Question about Freecom (24358) 160 GB Network Hard Drive
Failure to Save Files on Backup
I have the 400GB and it has worked well for some time. Now, however, it just says 'failed to back up' or 'error' type message. It doesn't say why or what to do. How can I find what the problem is and address it? Any ideas welcome. Many thanks
  • 413 Answers
I would look through the support site and see if there are any updates>
http://www.freecom.com/ecSupport.asp
Posted on Jul 01, 2009
Need command prompt for Acer Aspire
The Windows Backup and Restore feature allows you to save files and system images to external backup devices such as hard drives and flash drives. However, backing up files become problematic if the directory your backing up files from isn't configured properly, or if you're having issues with the devices you're backing files to. There are ways to solve or work around backup problems quickly and safely.
Hard Drive b> A backup will not complete if the files you're backing up exceed the amount of space left on the external hard drive. If you're backing up large system files, Microsoft recommends saving the backup to an external hard drive that can hold at least 200 GB. If you're running out of space, you must delete content to create space for others or use another hard drive. Error Codes In some cases, Windows displays the following error codes when it's unable to complete a backup: "0x80070001 (Invalid Function)" or "0x81000037: Windows Backup failed while trying to read from the shadow copy on one of the volumes being backed up." These error messages usually appear if Windows is unable to backup a specific library or if you opt out of adjusting your backup settings and settle for the default settings in the Windows Backup and Restore Feature. Reparse Point b> If you're unable to backup a specific library and run into error code messages, removing the reparse point allows you to complete the backup. A reparse point is a file that contains information about the user on a computer. If it doesn't point to a location that contains some of the data you want to backup, error messages appear when you try to back up your files. Type "CMD" in the Start Search box to open the Command Prompt. In the Command Prompt, typing "DIR /AL /S" and pressing Enter lists the reparse points. Each entry says "JUNCTION," which also means reparse point. The entries also tell you the location of the reparse points in Windows Explorer. If you locate a specific reparse point in Windows Explorer, delete its mounted volume from the device's Properties. Once deleted, you should be able to back up your files. Discs b> If you're backing up files to a disc, you'll run into problems if the discs are non-rewritable and already contain data, or if they are severely scratched or damaged. Non-rewritable discs can only be used once, while rewritable discs can be used to read and write data several times. If the CD or DVD you're using is severely scratched, the optical disc drive spins harder than usual in an attempt to read it. If it's incapable of reading the disc, the backup feature may freeze or display an error.
Windows backup or restore errors 0x80070001, 0x81000037, or 0x80070003
http://support.microsoft.com/kb/973455 - workaroundissue12
Apr 20, 2013 | Computers & Internet
Computer wanted to to backup files. I received a message, "The back-up did not complete successfully". "An error occurred. The following information might help you resolve the...
please clarify a little to what program did you use to backup files or which program wanted to backup files, also which windows do you have?
Add a comment and il help you.
Aug 18, 2008 | Computers & Internet
Tip
How to backup and monitor a desktop computer
<p>The computer systems are based on the memory and storing information. However, as the crash of a computer system, causing loss of data, all previously stored information. All computer systems, servers and personal computers, users can backup storage disks to store and to store information - in case of system failure. Creating a backup system is completely dependent on the operating system on the computer. <br /> <p><br /> <p>1. Press Start. Select "Control Panel". <br /> <p><br /> <p>2. Connect your external hard drive on the computer begin transmitting and storing files on your external hard drive. <br /> <p><br /> <p>3. Click on "maintenance". Choose Save and Restore. " <br /> <p><br /> <p>4. Choose your external hard drive and choose "Configure a backup." A wizard will appear and give you further instructions. While the setup wizard, you can schedule backups, and select where your backup files to save. Under Windows, the recommended storage for backing up files and programs on an external hard drive. <br /> <p><br /> <p>5. Show your stored files by choosing "System and Maintenance" and select "Backup and Restore". On the menu, select "Find files" or "Search" folder to the contents of your backup view. Because Windows will automatically create backup files when it is supplied, you can check or change the scheduled backup for "Schedule backup" to monitor the dates and times for the safety of a system. <br />
on Jun 22, 2011 | Computers & Internet
Master hard disc..Message stating that Windows has detected a problem.
Back up your files immediately to prevent information loss, and then contact the computer manufacturer to determine if you need to repair or replace the disk.
+ Start the backup process
* Ask me again later
If the disk fails before the next warning, you could lose all of the programs and documents on the disk.
Immediate steps
Because a disk failure will cause you to lose all programs, files and documents on the disk, you should back up your important information immediately. Try not to use your computer until you have repaired or replaced the hard disk.
Dec 24, 2012 | Computers & Internet
I can not setup my asus laptop core i3 from widows 7 that has backup.Actually i do not know widows has or has not in my computer backup
windows 7 has action center that shows up as a white flag at the bottom right hand corner where the rest of the icons are. if there is a problem, there will be a red x on the flag. if you click on it and open it, under maintenance, there should be back up. if the messages for back up are turned off, click "turn on messages for backup" and "set back up" button should appear, or it should already be there. when you click on this button, it will load the backup screen, and ask where you want to save it. since windows backup is designed to save your files in case you experience any type of hardware failure, it will ask you to save your files on either an external harddrive, flash drive, dvd, etc. once you click where you want to save it, it will show you a list of files or folders you can save. choose your files, and windows back up will begin. hope this helps, if you need further assistance, let me know and ill be glad to help.
Jun 04, 2011 | ASUS K52F-BBR9 Notebook
Issues with a C7972A 400GB tape: I observed that when the backup size reaches over 250GB, the tape starts giving an error that it cannot complete the backup. Is there a limitation on how much data can...
This tape is 200GB with no compression, up to 400GB with compression assuming 2:1 compression ratio. The compression ration is dependent on the type of file e.g. an MP3 file will not compress much, nor will a ZIP or JPG file, but BMP, DOC, TIFF will compress well. In my experience it is best to assume worst case and calculate for no compression i.e. assume max capacity of 200GB.
Mar 15, 2011 | HP (C7972A-10PK) LTO Ultrium Storage Media
I want to backup my computers (4) and have maxtor partitioned and used at purchase time, but now when I connect it I get no prompts or choice of hard drive to back up. How do I go about back up?
You have a varity of option to do your backup depending on the type of backup you want to do.
1 Documents and folders
To backup your document and folders you can just copy the Documents and folders to the external drive.
You could also use the backuo feature of the Operating system you have like windows backup to backup your documents and folders.
2 System backup of your system.
You can not use a copy accross to do the complete backup of your system. You can use the windows backup to do this or a third party backup software.
Windows Back for Windows 7.
Click on Start ----- Controll Panel ----- System and Security ------- Set up Backup ------ Select where you want to save your backup ( the external Drive you connected to your system) in the box ------ Next ----- Choose the files or drive you want to backup and click next ------- Review your backup settings and save settings and run back.
This will save your files to the external drive you added to your system.
Jan 08, 2010 | Maxtor One Touch II (EO1E200) 200 GB Hard...
When i try to access my Trekstor Datastation maxi mu 400Gb, I had error that the drive is not formatted. And if I try to fix or retrieve the files with PCI file recovery or other software like it, i got a...
it is difficult to recover it from that partition..use this software
"Recover My Files" if it is recover then ok otherwise use "Virtual Lab"
if it is not again recoverable then noway to recover. after all efforts one thing u can do is to quick format it and then try recover my files to recover from fast formated drive....but chances r very less something like wallpapers and songs can be recover.
Good Luck.
Hope the files will recover
Nov 24, 2009 | Trekstor Computers & Internet
Freecom Hard drive
Backup file in windows is being compressed the bytes from the original file. YOu don't need to worry unless everything doing good.
Please rate me solved if you like my solution.
Best regards,
Philip
Oct 31, 2007 | Computers & Internet
Freecom (24358) 160 GB Network Hard Drive Logo
140 people viewed this question
Top Freecom Computers & Internet Experts
callhow
Level 1 Expert
John Anderson
John Anderson
Are you a Freecom Computer and Internet Expert? Answer questions, earn points and help others
