Question about Sony FD Trinitron WEGA KV-29LS35 29" TV
Extra speakers I have a sony 32" vega trinitron and I want to use some extra speakers. Do I need an amplifier or not. I have tried to connect amplifier. It doesnt work. I also tried to connect my speakers without amplifier, does not work neither. What is the solution??? Please let me know.
    Problem Solver:
  • 14 Answers
Hi in the back of your tv you should have 2 sets of 3 plugs called rca one set is input the other one is output if u using standard speakers connect it to the input remember the speakers need to have the rca plugs,if you use a amp connect your amp to the input to outlet and reverse from the tv.
Posted on Feb 06, 2009
Cant hook up externl speaker to 32 inch vizio t.v.
those connections are designed to hook up to a reciever for surround, and are not amplified
Mar 05, 2013 | Vizio VO32LF 32 inch TV
I Have a Peavey XR 600B mixer. There are only 2 inputs in the rear for speakers. I want to add more speakers to be used as monitors or just have extra speakers. How can this be done? I only have...
First off it's outputs to your speakers. If you had an extra set of powered or amplified speakers you could "Y" cable your speaker outputs. Your passive speakers won't work without an amp. You really need powered speakers or an amp for your extra speakers. (if you had powered/amp'd speakers you could run them off one of you "aux" out for monitors. Do not daisy chain your speakers connecting twi together, you'll change the resistance/ohms and damage your speakers. Trust me, I do this for a living.
Mar 06, 2011 | Peavey Xr 8600 8 Channel Powered Mixer
My receiver has a single subwoofer line out. Will I get more or better base by using a Y cable so that I can connect to both left and right line in on my mirage mm-6 sub?
Your receiver delivers an unchanged power through its single line out jack. Therefore, if you use a Y cable to connect 2 speakers to that jack, the only thing you will get is to divide the power between the two speakers. Besides, I would not recommend this trick, as the nominal impedance would be strongly mismatched, putting in risk your system. The best solutuion seems to connect an extra amplifier to your receiver line out, and then connect extra speakers to that amplifier.
Sep 26, 2010 | Audio Players & Recorders
Sony trinitron television , when you turn on it takes awhile for the picture to come up on screen and when it does the screen constantly blinks
Three possibilities
First it sounds like your Tube EHT ( Extra High Tension) power supply is failing.
CRT TVs need a high voltage around 30K for the tube to work. Whcih is generated in the set, if you hear clicking sound like arcking this will confirm it. Unless you are familiar with HV electronics you should not attempt to fix it since it can be dangerous.
Second possibility is the picture tube is failing.
Third possibility is there is some problem with the video circuits, to check this try connecting a VCR or a DVD to see if the picture is OK. If it is, the problem is in the video circuits.
Feb 15, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
How to hook up 2 kicker 10" speakers & kicker amp to a 2002taurus
Good day ma'am, hi, hooking up an extra amp. on your radio is done by audio professionals, but if you can remove the radio out from your ford, you can install that extra amp. Just follow the diagram below.63bff30.gif You need to find line out of your radio to line in of your kicker amp. connect them using audio shielded cables. connect your speakers to the amp. I guess you this already.
Nov 23, 2009 | Kicker KX600.1 Car Audio Amplifier
Sony Vega TV , On off switch
prolly u need the "D" board replaced--common to give error code of 5 to 6 flashes--unplug and wait to reset and try again
Jul 18, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
How do I connect a subwoofer to an amplifier marantz pm-68
double up the speaker and then use the two extra screw to hook sub and center
Feb 10, 2009 | Marantz PM-68 Amplifier
Manual for a Sony s-master 5.1ch full digital amplifier
Where can i find some extra speaker wire and connectors for my speakers
Aug 30, 2008 | Televison & Video
Outdoor speakers
By hooking up extra speakers, unit might be damaged or refuse to power-up and protection mode can be enabel. Reason is that extra speaker will change impedance of amplifier out-put.
Jun 04, 2008 | Sony DAV-DX150 System
Sony FD Trinitron WEGA KV-29LS35 29" TV Logo
119 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
