Question about Compaq CV 7500 17" CRT Monitor
Out of frequency range set low resolution or refer monitor manual
Whenever i start my pc compaq 7540 monitor it show out of frequency range set low resolution or refer monitor manual sign and pc does not start and even after pressing f 8 pc does not start in safe mode nor does menu button on monitor respond
  • Anonymous Apr 01, 2009
    monitor flickering
    Problem Solver:
  • 13 Answers
TO RESET IT START YOUR COMPUTER IN SAFE MODE AND GO TO DISPLY SEETTINGS SET YOUR MONITOR AT VERY LOW 32BIT 800 BY 600 PIXELS IT WILL SOLVE THE PROBLEM THAN RESTART THE COMPUTER
Posted on Feb 06, 2009
  • 1 more comment
  • JIMMY JORDAAN
    JIMMY JORDAAN Feb 06, 2009
  • JIMMY JORDAAN
  • shashank300 Mar 27, 2011
    i have same problem but difference is that some time display works and some time not unexpectedly even at vga mode or other settings supported by monitor.I have also updated my video driver for integrated video card of ASUS PTGD1-LA motherboard.What is the possible error?Is my motherboard' video is faulty?
Out of range set monitor to 1024 x 768 @75mherz
Your monitor probably does not support this frequency. 60 Hz is most likely correct for a monitor of this size and resolution.
Oct 21, 2010 | HP Compaq 1501 15" LCD Monitor
Frequency out of range 11khz/ 119khz message
The PC is sending out the resolution that is too high for the monitor to handle, you need to set the resolution of the PC to be the native resolution of the monitor and set the refesh rate to be at 60Hz.
Jan 12, 2010 | Envision H191W Monitor
I have a computer monitor that has suddenly gone to a black screen with this note: "out of frequency range set resolution lower or see monitor instruction manual. How do I do this if the screen is black?
if you have a video card in your PC shut down, remove the card and this should do it, if you want to install the card again, shut down re-install card, and it should also work
Dec 29, 2009 | Compaq CV 7500 (Carbon, Silver) 17 in.CRT...
AOC 771S monitor always appear "not support out of range even if i already set my resolution to lowest.
the lowest resolution is not always supported. by the range maybe referring to the frequency. change that, that should work. if you are not sure, look at your monitors manual, it will tell you resolution as well as frequency optimal settings
Apr 20, 2009 | Computers & Internet
''out of frequency range'' on crt monitor
Go into your "Device Manager" in Windows and find out if your HDTV monitor is still installed. Delete the settings under the monitor tab and reboot the computer. With any luck the reboot will cause Windows to re-detect your current monitor and install the proper settings. A similar process may need to be followed with your video card driver as well. CAUTION: Make sure you have a disk or some means of installing a copy of your video card driver before you delete out the currently installed one.
Hope this helps!
OpenSource13
Apr 05, 2009 | Compaq Computers & Internet
Monitor displays Msg. frequency out of range, screen is black
Start your computer and press the F8 when the manufacturer's logo screen is showing. This will bring you to the Windows startup menu. Pick "start in VGA mode" and windows will start up with video settings you monitor can handle. Then you can change your video settings so Windows will start normally with your monitor.
Mar 31, 2009 | Compaq Computers & Internet
Out of frequency range set lower resolution
reboot the system by pressing F8 if your using windows OS and select last good configuration.
you can try also selecting Enable VGA mode (press F8 while rebooting and select ENABLE VGA mode).
hope this helps, please rate.
Feb 06, 2009 | Compaq Computers & Internet
Compaq CV 7500 17" CRT Monitor Logo
975 people viewed this question
Top Compaq Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
