Question about Samsung Blackjack SGH-I607 Smartphone
My mobile fell in hot water.
Now keypad is not working exept end(red) button
    Problem Solver:
  • 14 Answers
Hi your keypad is layed on a board that is connected on a ic when your buttons dont work it seems your ic has gotten wet the only way to repair that is to send iy in to a cell repairman unfortunately the gaurantee has been voided
Posted on Feb 06, 2009
Call end button was not working in micromax x600
My Dear your phone keypad ic default so please change keypad ic
and keypad problem will solved
Dec 07, 2012 | Cell Phones
Cover keys are not working
Flex connector that connects upper and lower panel seems to be the problem and needs a replacement,due to strong sliding up and down mechanism that might cause cut off the flex or ribbon.parts and service are available in any mobile service shop near you.
If the mobile has the history of dropping the phone,this can be fix by inserting the flex properly and fit,this may lose contact during the incident.you can fix it alone by unscrewing 4 screw at the upper back panel,lift up the cover,remove side buttons then lift up the main board and check the slot and clips which the flex connector is inserted. as well as doing it on upper panel.
If the mobile accidentally fell into water,just do the same way you open,Particularly on upper panel which keypad is not working,might corrosion,stained exists and need to clean the keypad membrane and the keypad interface.
If you think this method looks difficult to do, just ask assistance to any mobile service shop near you...Good luck
Jun 28, 2011 | Sony Ericsson W910i Cellular Phone
My nokia model no 7230 fell in water after that every time the mobile turn on but after that no key works.
If you open your cellphone after falling it to water,its possible to damage the keypad circuit because of shorted happened in the circuit board when it fell, so better to look for a cellphone technician to troubleshoot it to avoid major problems.
May 29, 2011 | Computers & Internet
Keypad not working
open the Hand SET THEN GET a Normal Brush And A Nail Polish Thinner or spirit the celean the board IF not Work THEN IT Means UR KEYPAD IC is not working properly if Solved THEn plS rate me
May 17, 2009 | Nokia 6300 Cellular Phone
Tefal quick cup
Press the Hot and Cold button for 3 seconds,
The red indicator light will start to blink,
Release the hot and cold buttons and while the red is still blinking, press the and hold the hold water button, Once the desired amount of hot water is reached release the hot water button.
Now press and hold the hot and cold water buttons simultaneously for about 3 seconds.
The red light will stop blinking to the end of the programming.
NB the RED LIGHT WILL BLINK FOR THE DURATION OF THE PROGRAMMING.
Repeat the process for the cup quanity selector for the cold water.
------------------------------------The end -------------------------------------------
Feb 28, 2009 | Tefal Kitchen Appliances - Others
Ihave sigmatel s3 mobile.Keypad lock
china mobiles some keypad is not working. How to solve this probleme??????????????????????????????????????
Nov 17, 2008 | Handmark Software MobileLists (950142) for...
Keypad acting up!
SURGICAL - you need to replaced the mobile flexcable in the phone also have the repair center flash the keypad flexfile back into the phone.
BRENNA - replaced the flexcable
VGETSON - you need to flash a file call keypad flex into the phone to correct the keypad freezing up on you.
Sep 27, 2008 | Motorola Mobility RAZR V3
Keypad
Well... there is a problem with your keypad you must get your mobile repaired and thats the only why it work . you should thank god that your mobile phone is fine people use to say there phone a good bye after felling in water so i am sure it won't cost you much if you don't tell the person it was felling in water
Sep 15, 2007 | Samsung SGH-D500 Cellular Phone
123 BUTTONS DON'T WORK ON MY SONY ERIKSON K750I
Try putting the phone in a very warm dry place, ay in the "Hot water cupboard" for a day or so and this may drive out any moisture that may be causing the problems, also shake the phone vigorously B4 you do so to try and dislodge any moisture. Or you could try disassembly and wiping the keypad contacts, perhaps there is still moisture there, or maybe it has shorted something else which is why ya gotta dry it out completely.
Jul 14, 2007 | Sony Ericsson K750
My sidekick fell in water , like normal water . And well everytime i use it it says something like " sidekick is having some techinically difficultie plz contact ur nearest t-mobile store " it works fine...
Ok, You need some assistance for that. You should get some precision screws and unscrew your mobile. The get a hair drier and put it on (Hot) or the Red button and start drying the Main board of your Sidekick. But be careful with unscrewing your device, as you may forget some screws.
Mar 20, 2007 | T-Mobile Sidekick II
Samsung Blackjack SGH-I607 Smartphone Logo
53 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
