Question about Toshiba Satellite A135-S2386 Notebook
Cannot get my dvdshrink 3.2 to work anymore
Hello my ongoing problem started like this-- i had been using dvdshrink3.2 on my toshiba w/vista basic for 2 years no prob.then one day it started failing at around 85% of the burn process,it would encode the entire movie but would only burn 85% or so.same with cds as well.i thought it was the dvd drive so i bought a new one installed it with no change in the performance.so i got pissed and just wiped my entire hard drive (i had several other program probs).then i reloaded my disc that had dvdshrink 3.2 on it,to find that the version of nero key # i had was expired and if i wanted to use 3.2 i needed nero,so i downloaded the free trial of nero to check it out.my first attempt burned100% but the disc was incomplete,backwards(scene 3 before scene2 for example) no menus, unable to respond to remote functions.settings in shrink had been the same as always.my second attempt failed at 5%.wtf.can any one help me?do ineed to get an updated version of 3.2? is there any downloadable burning software that i could use other than shrink3.2/nero?this seemingly is the last prob my comp has please help me fix it before i throw it off a bridge.
  • 1 more comment
  • hodelizioso Feb 06, 2009
    i think i had nero 7 but when i erased my hard drive i lost it and when i went to reload the disc that had shrink3.2,alco,nero,and a couple other progs only shrink would load nero said it had expired and would not respond to any key numbers that i had (i think there is a program on same disc that generates key numbers for nero) but i when i used shrink the first time after the reload there was a blue note in upper right corner of backup setting box sayoing if i wanted to burn i was gonna need nero,so i got the trial version (nero 9) to see what was up .does not work i reloaded shrink and right now am trying to analyze,encode,burn,will take about an hour.but i dont have very high hopes so i dont know if i really have nero at all can nero 7... or 6.. be downloaded somewhere
    i would like to add that i can now produce discs that will play just fine in my computer but will not play in any other dvd player ifeel im so close if any one can shed a little light
  • Debs
    Debs May 11, 2010
    what version of nero are you using? It is probably best to use nero 6.
  • 903 Answers
I think it only runs best with nero 6, it probably may be hard to find a standalone download now as nero have trials all over the place. I know it does not work with the latest nero's and when loading nero 6 on vista it will say that it is incompatible, but it does still run and work fine. Just try googling for it and you never know you may find a torrent to download.
Posted on Feb 06, 2009
  • Debs
    Debs Feb 06, 2009
    change the settings in nero, there are two different settings for dvd burning, one for your pc only and one for most dvd players etc.. check the settings in nero and also set dvd shink to produce dvds that run region free once burned.
    Scholar:
  • 127 Answers
Try and download one of the software's available here
also download CCleaner from here and clean/fix your system from unwanted files and registry issues.
If you have a DVD lens cleaner...try to clean the lens of your DVD rom.
hope this helps, please rate.
System restore points
You need to stop using Vista as Microsoft has not supported it since 2014. OK to use Vista for a while after 2014 because Windows Update still gave security updates for other Windows products (Word, Works, etc.). But now, Windows Update for Vista will not work anymore for anything. At least switch to Windows 7 as Microsoft will probably support it until 2020.
Nov 24, 2017 | Microsoft Windows Vista Home Basic with...
CD-R disc 16x has photos burn on and will not load on toshiba C660D conputer. Error 0x80010108 appears
Welcome to FixYa! About "Error 0x8001010" this currently an ongoing issue for Windows Live Gallery whether its Vista or 7. I suggest using the old Windows Photo Viewer when trying to open the files on your cd. This should work. Hope this helps! Thank you for using FixYa!
Jul 04, 2011 | Microsoft Windows Vista Home Premium with...
My 3 yr old Toshiba - A135-S2386 - Vista - has
Just a suggestion................I have seen the RAM cause these problems in many laptops try your old RAM that came with it see if the problems persist....Good Luck
Jul 23, 2010 | Toshiba Satellite A135-S2386 Notebook
Toshiba Satellite Vista 32bit...Big start up Problems!
1. you could use the vista to reformat the drive.
2. you could use boot disk to do the same thing.
or
3. load again the vista for fresh installation.
Apr 08, 2010 | Toshiba Satellite A130 A135 Notebook
Non of the 3 USB ports works anymore for unknown reason
ok, the answer is pretty simple, ur usb ports connect to a internal hub, that hub is what has malfunctioned, u need to reinstall that device's driver though the device manager on vista, go to start, type device manager in the search box, click device manager in the list, a uac query will appear, click continue, on device manager go to universal serial bus controlers and click the +, right click the usb root hub and uninstall it, repeat that for all of the usb root hubs, then restart ur pc, it will automatically reinstall the devices with a fresh driver, plug in your usb device and it should work, have a great day and happy holidays
Dec 31, 2009 | Toshiba Satellite A135-S2276 Notebook
Toshiba satellite a135 windows vista basic cannot open anything in control panel can i open device manager another way, search will not work eitherwindows vista basic cannot open anything in control panel....
ok i know a way u can do this when u are starting your computer press and keeping re pressing f8 and u will be able to choose to start ur windows in safe mode with command promp...or u can turn ur computer off without useing normal ways ex. unplug and the opion to do so wil apear by itself
Jun 05, 2009 | Toshiba Satellite A135-S2386 Notebook
Dvd/cds will not burn past 85%
Try burning at a slower speed and try +r if using - R or visa versa on the dvd disks. My better half burns all the disks here and this is what she reccomends.
Feb 05, 2009 | Toshiba Satellite A135-S2386 Notebook
Toshiba Sat A135-S2386 System recovery downloads??
As you have stated that the key which  you have is for
Vista - basic
and the operating system is most probably vista Ultimate
hence the key is not working
what  You can  do is search the internet for a Vista Ultimate Prodct key
if you can find it i  guess the activation will go through  easily
if this  does not work  or you want any  other assistance please do post back.
Nov 09, 2008 | Toshiba Satellite A135-S4527 Notebook
About my vista home basic
Check in the device manager to know whether the drivers are installed.
The issue would be bcause of the drivers.You can install the drivers using the drivers cd which you shold be having.
You can also use this
Start / Programmes / Camera Assistant. No idea who the software publishers are.
Whether or not this software is running, You can start the webcam using the [Alt] - [F7].
Bluetooth :
Try to enable it using key combination FN+F8.
You can download the bluetooth software from here :
http://aps.toshiba-tro.de/bluetooth/
Good Luck.
Live, Love, Laugh.
May 07, 2008 | Microsoft Windows Vista Ultimate Edition
Toshiba Satellite A135-S2386 Notebook Logo
680 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
