Question about Galaxy Radios DX-2517 CB Radio
Meter lights not working on my 2517 bulbs has been replaced and are new and still dont come on
  • 52 Answers
Power transistor or fuse blown for this function.
Posted on Feb 08, 2009
I have 1991 Nissan maxima. All my lights,tail lights and brake lights work EXCEPT my left brake light. Changed the bulbs and still dont work. Can someone help?
Pull the bulb back out and look in the plug. They get corroded and the tabs will spread apart and/ or break off. Bend them back if they are there, replace it , if not.. If it looks good, you need to use an ohm meter and check continuity of the tabs to the wire. They usually break close to the plugs.
Dec 31, 2014 | 1991 Nissan Maxima
Replace meter light
why take out the meter light? check out your diode first . there are several diodes in the front end that operate the light and several other lights .Check to make sure they are in proper working order.. Follow the wires out of the meter to the board then make sure by moving them that you light is indeed out. Then take the bulb out of the meter , go to radio shack and p/u one just like it . there is no pos or neg so just install it where you undid the wires to the board then put it back into the meter.
Jan 06, 2014 | Galaxy Radios DX-2517 CB Radio
My swr calibration does not work on my galaxy 2517 what is the problem?
Does the meter work otherwise? If so I would suspect a bad pot.
Sep 25, 2013 | Galaxy Radios DX-2517 CB Radio
Tail lights dont work everything else does
if you have a volt meter, turn on the lights and either take out a bulb or
unplug the harness going to one of your rear lights. the using the meter (switched to VDC) see if you power going to the lights if not, you have a wiring harness or a fuse issue. If you have power coming back to the light, switch you meter to Ohms and check to see if you have continuity on the bulb itself. you can also check your fuse with the meter on the Ohm setting.
Dec 16, 2012 | Cars & Trucks
Where do you adjust the signal meter ? the meter works but signals are real low.
http://www.cbtricks.com/radios/galaxy/dx2517_mosfet/dx2517_mosfet_trans_adj.htm
RF Meter
I'm not sure that is what you want to do. It seems like you are really asking to improve you receive or sensitize it. That may require some specialized equipment and if your thinking of giving it a go you might not like the end results.
Apr 02, 2011 | Galaxy Radios DX-2517 CB Radio
Low beam headlights will not work.the fuse keeps blowing so I replaced bulbs with new ones and checked relay and it was fine. also replaced light switch with a new one and replaced fuse. it still blew....
It sounds like you definitely have a short. Get an ohm meter and probe the power wire to each light. One of them should register continuity to ground. This will give you a starting point for where to start looking at the harness.
Sep 29, 2017 | 2005 Hyundai Elantra
My 2517 talks good after awhile on it it just drop out like dont have no mod but receive good let it cool it go back workin fine any idea? shows when this happens it shows on radio signal moving none on...
Hi and welcome to FixYa,
On a MOSFET version of a Galaxy DX2517 and assuming stock mic, heat related issues of missing modulation would require initial checks of:
  • echo circuit - board EB-2000 EPT0SSB51J;
  • mic amp - IC7 NJM4558D;
  • AF power amp - Q53 to Q55.
Good luck and thank you for asking FixYa.
Nov 09, 2009 | Galaxy Radios DX-2517 CB Radio
Rear interior light and door courtesy lights not working- Jaguar
take off the cover and replace them. if you have a volt/ohm meter you can put if on the car side and make sure you have voltage and the ohm meter on the buldb should give a 1 rating if its good. it would be the cheapest and easiest to just get a new bulb and see if it works then start checking fuses if its not the bulb.
Mar 15, 2009 | 2004 Jaguar X-Type
GE Profile Convention Light Bulb Not Working after Replacement
With a volt meter you must verify power to the door light switch and the light socket.
You can also unplug the oven and do this with a meter set for continuity.
Feb 17, 2009 | GE Profile JTP18 Electric Single Oven
Radio Communications Logo
87 people viewed this question
Top Galaxy Radios Radio Communications Experts
Steve
Steve
Are you a Galaxy Radios Radio Communication Expert? Answer questions, earn points and help others
