Question about Black Box Computers & Internet
My microtek 517m lcd monitor it keeps going blank
Ok my monitor will go blank then if push the on an off button it will come on then in a few sec gose out again what is going on ? thank you tammy c. I have a Microtek 17" LCD Monitor that keeps going out, also.
When I turn it on, it lights up, and you can see everything, then after about 3 - 5 seconds, the screen turns completely black.
If I turn it off, then back on, it comes on again, and does the exact same thing, only lasting about 3-5 seconds, every single time.
Talk about frustrating!
I'm pretty sure it's the lamp assembly, because I can see a faint image if I shine a flashlight on the screen...
But I don't know where to get parts, or bulb replacement instructions.
I think If I could just get the parts, and replacement info, I could fix it myself.
Anyone know where I might find what I need to fix this?
Hey PCMobMech wondering if you could do me a favor. i've been looking for the microtek 517m drivers online for a couple days now and there is nothing. I was wondering if you could give me a copy of the drivers. i can't find my installation cd either. thanks
Posted on Jul 25, 2010
    Problem Solver:
  • 4 Answers
The monitor its self has no problem but try installing the drivers again
Posted on Feb 06, 2009
MICROTEK C997SD MONITOR SHUTS OFF AFTER 5-10 MINUTES
If you turn your monitor on and when its on you go into your computers settings. Where you can fix your monitor and fix the resolution and all that. There should be a thing there where you can put never shut off. You have it on 5 to 10 minutes to shut off. That will keep the monitor from turning off again. I did this with mine it kept shutting off to. Thanks for posting I hope this helps you. I am sorry I couldn't be more detailed. i have been up all night lol.
Dec 12, 2017 | Microtek C997SD (Silver) 19 in. Flat Panel...
My Microtek 710S Monitor screen goes black if left unattended for one minute. What do I do to keep this from happening?
Check the power setting of your PC.
  • If you are on windows;
  • Click on start button
  • If you have vista or windows 7, type "poweroptions" into the search bar.
If not, open control panel and find the power options inthere
  • In "power options" you can change when the displaygets turned off and when your PC will go to sleep, just change these settingsto the time you want, e.g. 2hours
I can offer support for other OS if required
Mar 02, 2011 | Microtek 710S 17" Flat Panel LCD Monitor
Why dose mky monitor go blank after a few sec.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/
Jul 29, 2010 | Acer AL1715 17" LCD Monitor
Monitor flickers and goes blank after 5 seconds and keep repeating this very often.
If you turn the monitor off then about 1020 sec turn it back on and have a picture for five sec again it sound like the power supply in the monitor. but if that did not solve the problem, the picture board on your monitor is bad, since it goes off after few seconds and the power led or button is on, it means the picture board of your monitor has developed fault and will need to be replace.
I advice you replace the picture board on the screen of your monitor to solve the problem of the blank screen.
Take care.
Jul 26, 2010 | Acer AL2016W 20" LCD Monitor
Screen goes blank when first turned on, have to keep restarting m
Take care.
Jul 24, 2010 | Dell E153FP 15" LCD Monitor
Philips 150S screen turns on for 1 sec. and then gose dark???
nyounger4242, Very common problem!! learn to do flashlight test to evaluate "switch-mode-power-supply" status. Read my FIXYA profile to find out all you need to know about Black, or Black and Blank lcd screen fixes and the options you have. Your monitor NO DIFFERENT than any other CCFL Back-lit LCD monitor in it's basic design and operation!! Good luck with repair. Use warranty if possible. Read, Read, Read, before you do anything!!!! 12fixlouie
Feb 04, 2010 | Philips 150S4FB 15" LCD Monitor
hey momcowles3 wondering if you could do me a favor. i've been looking for the microtek 517m drivers online for a couple days now and there is nothing. I was wondering if you could give me a copy of the drivers. i can't find my installation cd either. thanks
Jul 30, 2008 | ViewSonic VP181s 18.1" LCD Monitor
X20G-Naga III screen goes blank after 1-2 secs
most common lcd monitor break down, check all electrolytic capacitors for leakage and loose board solder specially on the ccfl inverter section.
May 31, 2008 | Sceptre X20g-Naga III 20.1" LCD Monitor
INVERTER FAULT
May 01, 2008 | LG Flatron L1710S 17" LCD Monitor
Computers & Internet Logo
263 people viewed this question
Top Black Box Computers & Internet Experts
Johnny Massengill
Johnny Massengill
Glyn
Are you a Black Box Computer and Internet Expert? Answer questions, earn points and help others
