I am also having problems with water going in, but it come's straight out again - leaving no water in drum to wash. I also having problems with machine to spin. It will go on spin but nothing is spinning in machine - it stops and the timer goes up again then the whole cycle starts all over from washing again. Please can you help as we have tried everything - ie.: leveling the machine ect. but still nothing.
the pump is stuck. you need to get a pump replaced, a piece of dirt is all it takes to mess up the pump, exspecally if you are on well system, check the filter in the line and make sure its clean. if the machine is not spinning out, and its running the entire cycle the transmission is not engaging correctly, have this checked out.
let me know if you need further help
Thanks,
joyce
Was this helpful?
Yes
No
Popular Solutions for LG WFT1071TP Top Load Washer
Top Loader fuzzy logic 5.0kg LG washing machine (model wf-t502A) isn't draining. Not sure where to...
(More)
Top Loader fuzzy logic 5.0kg LG washing machine (model wf-t502A) isn't draining. Not sure where to begin.
my lg washing machine wf-s6607tc soon after start washing it stops then spin and drain lights comes....
(More)
MY LG WASHING MACHINE WF-S6607TC SOON AFTER START WASHING IT STOPS THEN SPIN AND DRAIN LIGHTS COMES. AFTER READING THIS SITE I GOT TO KNOW THAT THERES A MAGNET ON THE TOP FRONT COVER. SO I BEGAN SEARCHING FOR THE MAGNET. BUT ITS GONE.. SO WAT ELSE CAN I DO?
Machine cycle but over flow as if load sensor is broken , The machine does not complete cycle and...
(More)
Machine cycle but over flow as if load sensor is broken , The machine does not complete cycle and once first part of cycle is in motion it over flow. Please send drawing of machine and where load sensor is located.
