away if I have the input line unplugged from the speaker but with it plugged in it has the cracking sound and it does not...
Crackling is usally one or two things my guess would be bad grounding of the amp or bad connection with the jacks or plug it self try to make it crackle on purpose by jiggling the jacks see if it has any effect on the crackling try to narrow your possibilitys
May 04, 2011 | Mackie TH-15A Active DJ Powered THUMP...
Cracking sound from satellite speakers
Crackling is typical with dirty and/or loose connections in the speaker cable.
If you mounted or otherwise moved your speakers to position them while the speaker cable was connected then it's very possible that some of the threads broke or your connector is loose.
Dec 12, 2009 | Denon AVR-1508 Receiver
Speakers not working
are their speakers in the rear as well. does your car have a total of 6 speakers? if so, the new deck can only run 4 of them, thats why the middle speakers dont work.
Feb 26, 2009 | Kenwood 1090VR Receiver
No sound coming out of speakers
A quick way to check your speakers is to put the contacts from a 9 volt battery to the positive and negative speaker wires (briefly). You should hear a crackle of some sort if the speakers are functioning. If there is no crackle, speakers are bad / if there is a crackle, your head unit must have a problem.
Jan 22, 2009 | Kenwood VR-509 Receiver
Cracking
I don't know if this is a solution but I was getting the same thing and adjusted the dynamic range to min and it seemed to get rid of the crackling sound. Not sure why that works but it does.
Jun 12, 2008 | Yamaha HTR-6030 Receiver
Kenwood 1090VR loses sound after a few minutes
First thing to do is to check if this KENWOOD have an input at the back then you try another player i mean dvd player or anything that you can drive or cassette then hear if the same happened again there is something overheating and i pinpiont directly the Power IC is leaking.subject to change.See the number of the IC then buy the same number and change.
Jan 05, 2008 | Kenwood 1090VR Receiver
JVC RX558 VBK, Crackling noise from speakers
A quick quess of mine is the following:
The OVERLOAD indicator lights up when the receiver is maxing out on the current it is sending to the speakers. My guess is there is possibly something wrong with the receiver itself, especially since the B speakers won't play. Either that, or something is broken in your speakers or you are using a set of speakers that have too low an impedance rating for your receiver.
Apr 23, 2007 | JVC RX-558V
201 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
