Question about Epson Stylus R290 InkJet Printer
My epson r290 produce streaking lines during photo printing
And shadows on text. i already done head cleaning many times but there is no good result. is the print head the problem or the board? cant it be fixed?
  • jtlacson97 Feb 09, 2009
    it is supposed to be under warranty but i converted it to continous printing. thats the problem
Set the setting it to best photo
Posted on Mar 22, 2009
  • Epson Master
  • 511 Answers
Try to print with no high speed. if it's ok, so your r290 need head alignment.
Posted on Apr 17, 2009
Did you install continuous ink with your R290? The shadow image is usually the delayed printout as a result of the restrictions or limited movement of the INK CART. Adjusting the placement of ink pipes support positions and its length that should just be enough so the cart could move freely on both sides of the printer. Good luck.
Jerome Fortaleza
Posted on Apr 03, 2009
    Habit-Forming:
  • 121 Answers
Is the printer under warranty?
Posted on Feb 06, 2009
  • Duke Bells Jul 06, 2009
    No the printer isout of warranty and i have to make sure they work out to secure my job
How to fix the white lines on my prints
Print a test pattern to see if that is good. If so, then you are probably printing in draft mode. Simple select text and photos in printer properties and that should take care of it,
Sep 07, 2014 | Epson Stylus Photo 810 InkJet Printer
Epson C88 3/16" gap every inch printing black text
Reload the printer drivers, you can get this from the manufacturers web site under support or downloads.
its a common error and an easy fix.
good luck !
Mar 30, 2017 | Epson Stylus C88 InkJet Photo Printer
Printing lines on the photo using bulk ink
Good Day!
Please follow the instructions:
1. open a blank document (word,excel,) 2. control P 3. under printer properties hit on maintenance tab. 4. then hot on head cleaning. once done, "print check pattern" 5. please continue doing this until the print out goes clearer. 6. then, try to print. i hope this helps.
Jul 20, 2011 | Epson Stylus R290 InkJet Printer
Epson R290 with Continuous Ink System. Even after 4 or 5 head cleans, I'm still getting banding. I never had this originally, and use this printer for high quality photo prints. Can the print head be...
Hi
Sure can be printhead can be cleaned but remember one thing you are dealing with a delicate thing and need to take care while doing this.
1. remove the head from the printer
2. Take little lukewarm water in a container (remember not to submerge the complete head in water)
3. Take a Syringe with little water in it and insert in the tip where the ink is supplied to the head from cartridges.
4. be gentle and do not force the water too much as this will damage the head gaskets.
5. keep in water again for some time and repeat the same process once more but this time do the suction from the same syringe so the dirt can come out into the syringe.
6. Install back the head and do the head cleaning 2 times
And you are done
DO RATE MY SOLUTION
Jul 01, 2011 | Epson Stylus R290 InkJet Printer
Hi, my Epson 2100 is printing with faint lines at regular intervals right across the page. I've done various alignment tests and cleaning tests but can't seem to clear the lines. Any advice much...
Are your alignment tests show good results? If they are, try head cleaning 3 consecutive times without printing nozzle checks. After 3 head cleanings do the nozzle check. If problem persists try printing at BEST PHOTO or whatever is the slowest print setting for your printer. Good luck!
Jan 14, 2010 | Epson Stylus Photo 2100 InkJet Printer
My printer is leaving horizontal streaks across
When I had the same problem, I found out, that Epson did not like Generic Ink. As soon as I replaced it with Genuine Epson Ink, it was fine.
Make sure you do Maintenance, Nozzle Check and Head Cleaning. You might be clogged?
Good Luck.
Nov 05, 2009 | Epson Stylus Photo R220 InkJet Printer
Every fifth line or so of text has a missing streak in the middle. ie across the page Do I need to clean something??
Check nozzle. Is there some lines missing? Do head cleaning procedure from peinter maintenance. Wait for 15 minutes. Check nozzle again. If there is just little missing lines, you can print with fine/photo quality fot better result.
Jul 27, 2009 | Epson STYLUS CX3900 All-In-One InkJet...
Printer output has shadows, blurring, streaks, lines, poor color
Seem like blocked hole(s) on the color print head...
Most likely if there is a deep clean option then do it (may need a few times to unblock a hole or never).
Also get the printer physically cleaned up if you can see dusts inside (vrtical lines on color bars).
Mar 20, 2009 | HP DeskJet 9800 InkJet Printer
Epson r290 printer no printing now
try to clean yellow nozzle manualy, use a spuit and flexible pipa (as in cleaning mechanism), use a cleaner.
Feb 21, 2009 | Epson Stylus R290 InkJet Printer
Epson Stylus C88 InkJet Printer
Are you confident the new cartridges are full and in-date? Can you confirm that the old cartridges were not removed until immediately before the new cartridge was installed. Did you remove the yellow tape from the new cartridges before you installed them? Were the cartridges changed properly such that an ink charging cycle occurred. Have you carried out any head cleaning cycles recently? If not, do it. Then do a nozzle check print. Any improvement? Yes, but not perfect? If so do a couple more head cleans and nozzle checks. If still not perfect, let it rest for 24 hours to disperse air bubbles. Then repeat.
If you have already done lots of head cleans with no result, and you're sure you have good ink cartridges properly installed, then you can try soaking the print heads for 24 hours (or more), as follows. Turn the printer on, and as soon as the print head moves pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way. Look inside the print head parking area on the right and you will see a small rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head fully into its parking position so that the cup full of fluid comes up over the print head. Leave this for at least 24 hours, then try a head clean/nozzle check again. If still nothing, post a new comment detailing what you have done and the results.
Aug 04, 2008 | Epson Stylus C88 InkJet Photo Printer
Epson Stylus R290 InkJet Printer Logo
928 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
