Question about HP Pavilion dv7-1130us laptop
Screen wont light up, cannot see the screen.
My HP Pavilion dv7 was working fine for about 4months until i closed it and the screen never turned on. the computer works fine, but nothing shows on the screen. I can hook the computer up to an external monitor and it works just fine. its just the screen display wont display anything.
  • Anonymous Apr 19, 2009
    same as previous review
    New Friend:
I Have a brand new Pro book 470 G1, worked fine for a few days now it still boots up fine but nothing on my screen at all
Posted on Apr 12, 2014
  • 3 Answers
Press f8 after boot up ,then select option enable vga,then when it start go to control panel,
un-install the display drivers,restart and reinstall them.
Posted on Feb 06, 2009
How do i open dv7-1451nr?
Instructions
Shut the Pavilion dv7 down and close the screen. After unplugging all cables from the computer, turn it over and remove the battery.
Unscrew the six Phillips-head screws holding the large T-shaped panel to the bottom of the Pavilion dv7. Remove the panel and set it aside.
Remove the keyboard locking screw--marked by a keyboard-shaped icon--from the top part of the compartment exposed when you removed the T-shaped panel. Reserve the screw.
Remove the black Phillips-head screw from next to the wireless adapter inside the T-shaped compartment. This screw holds the Pavilion dv7 optical drive in place.
5
Pull the Pavilion dv7 optical drive gently out of its bay, and then remove the two Phillips-head screws from inside the empty drive bay. Reserve the screws.
6
Remove the Phillips-head screw next to the circular intake fan vent in the corner of the Pavilion dv7.
7
Remove the five Phillips-head screws from inside the empty battery compartment. You should now have removed 16 screws in all. Turn the Pavilion dv7 over and open the screen.
8
Insert a spudger or other flat plastic tool into the seam between the speaker grille and computer casing on the right side of the Pavilion dv7. Gently pry up to begin removing the speaker grille from the computer. As you do this, move the spudger to a new location to pry different areas until the grille is completely disconnected. Mind the ribbon cable connecting the center of the speaker grille to the logic board, and do not lift the grille any higher from the computer than the cable allows.
9
Push both sides of the speaker grille cable lock forward until the cable slides easily out of the logic board connector. Set the speaker grille aside.
10
Remove the four Phillips-head retaining screws above the top row of the Pavilion dv7 keyboard. Lift the keyboard up and forward, and place it face-down on the palm rest.
11
Unlock the Pavilion dv7 keyboard cable connector using the same method as for the speaker grille connector. Slide the cable out of the connector, remove the keyboard and set it aside.
12
Place the new Pavilion dv7 keyboard upside-down on the palm rest. Slide the keyboard into the connector, close the lock and rotate the keyboard down into the computer. Replace the four Phillips-head screws.
13
Slide the speaker grille cable into the connector and close the cable lock. Push the speaker grille into its original position above the Pavilion dv7 keyboard. Press gently on all parts of the speaker grille until it is flush with the computer casing.
14
Close the screen and turn the computer over. Replace the five screws inside the battery compartment, the screw next to the intake fan vent, the two screws inside the empty optical drive bay and the screw inside the T-shaped compartment.
15
Replace the t-shaped panel on the bottom of the Pavilion dv7 and its six screws.
16
Slide the optical drive back into its bay and replace the securing screw.
Jan 10, 2013 | HEWLETT-PACKARD Hewlett Packard Pavilion...
Hi my hp dv7 1130 pavilion powers on with the fan on then it turns off. All the lights are on but there is no activity. tHE SCREEN IS BLACK ALSO. aNY IDEAS?
Generally this problem is due to contact/loose wires connected to your hardware components but the pile of dust may occasionally prevent the visual display.
Aug 13, 2010 | HP Pavilion dv7-1130us laptop
HP Pavilion DV7-1020US 17" Wont power up and stay on, shuts off after a half second, then cycles on and off until power cord is unplugged.
take the battery out and try,, battery maybe bad..
it could be the charger and the battery is to low.. if its not the battery or charger then its likey the mother board
Apr 11, 2010 | HP Pavilion DV7-1020US Laptop
Hi, I have an HP Pavilion DV7 laptop. When I turn on the computer everything seems to be working but the screen is blank. Blank meaning black and/or colorless without light. Thanks!
Borrow a monitor and plug it into the side of the notebook to verify that the computer still works. If it does then the screen has gone out.
Jan 28, 2010 | HP Pavilion dv6000z Notebook
My hp pavilion notebook dv7 is overheated how can i fix it
the computer is fried. any questions you can email me at meanness628@aim.com
Jun 07, 2009 | HP Pavilion dv7-1130us laptop
My hp dv7 wont turn on
Its seems like the battery, connect it directly to power, let me know if it works
Mar 25, 2009 | HP Pavilion dv7-1132nr Notebook PC
Hp dv7 wont boot
Please re your system holding down F11 and the problem will be solved.
Please rate this
Mar 22, 2009 | HP Pavilion dv7-1132nr Notebook PC
HP Pavilion dv7-1130us laptop Logo
546 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
