Question about Canon imageRUNNER 400S Copier
Ir400 e677 error
My mechine shows automatically e677 error. i dont know what is the solution for it. i request u to send the solution to my email.
    New Friend:
Where is the PDL board located?
Posted on Dec 30, 2013
  • 77 Answers
Check the connection between the
printer board and the PDL I/F board
and the system motherboard. Is any
of the pins bent or otherwise not
normal?
Posted on Feb 09, 2009
E677 on iR400 is the otional printer board assembly was trouble. It must be change. Try this : replace your optional printer board assembly, the problem was correct? The other day you must bought optional printer board assembly. God Bless You....?!
Posted on Feb 06, 2009
Canon ir400s E014 error code problem
I dont know that model,but on the others it may be waste toner bottle full,or fixing motor faulty
Oct 15, 2014 | Canon Office Equipment & Supplies
What to do Error E677
hello i will tell you what error means and how to fix the problem but you will need the service manual to help you
1. E677 error means that "The communication between the printer board and the machine has a fault."
2. Check the connection between the
board and the system motherboard.
Is any of the pins bent or otherwise
not normal?
3. If this not helped you must replace the printer board
You can download the service manual for ir400 from the below link it will save u $$$:
http://goo.gl/bFmfmN
good luck
Sep 11, 2013 | Canon imageRUNNER 400 Printer
Canon ir 400 error code e004
The error code E004 deals with the fixing unit. Odds are that you may have one or all of the following parts need to be replaced > the fixing lamps or thermistor or the thermal fuse or the upper fixing roller.... Just for starters... Good Luck
May 05, 2013 | Office Equipment & Supplies
Xerox mechin ir400 automatic morning time on off problem heating rollen problem
So the rollers are not heating properly? if thats the case, its a possible thermistor (heat sensor) out, bad heating element, all of witch need to be repaird by a tech
Sep 07, 2010 | Canon imageRUNNER 400S Copier
Hello my nokia 3110 mobile got hang and switched
my nokia 3110 mobile got hang and switched off automatically. to restore factory setting i put the code 12345 or 00000 but i shows code error. i think there is virus in my mobile. now i dont know the exact code to format my mobile. pls send me the procedure to format my my and give me the right code to format it. follwing is the information of nokia3110c: Email Id :- yogeshkumar5555@gmail.com
Aug 07, 2010 | Nokia 3110 Cellular Phone
Como borrar o quitar el error e677 de una ir400s
board and the copier is faulty.
Replace printer pcb or dc controller
Mar 05, 2010 | Canon imageRUNNER 400S Copier
Ihave problem with canon ir 600 .Error show E677
E677 communication error between machine & pc.
Thanks, i am waiting for your feed back & if you satisfied then thumps me please.
Feb 01, 2010 | Canon imageRUNNER 600 Printer
Eror E677
roblem :
The machine displays an E674 code. This may be followed by an E677 code when the Fax pcb is removed. The imageRunner also has a Print Board installed.
Solution :
With the Fax Board and Print Board installed an E674 code occurred. When the Fax Board was removed an E677 code then occurred.
Try removing the PDL Interface pcb for the Print Board from the copier. Reinstall the Fax Board, if the E674 code does not occur and the copier is capable of sending and receiving faxes, then replace the PDL Interface pcb because it may be faulty and causing the two E codes; E674 for faxing and E677 for printing.
Jun 01, 2009 | Canon imageRUNNER 400S Copier
E677 Error in canon IR400
switch main power off and on E677
Feb 24, 2009 | Canon imageRUNNER 400S Copier
Canon imageRUNNER 400S Copier Logo
309 people viewed this question
old marine
old marine
