Question about Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
Init unable error 43
I don't know what the problem is with my printer. I've checked for a paper jam, cleaned the printer and turned machine off for 30 minutes but printer still displays "Init unable 43. Check troubleshooting and routine maintenance in user's guide," which I have done but am unable to resolve the problem
  • Anonymous Feb 28, 2009
    The same one. NO solution anywhere
SOURCE: Not printing
I tried pushing the menu button and the blue start button 4 x's. First the 4 buttons (photo/capture, copy, fax & scan lit up and started flashing and the printer went into maintenance mode, then the word copy 01/01 appeared and nothing happened. Then machine error code 4Fappeared. Does anyone have a clue what to do next? Mix-it-Up do you have any input?
Posted on Feb 28, 2008
SOURCE: [HELP] MY BROTHER MF-210C "UNABLE TO INIT"
Dear Guru,
I have a same problem" UNABLE TO INIT " but my printer DCP 110.
Please can help me.Thanks
Posted on Oct 22, 2008
benwabnick
  • 2404 Answers
SOURCE: Printer flashes "Clean Unable 46 - refer to troubleshooting and routine maintenance in User's Guide". I went to the user's guide and did all the maintenance/cleaning that was reccommended. Nothing cha
Try resetting the purge counter:
1) Enter machine maintenance mode (on MFC240C all fourphoto/copy/fax/scan lights flash in maintenance mode). Care is neededin maintenance mode, otherwise critical settings may be inadvertentlycorrupted.
FAX models with numerical keypads:Press the Menu/Set, *, 2, 8, 6 and 4 keys within two seconds. (if youfail to complete the correct key sequence within two seconds, press theStop key to try again).
Other (non-FAX) models: Press the Menu/Set and Black Start keys.Next press the “up arrow” key four times to enter the maintenance mode).
2) Press the 8 then 0 keys in the initial stage of the maintenancemode to call up the machine’s log information list (function code 80).
3) Press the Black Start key several times to scroll through the loginformation list to reach the purge counter. The purge counter is the25th item in the list.
4) Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero.
5) Press the Stop/Exit key to return to the initial stage of the maintenance mode.
6) Press the 9 key twice to return to the standby state.
Posted on Jun 02, 2009
sardanadixit
  • 813 Answers
SOURCE: unable to print See Troubleshooting and routine maintenance chapt
Download the manuals from:
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_5440CN_5840CN_EN_108.PDF
and
http://www.brother-usa.com/ModelDocuments/Consumer/Software%20Users%20Manual/SUM_DCP_110C_MFC_210C_3240C_3340CN_420CN_5440CN_5840CN_620CN_EN_1266.PDF
Please rate this solution in case you find it helpful, else leave a comment and I shall revert back with more suggestions.
Posted on Aug 11, 2009
Testimonial: "Thank you for the site info! i looked for a long time, wish i had asked and followed your advice the first thing as it went right to it."
Semi-Driver
  • 434 Answers
SOURCE: the printer says unable to init. and to go
This is almost always due to foreign material (bits of paper, paperclip, push pin etc.) in the printhead path or under where the printhead parks.
Unplug the machine. Open the cover. Check the printhead path for foreign material. Note the position of the printhead.
If the printhead is at the far left, gently slide it towards the center. (Do not force it). Carefully inspect the area under where the printhead was positioned with a flashlight if necessary, looking for debris.
Close the cover. Plug in the machine and check.
Posted on Jan 21, 2010
Solution for unable to Init.43 repair
To clear the message, you need to disconnect the Brother machine from the power outlet to check the machine. Follow the steps listed below: Check for foreign objects, such as a paper clip or scrap of paper, inside the machine. Disconnect the machine from the power outlet and open the scanner cover by pulling up on the lower right corner of the cover. Look inside the machine and remove any foreign objects. If you see jammed paper or another item inside this area, gently pull it out and then close the scanner cover securely. If the error continues to appear, move the print head and examine under the print head. NOTE : The images shown below are from the representative product and may differ from your Brother machine. 2-1.Disconnect the Brother machine from the poweroutlet. 2-2.Open the scanner cover by pulling up on the lower right corner of the cover. 2-3.Check the print head's position. In the example photo the print head is positioned at the left hand side of the platen area. 2-4.Gently move the print head to the center. Caution Be careful not to force the print head to move. If the print head is positioned at the far right hand side, you cannot move it. Please contact Brother Customer Service from "Contact Us". 2-5.Examine under the print head. If anything is found, remove it. Hint Use a flashlight if necessary to check thoroughly. 2-6.Close the cover and reconnect the machine to the power outlet. If the message continues to appear on the LCD, the machine will require repair as the print head has failed and will need to be replaced.
May 29, 2014 | Brother Sealed Mfc-j430w Wireless Printer...
Unable to init. 50, Unable to Init 30,
paper jam or some sensor problem, in error 30, clean the strip encoder located at the top of the printer head, his color is transparent.
Jan 04, 2014 | Brother MFC-665CW All-In-One InkJet...
Mfc j691dw unable to init AF what does it mean
I cant get rid of 'unable to init.42' from my new mfc j6910dw. Anybody know what does it mean & how to remove the mssge?
Oct 14, 2012 | Brother Mfc-j6910dw Inkjet Multifunction...
Unable to print
I have a Brother MFC665CW and it has error message
"Unable to change 50" after paper jam. Paper is all cleaned
out of machine and still shows message.
cenprop@bigpond.com
Apr 08, 2010 | Brother Office Equipment & Supplies
"unable to init" message appears on my MFC 210c
If there is no jam it is generally a mechanical issue such as...
1. The planetary arm assembly not engaged correctly
2. Ink cartridge/purge switch harness not connected correctly
3. Purge cam switch broken
4. Gear(s) on maintenance unit broken
5. Paper feed motor broken
6. Main PCB defective
I find that if there was a paper jam, and the user pulled the paper out, option 4 is most likely. It is the smallest of cracks but ruins everything!
You will need to contact your local ASC for repair, find it here.
Thank you for using FixYa! – Don’t forget to rate our service.
Feb 03, 2010 | Brother MFC 210C All-In-One InkJet Printer
MFC-640CW Switch on error message: "Unable to Init! - User Guide says this is a mechanical fault or jam - not a jam all clear. There is an empty Cyan ink cartridge message as well which is correct. Also...
Nov 09, 2009 | Brother MFC-640CW All-In-One InkJet...
Paper jam. caused error print unable 30
"Machine Error 30" (or "Unable to Print") indicates either a simple problem such as a paper or part of a paper stuck inside the machine, which of course is solved by opening the machine as much as possible and remove the reason for the jam.
Even a ripped part of a paper will be able to cause the paper, so it's important to be careful when taking jammed paper out to not rip the paper (do this by carefully pulling the paper among the same way as it would go when printing, not the opposite direction).
However, if that doesn't work, the error is mechanical (but still most likely caused by the jam, either a sensor getting dirty and unable to do it's work, or actually getting broken), and there isn't much you can do. If the message comes back right after turning on the machine, you'll have to have service performed on the machine.
Jun 16, 2009 | Brother MFC 240C All-In-One InkJet Printer
Message unable to print 50
Machine Error 50 either means that there is a loose object inside the machine (usually piece of paper), or that there is a mechanical error which would need you to have the machine sent to service.
Jun 02, 2009 | Brother MFC 240C All-In-One InkJet Printer
UNABLE TO INIT
MENU * 2864 VERY QUICKLY TAKES YOU TO MAINTANENCE MODE, ALL LIGHS FLASH... PRESS 82 SET, YOUR ERROR CODE WILL DISPLAY. THAT IS NEXT STEP.!!!!
Nov 16, 2007 | Brother MFC-5840CN All-In-One InkJet...
Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
383 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
