Question about Brother DCP-7020 All-In-One Laser Printer
Toner life end
We found the problem after install new cartridge also
  • 4 Answers
On my 7020 there is no keypad. I remebered a fix done months before and it works! Take out the toner cartridge and on the left side there is a white tab connected to a half round gear. This has to be reset to the forward direction. To do this remove the 3 screws holding the side cover, Pull up the cover and move the tab almost 180 degrees rotate forward, re-assemble and it will work!
Posted on Apr 08, 2009
  • 215 Answers
Open front cover, press "options" button, press "start" key, then enter "1" then "0". once display says accepted, close front cover. i'm going by memory but i'm pretty sure thats the right keystrokes.
good luck and hth,
razors
Posted on Feb 06, 2009
Xerox workcentre m24 replace toner even if the toner is new
There is no need to worry a lot what you can do is that, just open the toner access door located at the front of the printer and then you can scroll down the list of cartridges until you find the one which is giving you the message of Replacing toner.
Then press the button "1" to reset the display toner settings. If still you find any of the difficulties then we have a best place available which can actually sort out your issue and they are Micro Toner Supplies and their official website is where you can find a lot of things is https://www.microtonersupplies.com.au/toner/xerox-toner-cartridges
Basically these guys(Xerox Toner Cartridges) are famous for supplying cartridges at a specific cost and to your mentioned area but in this site there is a contact option available where you can contact them and can solve you issue. Hope this may work to you and if still you find any difficult even after accessing the prescribed website then there are many other websites where you can find better solutions.
Aug 30, 2014 | Xerox Office Equipment & Supplies
Tip
Toner life end message
If printer displays "Toner Life End" after installing new cartridge, open front cover, press 'Option' button, then key *00 on the keypad. This resets the device so it knows it has had a new cartridge.
on Jul 07, 2008 | Brother IntelliFAX 775 Plain Paper Thermal...
How to reset toner life end message on dcp8060
The counter reset method depends on the cause of the toner life end message and the condition of the newly installed cartridge.
When a USED toner is installed the reset gear is set to IN USE.
When a NEW toner is installed the reset gear is set to FACTORY SET.
Dec 13, 2013 | Brother DCP-8060 All-In-One Laser Printer
I have a printer dcp 7030 brother company i am showing problem 'toner life end change your cartridge' after reffling. i have no new cartridge what can i do?
this will reset toner counter on a lot of brother printers good luck
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Dec 29, 2010 | Brother DCP-7030 Digital All-in-One Laser...
"toner life end" message even with new cartridge
Open the front cover
Press the OPTIONS button
Press the START button
Press the number 1 key twice
Close the front cover.
You may need to go through the steps above twice to reset the toner.
Jul 11, 2010 | Brother IntelliFax-2820 Laser Fax
I am changing the ink cartridge i put the new one in and it keeps saying End of life and it has a new cartridge what do i do
Here is the solution that will reset the count and allow your fully functional toner cartridge (the one the printer tells you is empty) to continue to work.
Open the front cover.
Press options button.
Press the start button.
Press + or up arrow button 10 times.
Press set button.
You have to do this with a long pause or the system will reset and you will have to start over.
Good luck.
May 24, 2010 | Brother DCP-7020 All-In-One Laser Printer
Installed new cartridge and comming up machine won't regognise it saying tonner life end install new cartridge
To reset the sensor after installing a new toner cartridge follow these steps. 1. With unit powered On, open the front cover. 2. Press the “Options” key. Display will show “Replace Drum?” 3. Press “Start” key. 4. Press 1,0 . 5. Display will show “Accepted” for approximately 2 seconds. Then display will change to “Cover Open”. 6. Close cover and see if Toner Life End error message has gone.
Try this. We are Brother authorized.
Apr 15, 2010 | Brother MFC-7420 Laser Printer
Had toner life end message. Replaced toner and drum with oem,machine reset but now just making blank copies. Tried to print internal report that's blank too
2. Press the "Options" key. Display will show "Replace Drum?"
3. Press "Start" key.
4. Press 1,0 .
5. Display will show "Accepted" for approximately 2 seconds. Then display will change to "Cover Open".
Please note that this must be done with a new cartridge so the unit will see that there is toner in the cartridge.
Aug 01, 2009 | Brother IntelliFax-2820 Laser Fax
Toner life end message flashes
did you reset the toner life?
open the front cover, press the option button, on the screen will display ''reset toner life 1 yes 2 no ''
press 1 and close the cover.
toner life reseted
May 06, 2008 | Brother MFC-7820N Laser Printer
Toner life end
There is no reset code the likely thing is that you have a faulty toner cartridge. Put another new one in and check the machine then.
Before you try the above shake the toner cartridge and tap it some more as it may also be the toner inside have become solid and needs breaking up.
Hope one of the above works for you
Thanks J
Jan 08, 2008 | Brother IntelliFax-2820 Laser Fax
Brother DCP-7020 All-In-One Laser Printer Logo
184 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
